Download: http://archive.info-mac.org/dev/37th-resex-202.hqx
37thResEx is a useful application for seeing, extracting, copying and
transferring resources from files. By means of it you may:
- view all types of resources into files;
- view all resources of determined type;
- view resources contents;
- know resources attributes;
- gather resources infos;
- copy individual resources or whole types into already existing files or
into new ones;
- modify attributes of copied resources;
- modify attributes of original resources;
- remove from files individual resource or whole types;
- check the Resource Fork integrity.
37thResEx can also convert resources of type 'snd ', 'TEXT', 'PICT', and
icon families into double-clickable files:
- converted Icon families show theirs own icon on the desktop;
- converted 'snd ' resources become sound files;
- converted 'TEXT' resources become styled text files
- converted 'PICT' resources become pict files.
Last, but not least: by means of hot key, you may achieve directly the
Conversion dialogs, without opening the file-related window. Moreover, if
you launch 37thResEx by using this feature, after completing its job it
quits itself automatically.
37thResEx is Internet Config, Drag Manager, Balloon Help and Navigation
Manager aware, moreover it's Appearance savvy. It requires at least System
7 to run.
Author: Rocco Moliterno
mailto:[email protected]
http://yellowsoft.tsx.org
37thResEx page: http://www.geocities.com/SiliconValley/ ... resex.html
What's new in 2.0.2 version
- Code optimized for better performances.
- Improved Internet menu.
- Addresses update.
- Removed registration form from About Box.
- Added Registrations folder.
- Added Support folder.
