Is it possible to tether iPad with iPhone.
I recently purchased my iPad and am loving it, however I only bought the WIFI version thinking I'd only use it at home and such, however I like the iPad a lot and im beginning to think i'd like to take it to work etc. Can anyone think of a way to use my iPhone to provide the 3G connection to my iPad on the rare occasion that i might need it??
Neither are jail broken and I've no plans to jail break them any time soon. I don't see a need to jailbreak, i like the products the way they were sent from apple.
GiraffeeDreams
- 4 MB
Re: Is it possible to tether iPad with iPhone.
As far as I'm aware you can only tether with a device with ad-hoc support and the iPad and iPhone don't support this.
Computers and other phones that can ad-hoc are usable, hope this clears things up.
Thanks guys. I think I'll be buying an iphone 4 then
PaulPalmer
- 16 MB
Go for it the iPhone 4 is cool
But,,,, The iPhone 4 will not resolve your 3G need.
On some forums I read the possibility to make a private wifi LAN using your iPhone and/or your MacBook when you are on the road, but not tested by me, because at last I prefer to bought the 3G iPad. For the thinking iPad bayers: if you have kids, then buy the 64gb, you will need it just for their movies and of course ever and ever the 3G version.
PaulPalmer
- 16 MB
One of the features of the iPhone 4 is that you can use it as a modem isn't it?
Buy a second hand Nokia Series 60 RD ( they are not expensive) and install Joikuspot for about $5, then you can use it as hotspot. I was using it on my bus trip recently and works great.
iPhone 4 can connect to iPad? hmm, that's difficult.
Well, I like iP4 facetime, but I have got my iPad, and enjoyable with it.
All you need is a jailbreak and MyWi from the Cydia store. Then you will be able to turn your iPhone 3G/3GS/4 into a mobile hotspot.
