Software & Hardware Tracker 3.6
Download: http://archive.info-mac.org/app/softwar ... racker.hqx
by DXoft
June 21st, 2000.
Version 3.6 of Software & Hardware Tracker is now available.
Main changes in version 3.6:
- Software & Hardware Tracker now informs you when it finds records with IDs
longer than 60 characters so that you can try to shorten them.
- Fixed several buttons which didn't invoke the correct scripts.
- Fixed a field in the Purchase Tracker, the type of which had been switched
to "time" by mistake.
- Fixed two fields in the Company Tracker which didn't call upon the right
relationships.
- Fixed two "Omit" scripts so that they really omit all the records they are
supposed to.
- Added fields to let Software & Hardware Tracker 3.6 find long IDs.
- Added a few more fields to help version 4 import version 3.6 records
directly. It means you must upgrade to version 3.6 (3.5 lacks a few
important fields) to be able to restore your records into the upcoming
version 4 automatically.
All Software & Hardware Tracker 3.x users should download and install this
free update.
A CNET/Download.com "Premiere" and "Top Pick" and a BizProWeb "Pick of the
Day", Software & Hardware Tracker is a collection of FileMaker Pro 3.0/4.0
relational database which will help you collect, store and organize useful
information (such as registration codes, serial numbers, product notes,
etc.) about all your computer products (hardware and software). Relying on
the standard Internet Config system, Software & Hardware Tracker is
perfectly integrated with your other Internet software. It also keeps track
of all your contact information for software and hardware developers,
distributors and places of purchase, turning it into a powerful contact and
Internet bookmark manager.
Software & Hardware Tracker 3 is compatible with FileMaker Pro 5 once
converted to the new version's file format. The conversion happens
automatically when one opens Software & Hardware Tracker using FileMaker Pro
5 or later.
Software & Hardware Tracker is being distributed as shareware. Several
registration and upgrade options are available. Registrations are handled by
Kagi Shareware.
Thanks for your support!
DXoft Technical Support
