Software & Hardware Tracker 3.5
Download: http://archive.info-mac.org/data/soft-h ... ker-35.hqx
by DXoft
June 3rd, 2000.
Version 3.5 of Software & Hardware Tracker is now available.
Main changes in version 3.5:
- Corrected a bug in the Workstation Model field validation options.
- Cleaned up a lot of scripts' "messages".
- Added fields to the Product, Purchase and License Trackers to let version
3.5 export records compatible with the new Software & Hardware Tracker 4
file format.
- The source of the issue affecting Purchase IDs' calculations has now been
identified and is now listed as a "known issue". It's fixed in the upcoming
Software & Hardware Tracker 4.
All Software & Hardware Tracker 3.x users should download and install this
free update.
A CNET/Download.com "Premiere" and "Top Pick" and a BizProWeb "Pick of the
Day", Software & Hardware Tracker is a collection of FileMaker Pro 3.0/4.0
relational database which will help you collect, store and organize useful
information (such as registration codes, serial numbers, product notes,
etc.) about all your computer products (hardware and software). Relying on
the standard Internet Config system, Software & Hardware Tracker is
perfectly integrated with your other Internet software. It also keeps track
of all your contact information for software and hardware developers,
distributors and places of purchase, turning it into a powerful contact and
Internet bookmark manager.
Software & Hardware Tracker 3 is compatible with FileMaker Pro 5 once
converted to the new version's file format. The conversion happens
automatically when one opens Software & Hardware Tracker using FileMaker Pro
5 or later.
Software & Hardware Tracker is being distributed as shareware. Several
registration and upgrade options are available. Registrations are handled by
Kagi Shareware.
