ios 4.2
johnboy66
ios 4.2
Post by johnboy66 »
I am a dummy with ipad.
ok. How do I get ios 4.2 ?
I have the ipad_iOS4_User_Guide but no ios 4.2.
I have hooked up ipad. and itures but Itures does not have an update.
chasm
128 MB
Re: ios 4.2
Post by chasm »
If you have synced the iPad with iTunes and it says you are up-to-date, then you already have iOS 4.2
Cheers
chas_m
http://spacejavelin.com
iphonechik
Re: ios 4.2
Post by iphonechik »
Yup, what chasm said.
johnboy66
Re: ios 4.2
Post by johnboy66 »
How come I see on Ipad Version 3.2.2 (7B500) ?
Re: ios 4.2
johnboy66 wrote:How come I see on Ipad Version 3.2.2 (7B500) ?
Updates are handled through iTunes. So if your iPad says it's running iOS 3.2.2, then you have to plug it into your computer, go to its page in iTunes, and click Check for Update...
Screen shot 2010-12-01 at 9.17.53 PM.png (11.03 KiB) Viewed 18262 times
There isn't any other way to do it.
johnboy66
Re: ios 4.2
Post by johnboy66 »
iOS 4.2 Software update says updating is easy.
Connect your ipad to your PC and follow the onscreen instructions in iTures.
I Did.
and there are no updates available for any apps in your iTunes library.
Re: ios 4.2
johnboy66 wrote:there are no updates available for any apps in your iTunes library.
iOS is not an app. Updating apps and updating iOS are in two different sections of iTunes. Click on your iPhone/iPod/iPad (not the iTunes Store or "Apps" section) and then click Check for Update.
If you're clicking that and it's still not working then perhaps something's wrong with your iPad and you need to restore it, or you're using an old version of iTunes.
johnboy66
Re: ios 4.2
Post by johnboy66 »
I used to be a PC programmer I used Apple II. then got a windows dos,
But I was called a Tech. or more likely 'Hey you'
Then in '95 I had a Stroke, loss my right side, Memory, All hearing. Use a scooter if very far , One half blocks.
Sorry but I can't see what your saying.
I made a file itunes_is_fun.jpg and and another file as txt. but I just can't see what your saying.
I have to Start by deleted iTunes then reinstalling iTunes but I can't go it till monday.
We are camping with some friends and will be back Monday.
Re: ios 4.2
If the image displays too small in iForum, you can see a larger version of my image here. I'm saying when you plug your iPad into your computer, click on it's listing under "Device" in iTunes - do not go to iTunes Store or Apps, which is where you had to of gone to see "there are no updates available for any apps in your iTunes library" as you described earlier.
If you're at the proper iPad device area, you click Check for Update, and it still doesn't update then:
  • your iPad is up to date,
  • you're still clicking the wrong button,
  • or your copy of iTunes is out of date.
In none of the above cases is deleting and reinstalling iTunes your best option.
johnboy66
Re: ios 4.2
Post by johnboy66 »
Turboladdade,
I have ipad waiting
I Dled iTures Again.
At the top I have
File Edit View Controls Store Advanced
On the left side I Have this
Library
Music
Books
Apps
Store
iTues Store
PlayLists
90's Music
Classcal Music
Music Videos
My Top Rated
Recently Added
Recently Played
Top 25 Most Played
Now What?
Re: ios 4.2
Well, for whatever reason, your iPad isn't showing up in your list there. If it were, it would look similar to this:
That's where you need to go to update your iPad's operating system... as well as sync your iPad with your music, videos, and photos, apps, restore the iPad to factory settings, etc... by what you're describing, you haven't been able to do any of that, or lost that ability somehow.
I guess the next question is, are you on a Mac or PC?
johnboy66 wrote:I Dled iTures Again.
Nobody told you to do that.
johnboy66
Re: ios 4.2
Post by johnboy66 »
I have an PC, XP Home SP3
Re: ios 4.2
When you plug in your iPad, does the iPad's screen indicate that it is connected or syncing or anything like that?
johnboy66
Re: ios 4.2
Post by johnboy66 »
I can use Safari, Maps. Mail, Photos, and Stanza books.
I did have syncing.
mark_42
Re: ios 4.2
Post by mark_42 »
Johnboy66, are you plugging the iPad into your PC or the charger?
Mark
johnboy66
Re: ios 4.2
Post by johnboy66 »
Mark,
I have been plugging the iPad into my PC until I get tired. Then I plug it into the charger .
But now I have using itures to run support and right now I can't even use itures.
Use the Control Panel to uninstall iTunes and related software components in the following order:
iTunes
QuickTime
Apple Software Update
Apple Mobile Device Support
Bonjour
Apple Application Support (iTunes 9 or later)
Important: You may see various alert messages if you uninstall these applications in a different order or only uninstall certain components.
For detailed steps on removing and reinstalling iTunes and related components on Windows XP, refer to the following steps:
Removing iTunes
Removing QuickTime
Removing Apple Software Update
Removing Apple Mobile Device Support
Removing Bonjour
Removing Apple Application Support (iTunes 9 or later)
Verify iTunes and related components are completely uninstalled
Reinstalling iTunes and related components
After verifying that iTunes is completely uninstalled, you should download and install the latest version of iTunes.
then I found another site that used Windows XP and Apple and they said
When I received notice to update my iTunes to version 10, I ran into the error message about Bonjour and not having access to the folder. I solved it by:
1. Uninstalling iTunes
2. Uninstalling QuickTime
3. Uninstalling Bonjour, or trying to. When I couldn't, I deleted the Bonjour folder in C:\Programs.
4. I downloaded all three programs from the Apple site to my desktop.
5. I rebooted my computer.
6. I installed Bonjour.
7. I installed QuickTime.
8. I installed iTunes.
All my music was still there and everything is working well. I think it helps to uninstall and install the programs in the above order.
and ---
Go to this website to fix it: http://www.raymond.cc/blog/archives/200 ... ponderexe/ I just found this website, I followed the instructions and I was able to delete the bonjour file. It is really simple to do. Hope it will work for you guys. My ipod is working fine now.
right now I can't even get itures.
Re: ios 4.2
You know, you can update your iPad's operating system on anyone's computer, even ones it isn't synced with. For the immediate task of updating your iPad, why don't you just use someone else's computer with working iTunes to update it's operating system.
I'm at a total loss with regards to what is happening to your PC, but I suspect it may have something to do with the fact that it's a PC. Hopefully somebody can come to your rescue here.
johnboy66
Re: ios 4.2
Post by johnboy66 »
I had a password in Gmail go out on me this morning.
It took me about 4 hours to fix it. took me a while to change it.
Then ipad has Cannot get Mail
The user password is incorrect.
Re: ios 4.2
That means you have to change your password in Settings -> Mail -> Accounts.
johnboy66
Re: ios 4.2
Post by johnboy66 »
Turboladdade wrote:That means you have to change your password in Settings -> Mail -> Accounts.
Thanks, I reentered my password, after I put ipad into USP port.
It works now. Yea. lol
I missed something putting my password it.
Thanks
