Download: http://archive.info-mac.org/app/update-agent-81.hqx
UpdateAgent 8.1 - Update all your software with just two clicks!
Nothing ruins the stability and performance of your Macintosh more than
old software. With just two button clicks, UpdateAgent automatically
brings all your Macintosh System Software, Control Panels, Extensions,
Applications, and Utilities up-to-the-minute and works forever to keep
them that way. It fixes bugs, adds new features and eliminates crashes
and lock-ups.
Download UpdateAgent now and get a Free Check-Up. The Free Check-Up will
report how many updaters you need and will also update your Macintosh
System software. To update all your third party applications, Control
Panels, Extensions, and Utilities obtain an Access Code and enter it into
the Free Check-Up.
Version 8.1 integrates Aladdin StuffIt version 5 resulting in 20% faster
downloading and faster decompression, and improves error messages which
assist in pinpointing problems.
Visit www.insidersoftware.com for more information.
Insider Software Inc
6412 Merlin Drive, Suite 700
Carlsbad CA 92009
sales: 800-700-6340
support: 760-804-9900
eMail: [email protected]
