Download: http://archive.info-mac.org/dev/jons-re ... lasses.hqx
Jon's RealBasic Classes is a set of custom classes for RealBasic. Examples
are included.
NumberField: Automatically filters out non-numeric characters from
EditFields while you're typing.
MultiCheckbox: Create a checkbox with up to 3 out of 12 possible states.
Change the colors, too.
FaderControl: Automatic fading boxes, buttons, and lines.
ScrollingText and ScrollingEdit: Those annoying scrollers that you see all
the time on web pages.
ComplexLib: Complex numbers for RealBasic! All the way from arithmetic to
trigonometry. Formulas are created using English-like syntax. Examples are
included in the ClassExamples.
SimFolderItem: Create a FolderItem-like object from any hierarchical list.
Combine with a file list box, and you have automatic hierarchical listboxes,
too. Supports AbsolutePath, Name, Parent, Child, Item, Count, Directory, and
Exists.
