PatchMaker 1.0
PatchMaker 1.0
Download: http://archive.info-mac.org/dev/patch-maker-10.hqx
6/24/99
Patching will never be same
What it does
PatchMaker will generate C source code for a PPC extension to patch a trap or traps.
Instructions
1) Launch PatchMaker
2) Click on the traps which you want to patch
3) Use the File Do It Menu.
4) Name the output file "Patches.c" and place it in the same folder as the Patch_INIT.µ folder
5) Double Click on Patch_INIT.µ to Launch CodeWarrior
6) Choose make to build your extension!
USE AT YOUR OWN RISC
THIS IS A HACK AND IS EXTREAMLY DANGEROUS
