Info-Mac Digest V7 #48
Subject: Info-Mac Digest V7 #48
Date: 9 Mar 89 23:09:01 GMT
Lines: 316
Info-Mac Digest Thu, 9 Mar 89 Volume 7 : Issue 48
68030 bug in TMON
A/UX Shutdown procedure for Non-superusers
Ada for Mac IIx
Answers to memory questions
Data Sharing
Hypercard, Macs and Modems
Hypercard problems
Ignisound V1.5
Interrupt button
Jasmine's DirectPrint
Looking for SU-MacIP comm. software
mice
Talking Moose 1.21 on a Mac II
The search for a "kinder quieter SE"
Date: Wed, 8 Mar 89 20:44:30 EST
Subject: 68030 bug in TMON
The 7th March issue of MacWeek (MacInTouch column) has the following fix for
TMON v2.8.1, to make it compatible with 68030-based Macs (ie, IIx, SE/30...).
o Open TMON w/ ResEdit.
o Open MonC resource & duplicate 'MonC ID 2'.
o Select the new resource just created and give it ID=3.
o Close the MonC resources, and repeat the procedure w/ resource 'MonI ID 2'.
This info was provided by Eugene Evans at ICOM Simulations, and all flames,
bug reports, etc, should be sent to him (Hell, I don't even have TMON:-})
tom c
Electromagnetic Armament Technology Branch
US Army Armament Research, Development and Engineering Center
Picatinny Arsenal, NJ 07806-5000
ARPA: [email protected] -or- [email protected]
UUCP: ...!{uunet,rutgers}!pica.army.mil!tcora
Date: Wed, 08 Mar 89 11:07:30 PLT
Subject: A/UX Shutdown procedure for Non-superusers
We just got an A/UX machine which will be used by several different
people (though
only one at a time -- no serial port log-ins or ethernet clients). The
"shutdown" command can be issued only be the superuser. If a non-superuser
comes in, powers up, logs on, does some work -- how does he shut down?
Is it OK to just power the machine off at the "login:" prompt? If not,
what? I don't want to scramble our file system -- I also don't want to
give the superuser password to everybody, or have to babysit each use
just to log off.
Also, we have to shut down A/UX to get back to Mac OS (which most of the
people on our Mac II prefer).
Date: 08 Mar 89 0035 PST
Subject: Ada for Mac IIx
Are there any (preferably certified) Ada compilers available for the
Mac IIx? If so, home much memory and disk do they need to run effectively?
Thanks.
Arthur
Date: Thu, 9 Mar 89 10:31:24 -0500 (EST)
Subject: Answers to memory questions
I received a number of responses to my first two questions, but not to the
third. So here is a summary of the answers to the first two questions.
>Hi,
> I have a couple of questions about Mac simms. I removed two 256K simms from
my Mac >Plus, when I upgraded it to 2.5 MB.
>Is there a way to tell the speed of these simms by the age of the Mac Plus, or
by looking at the >simms?
You can tell the speed by the last two digits on the chip. -15 means 150 ns and
-12 means 120ns.
>Are Mac simms and IBM simms interchangeable as long as the simms are fast
enough?
It is possilble to use IBM simms in Macs, but not Mac simms in IBMs. IBM simms
are 9 bit chips. The nineth bit is used for parity checking, and according to
Lee Larson,
"statistical analyses have shown that there is no significant
increase in reliability in using that ninth chip as IBM does. It is only
used once, during the boot-up process. It has as much chance of failure
as any other chip in the system, so 1/9 of the time, the parity chip
is the one that goes. (More parts ==> More failures)"
>Is it possible to use Mac simms in a 512KE, ie. does the 512KE macs have simms
slots?
I haven't gotten an answer on this question.
Thanks to all the people who responded.
John Salmento
Date: Tue 07 Mar 1989 22:47 CDT
Subject: Data Sharing
Could anyone out there tell me how simple it would be to share the data
contained within a HyperCard stack, among a number of users on an AppleTalk
network.
Optimally we would like to have, say 6 Macs, with perhaps two of them wishing
to access the same HyperCard file (not necessarially at the same time), but
without having to worry about merging the changed data from two copies of
it every day.
What software would make this sharing possible, and would be quick, and
reliable. I was thinking AppleShare, but I want to research all the
possibilities.
We will probably also be sharing a number of other applications...
Any help is greatly appreciated...
Bye for now but not for long
Greeny
BITNET: MISS026@ECNCDC
Internet: MISS026%[email protected]
Date: 8 Mar 89 12:10:00 EST
Subject: Hypercard, Macs and Modems
I have a Hypercard stack that will dial a list of phone numbers and see if a
CONNECT is made to a computer. I am interested in knowing if there is a way
that I can modify this stack to 1) detect when someone answers the phone and
2) deliver a digitized message? I am looking for a way to use my Machintosh and Hayes modem to call members of our computer club and leave a message telling of meeting times.
Date: Wed, 8 Mar 89 23:56 EST
Subject: Hypercard problems
I have previously indicated problems with hypercard sounds quiting and
eventually corrupting cards. I recently received version 1.2.2. While
I have not been able to extensively test it for more than 1 hour, it
seems to have cured the problems. Sounds now work, even after using
DAs. Also, cards don't seem to get corrupted anymore either.
-- Doug
Date: 9 Mar 1989 10:22 EST
Subject: Ignisound V1.5
This is a cdev which allows you to play a sound (snd resource)
at startup.
Written by Steve Bollinger
Copyright (c) 1989 Steve Bollinger and Mushyware
All Rights Reserved
This may be freely distributed in an unmodified form.
See inside for details.
Shareware $10
[Archived as /info-mac/cdev/ignisound.hqx; 36K]
Date: Thu, 9 Mar 89 10:05:10 EST
Subject: Interrupt button
Here's a question I've been wondering about for some time.
Back when I used a Mac+, if something happened which froze the Mac, or
caused a system error, I could (sometimes) escape to the Finder by pressing
the interrupt key on the side of the machine, and typing 'G 40F6D8' in the
debugger window which appeared. This saved the hassle of rebooting,
particularly when SCSI disks like to be shutdown properly.
Now, my boss has gotten me a shiny new SE! But typing 'G 40F6D8' does nada.
It simply returns me to the debugger window. Typing 'G FINDER' sometimes
gives me a 'Restart or Resume' dialog box (DSAT, right?), but most times,
the Resume option isn't hilited, so I have to restart the mac anyway. And
wait while the HD straightens itself out...
Does anyone have any suggestions as to the proper way to recover from this?
(ie, what to type in the debugger window?) I will summarize to the net.
tom c
Date: Tue 07 Mar 1989 22:48 CDT
Subject: Jasmine's DirectPrint
Has anyone out there used, or heard anything good/bad about Jasmine's new
"laserprinter" the DirectPrint?
Problems, advantages, etc...
Greeny
Date: Wed, 08 Mar 89 13:49:40 EDT
Subject: Looking for SU-MacIP comm. software
I am looking for the source host of the SU-MacIP software usable for
communicating on the Internet from a Mac via a variety of mediums. I saw
version 2.0 working somewhere and it's FTP interface looked a lot more
friendly than NCSA's.
Since this is Stanford developed software, I should assume that it is
to be found within the '.Stanford.EDU' domain, but in which host ?
Thanks for any pointers.
Juan Courcoul
Date: 6 Mar 89 11:05:00 EST
Subject: mice
I need to order a replacment mouse for a MAC II. Can anyone out there on the
net recommend a mouse? Send replies to [email protected]; if there
are enough replies, I'll summarize to the net.
_______ Michael Roman
/ | Cornell University
| | Wilson Synchrotron Lab
_________/ | Ithaca, NY 14853
Date: Tue, 7 Mar 89 09:41:08 edt
Subject: Talking Moose 1.21 on a Mac II
CEO summary:
I picked up the most recent copy of Talking Moose and have yet to
be able to get it to work on the two II's we have here. We have
tried under Finder and Multifinder (I dont recall their versions but
can check if it matters).
We had no problems with the FTP or the unpacking. We cant get it
to do anything under Finder and it enters what appears to be an
infinite loop when run under MultiFinder (the watch stays up for > 5
minutes so we aborted it). Has anyone else had problems? Is there
something I especially need to do?
Bruce ([email protected])
Date: Thu, 9 Mar 89 08:18:39 PST
Subject: The search for a "kinder quieter SE"
The noise from the fan on may SE is becoming very distracting.
Mobius offers a replacement called "The SE Silencer" which will
replace original fans in pre-December 1987 Mac SE's. Has anyone had
experience with this fan? Is it more quiet? Does it work? I purchased
my SE in Feb of 1988, how can I determine the manufacture date? Are there
any other fans out there worth looking at? Any information would be
Naval Postgraduate School Monterey, Ca.
