iOS 4.2 Good or Bad?
danielcarlisle
4 MB
Post by danielcarlisle »
Is the iOS 4.2 or iPad good or bad. What do you like and dislike about it?
Re: iOS 4.2 Good or Bad?
danielcarlisle wrote:Is the iOS 4.2 or iPad good or bad. What do you like and dislike about it?
iOS 4.2 update is really great for iPads. It brings long-awaited multitasking to the iPad and finally, feature parity between iPads and iPhones/iPods. I've just recompiled and resubmitted iForum to make proper use of iOS 4.2, so hopefully it gets approved in short order.
williamwe
Post by williamwe »
I haven t no problem for the moment
perhodes
Post by perhodes »
So far so good. Downloaded a hack for my Mac to get AirPrint working with my printer. Looking for something that will get airplay to work with my old apple tv. Hate hate hate the change to the orientation lock.
danielcarlisle
4 MB
I hate the screen lock to and the mute button doesn't even work right...
