iPhone 4 flash problem
nmb20
Post by nmb20 »
Does anyone else experience a hazy look to photos taken with cases on iPhone 4? Many of them design the cases too close to the camera/flash and it produces a milky look in the photos. If I take the case off, the photos are clear.
Has anyone found a case that works with the flash?
Re: iPhone 4 flash problem
I had the Speck PixelSkin case for my iPhone 3G. It was great, extremely protective (I dropped on concrete dozens of times). It also fit my iPhone 4 nicely, which was a surprise, but as it was designed for the older phones it did the same thing you described above (it completely covered the flash).
I now have the Griffen Perforated Silicone Case / FlexGrip Punch. It's opening for the camera and flash is very wide as you can see below.
I'm pretty satisfied with this case so far. I like the thinner profile compared to the big Speck case from before. I only worry that it leaves the bottom of the phone a little flimsily protected.
I hear that Speck now has a PixelSkin for iPhone 4 but, as you suggested, it's opening for the camera is much closer and snug around the camera and flash.
RUcollegeBoy
Post by RUcollegeBoy »
I use a nice blue ifrogz case on my iPhone 4 and haven't exeperienced this issue.
Have you tried your flash with more than one case?
Janet
Post by Janet »
No, I don't have the problem, I think you should try one more case
