Photo booth/iSight GONE!
Updated to Leopard, and since then, can't find built in iSight, and photo booth application is GONE! D: What do I do??
Re: Photo booth/iSight GONE!
Is it not in your Applications folder?
"Never trust a computer you can't throw out a window."
You might have accidentally taken the shortcut to it out of your Dock, but it's probably still in your Applications folder.
I lost my photo booth too, I just reloaded the Leopard update( I had erroneously deleted it from the applications folder)
Not in applications either! How can I get the leopard update?
I believe you can use Pacifist to extract it from your original install disks.
Thank you. I'll give it a shot!
