MultiXfer v0.3a2
MultiXfer v0.3a2
Post by Info-Mac » November 21st, 1989, 1:42 am
Path: utzoo!utgpu!jarvis.csri.toronto.edu!mailrus!cs.utexas.edu!wuarchive!psuvax1!brutus.cs.uiuc.edu!rpi!batcomputer!rpi!rpiburst!rpi!gem.mps.ohio-state.edu!tut.cis.ohio-state.edu!ucbvax!SUMEX-AIM.STANFORD.EDU!Info-Mac-Request
Subject: MultiXfer v0.3a2
Date: 31 Oct 89 21:12:48 GMT
Lines: 32
To: [email protected]
This is the latest version of MultiXfer (V0.3a2).
MultiXfer is a telecommunication application in which I implemented
a protocol based on X.25 allowing someone to make simultaneous
upload/download/chat (this is the kind of protocol used in MCS).
While in simultaneous upload/download, protocol efficiency is
at his best being as good as 3 times faster than XModem and
50% better than ZModem (which is considered the fastest protocol
available).
MultiXfer is a Mac-to-Mac serial-to-serial file transfer utility.
This means it can transfer files between two Macintosh linked by
modems or a null cable.
One of the major feature of MultiXfer beside its protocol is its
ability to turn your Macintosh into a host computer letting other
peoples under MultiXfer call your Mac, receive, send, catalog files
and navigate through the directories of your disk without any
human intervention.
There is also a VT-52 terminal implemented into the application
and it is MultiFinder friendly (can be used in background).
Most of the changes to V0.2 are related to the terminal emulator.
The VT-52 terminal emulator has been designed to be functionnal
for baud rates ranging from 1200 to 9600 bauds.
Martin Dubuc
Universite de Montreal
[Archived as /info-mac/comm/multixfer-03a2.hqx; 55K]
