TargetDate 1.0.3
TargetDate 1.0.3
Download: http://archive.info-mac.org/app/target-date-x-103.hqx
TargetDate 1.0.3 is a small utility to track the progress of your pregnancy.
It is an easy way to see how far you have come and how much longer you have
to go. You can use it to determine Due Date, Conception Date, Last Menstrual
Period, etc... . There is a Milestone feature that is customized to your
pregnancy that shows key dates and development stages of your baby's growth.
The Milestones data can be saved to a text file to be printed, emailed or
shared. You can modify "Today's Date" to see how far along you are on any
given date. The number of days left are displayed in the dock for OS X
users. TargetDate will update the days left information if left running
without you having to update the current date. There is even a progress bar
to visually track your pregnancy!
What's New:
Version 1.0.3 Fixed bug that would not update dock icon if the main window
was closed.
Now correctly resets dock icon on quit.
Requirements:
Mac OS 8.6 or later, CarbonLib.
