TechTracker Pro 1.1 - Software Update Monitoring Client
Download: http://archive.info-mac.org/app/tech-tracker-pro-11.hqx
Introducing TechTracker Pro, the latest way to keep your software up-to-date
and your computer systems running smoothly. Now you can personalize
VersionTracker.com's software support information and create tracking lists
for the software that you care about. On the Web or on your desktop,
TechTracker Pro lets you track customized software lists for up to three
machines.
The service is two distinct pieces that work together: the
VersionTracker.com Pro tab and TechTracker Pro desktop client. Each piece
can work independently but their true potential is revealed when they are
used in conjunction.
The Desktop Client will be able to check for out of date applications,
extensions, and control panels. It can keep track of applications on up to
three machines and, you will receive proactive notification when any of the
applications you have installed on your machine are out of date.You can,
from the VersionTracker Pro tab, track the status of all three machines in a
single place. Additionally, you can track applications you are interested in
that are not installed on your computers by adding them to your list
manually (this can be done via the Pro tab )
Requires Mac OS 8.6 - 9.2
