PICT Compiler 2
PICT Compiler 2
Download: http://archive.info-mac.org/dev/pict-compiler-2.hqx
PICT Compiler 2.1
Matthew Dolan
©1999, Tri-Bar.
http://www.tribar.dabsol.co.uk/
PICT Compiler is a small compiler plug-in for use with CodeWarrior. It
allows the adding of various picture formats to the project. It
automatically converts these to PICT resources whatever file type they are.
Requires:
CodeWarrior 9 or better
QuickTime 2.0 or better
PICT Compiler is shareware, and as such if you continue to use it for more
than 30 days you should pay the $5 license fee (£2.50 UK).
