Download: http://archive.info-mac.org/data/troi-c ... lug-16.hqx
Troi Coding Plug-in is a very powerful tool for securing your
FileMaker data, exporting or emailing your data without risk and
importing safely back into FileMaker. All from within FileMaker you
can:
- encrypt fields using the powerful newDES encryption scheme, so that
your sensitive data is secure
- export encrypted data that can be sent safely over the Internet,
for example via email. No risk that someone will read or change the
data while in transit
- use the decoding functions to restore the original information
after you have imported the received email or export file back into
FileMaker, with the assurance that nobody will have tampered with it
- verify data integrity and sources with the checksum function
- create text signatures to ensure the text is original
- make conversions to and from binary
- compress databases with large text fields
New Features
Troi Coding Plug-in 1.6 (release date June 25th, 2001) adds these new
functions and features:
- Tested with FileMaker 5.5 and made compatible for Mac OS X. The Mac
OS version of the plug-in is now a so called 'Super Fat' plug-in that
will run on Mac OS 8, 9 and Mac OS X.
- Improved Version function. It now also can show the Flash Dialog
and return a version build number.
Troi Coding Plug-in is shareware and costs US$ 39 per user. Developer
licenses and multi-user discounts are available.
