RGBColor 1.0
RGBColor 1.0
Download: http://archive.info-mac.org/dev/rgb-colors-10.hqx
FOR DEVELOPERS ONLY!!!
"RGBColors is a small utility for mac developers. It gives you informations
about the color you're pointing with the cursor. Also runs in background.
If you're running it while it isn't in background, you can stop and restart
its detection pressing the space bar."
Pratically: you point somewhere on the screen, and the app tells you the
red, green and blue values so that you can know what to do with your
RGBColor.
