Newbie iPad Questions
johnboy66
Post by johnboy66 »
Ipad
1. how do I delete an App that I don't use?
2. I think next week that Apple has an iOS upgrade. How do I handle it? APP and files.
I know Windows requires backup. How do I backup?
very newbee.
Ipad and windows
chasm
128 MB
Re: Newbie iPad Questions
Post by chasm »
1. Touch and hold any app. They will all start to "wiggle" and a black X appears in the upper left corner of their icon. Touch the X on any app you want to delete.
2. Your iPad is automatically backed up each time you sync it with your computer unless you have deliberately turned this off, so it's a non-issue.
And if you think that's cool, you should try a Mac! :)
Cheers
chas_m
http://spacejavelin.com
johnboy66
Post by johnboy66 »
Thanks, That works.
I did not deliberately turned it off. I did not know that. lol
