Virtual WineCellar 4.5
Download: http://archive.info-mac.org/data/virtua ... lar-45.hqx
http://www.rootsolutions.de/vwc/index.htm
May be included in CD ROM collections
Requirements: Any Mac with FileMaker Pro 5.0 or later.
Standalone applications for OS X and OS Classic available from
Virtual WineCellar is an easy to use cellaring software for wine collectors.
It keeps you informed about stock and history and shows the current value of
your wine collection. Apart from the standard data entry fields, it features
several advanced functions, like user defined fields, a suppliers database
with order-to-inventory processing, integration with Vinote (TM) barcoded
neck tags, support for digitized bottle labels, and much more.
