Hello
I have a iphone 3g with the firmware version 4.0.
I have too much problem. Its possible the iphone downgrade, to version 3.x??
Thanks, and sorry for my englisch
iPhone 3G with 4.0 os update. Downgrade
romero_javi
- 1 MB
Re: iPhone 3G with 4.0 os update. Downgrade
Officially, no. There is (or was) a hackish way to do it, back when iOS 4 was only available to developers and many developers found the pre-release versions too unreliable to use regularly. However, I'm not sure that this same method works for the actual public version of iOS 4.
http://www.youtube.com/watch?v=m0vXULSW ... r_embedded
It was pretty complicated and I wouldn't recommend it.
Actually, it's possible; follow the advice/steps here:
http://www.macworld.com/article/152428/ ... ogs_mac911
I did it myself and it worked like a charm; good luck romero!
SchwarzerFuerst
- 1 MB
Hello, i had similar Problems After load os4.0,
But now all Problems are Away:
I load all apps New and now the System is highly stabil
Greetings from Berlin
DER SCHWARZE FueRST
DER SCHWARZE FueRST
