VersionFinder 2.5
VersionFinder 2.5
Download: http://archive.info-mac.org/app/version-finder-25.hqx
Version Finder is a Mac OS Application that keeps track of the current
version numbers of all your Applications, Extensions, Control Panels,
Drivers, etc. on your hard disk. You can quickly determine which version
of a program you have by consulting Version Finder. If you have internet
access and a web browser, you can use Version Finder to help search
various internet sites for possible updates to your files. If you have
MacOS 8.5 or later, Version Finder can use Sherlock to help find items on
the internet.
Version Finder has many other useful features such as the ability to
display the full pathname of items in its list, open Finder "Get Info"
windows for any of the items in its list, open the folder containing an
item in the list, and opening (launching) any item in the list. You can
also restrict the display to show only duplicate items, which can aid in
cleaning up duplicates on your disks.
New for version 2.5
- Additional and updated internet search web sites
____________________________________
William H. Tudor
email: [email protected]
Web : http://home.nycap.rr.com/tudor
Voice: (518) 428-4575
