Subject: Info-Mac Digest V7 #113
Date: 27 Jun 89 02:07:49 GMT
Sender: [email protected]
Reply-To: [email protected]
Lines: 387
Approved: [email protected]
Info-Mac Digest Mon, 26 Jun 89 Volume 7 : Issue 113
Batchbin3k?
BookEnds biblographer
Convert .hqx into AppleShare(CAP) files
Deskzap
drawing grayed text
More on SoftPC 1.3
Public domain TeX for the Mac exists!
Rappaport plug
Search for a decent lib program for Absoft Fortran 2.4
Spell Checker for HC
Please send articles and binaries to [email protected].
Send administrative mail to [email protected].
Date: Sun, 25 Jun 89 22:48:32 PDT
Subject: Batchbin3k?
I just tried Batchbin 0.51 posted here recently. Under the menu
"Conversions" there are two items - "MAC=>IBM" and "IBM=>MAC".
On my Mac Plus, the second item "IBM=>MAC" is greyed out, so I
can batch convert files *to* MacBinary, but I can't do the opposite.
There was no mention in the docs about this. Has anyone else
had this experience with Batchbin?
Date: Mon, 26 Jun 89 17:01 N
Subject: BookEnds biblographer
BookEnds Reference Management System is HyperCard Stackware
and it costs $99. Latest version is 1.1, as far as I know.
It is provided by
Sensible Software, Inc.
335 E. Big Beaver, Suite 207
Troy, Michigan 48083
(313) 528-1950
MS-DOS version is also available (I don't have experience on
that, though).
Features:
- Database size is limited only the free disk space.
- It has categories for author, title, editor, journal, volume, pages,
date, publisher, loacation, keywords, abstract, and classification
- Each category can have up to 30 000 characters
- Convenient import abilities including:
1. Tab delimited text files (data type typical for most database
applications in MacWorld)
2. Other BookEnds databases (from MacIntosh, Apple II or IBM-compatibles)
3. Dialog
4. MedLine/MedLars
5. BRS, MESH format
6. BRS, Generic format
7. MedLine Knowledge Finder (CD-ROM)
- Generates alphabetical listing of all unique authors and keywords in
a database
- Export to text files and to other BookEnds stacks
- Duplicate references can be deleted
- A Journal Glossary with abbreviations of the journal name for easy
source entering
- Boolean AND, OR and NOT searches supported (although a bit limited)
- References can to searched by scanning the stack, by the absolute number
of the reference, with Search command (scans all the desired categories),
or by Find command which scans only one category at the time.
- Matches can be sorted by any two categories
- Output can be formatted easily. 10 editable formats can be used at
one time. The order of categories,as well as author and editor names
can be formatted (Fonts and styles cannot be formatted)
- Output can be:
1. Printed
2. Sent to a text file
3. Sent to the word processor you like best
- MultiFinder compatible (not copy protected)
These are the main features, some others are still available
Our experience so far:
We have some 3400 references now, and the worst possible search
(that is, searching all the categories and collecting the matches
using quite simple AND or OR logics) will take our Mac II (5 MB)
about 9 and a half minutes. Searching from one category without a
match list collected is almost immediate. By using short search strings
the search will be faster.Mac Plus is irritatingly slow (the job
would take some 20 min).
The most important feature for us is the Import capability. We can
import references from Datastar's (in Switzerland) MedLine database
>From the on-line log file with a converter program written in Fortran.
I get the log file from our library and run a conversion application
in our mainframe (VAX) and transfer the file to Mac II using the FTP
protocol and Import the references. This takes only some 5-10 minutes
in all.
Datastar's MedLine can be imported without the conversion by using
BRS, Mesh format Importing in BookEnds, the drawback is that BookEnds
cannot separate the categories in the reference source, so the source
will go into category Journal. Also the authors do not always import
correctly.
We are quite satisfied with BookEnds, but it could be faster. It
might be possible to Import references from CCOD (Current Contents
on Disk), since CCOD can output the references in MedLine format.
I don't have any experience on that. Anyway, this would add the value
of this package.
Mikko Lammi
Department of Anatomy
University of Kuopio
Finland
Date: Mon, 26 Jun 89 14:28:50 EST
Subject: Convert .hqx into AppleShare(CAP) files
Given a number of .hqx files on your favorite CAP-server, how do you
get all files extracted the easiest way?
Is there a utility that takes a .hqx file, and unpacks it into the
three files used by AppleShare(CAP) ('.finderinfo/file',
'.resource/file' and 'file')? There are several ones to convert into
.bin and macput format but I have not seen a CAP one.
/hans
Hans Eriksson ([email protected])
CSIRO/DIT, 55 Barry Street, Carlton, Victoria 3053, Australia (we are GMT+10)
Tel: +61 3 347-8644 Fax: +61 3 347-8987 Home: +61 3 534-5188
On a years leave from Swedish Institute of Computer Science ([email protected])
Date: Sun, 25 Jun 89 22:54:08 PDT
Subject: Deskzap
Does anyone have a version of Deskzap newer than 1.3a8? That version
works OK, but some of the file dialogs will work *real* slow when
certain other inits like MacroMaker are loaded.
Date: 26-JUN-1989 21:33:05.30
Subject: drawing grayed text
Hello all,
Is there a standard way to draw grayed text (or text using any pattern
in general) with QuickDraw? Unless I've missed something, it's not available
directly, but is of course used all over the place. Is there a generally
accepted way of doing it? Thanks,
Richard Silverman
arpa: [email protected] Computing Center
bitnet: rsilverman@wesleyan Wesleyan University
CIS: [72727,453] Middletown, CT 06457
[The answer (for items in a DITL) can be found in Apple's Macintosh Development
Questions and Answers stack in the /info-mac/apple/stacks directory. -Bill]
Date: 26 Jun 89 15:08 EST
Subject: More on SoftPC 1.3
Date: 26 June 1989, 14:49:53 EST
>From: WMLBTAM at UCCCVM1
To: INFO-MAC at SUMEX-AIM.STANFORD.EDU
I've had a couple of questions raised about SoftPC after my last missive to
the net, so I thought I'd summarize here in case others were interested.
Al Best asked about 8088/80286 emulation, >640K/EMS/EEMS/RAM disk, and
HDFD drive support.
SoftPC is 8088 emulation only. There is no mention in the manual of any
mechanism for installing E/EEMS or RAM disk software but it might be fun to
try! In version 1.3, the HDFD >ISNOT
Subject: Public domain TeX for the Mac exists!
In digest #107, Matthew Wall mentioned the search for a p. d. MacTeX. Thanks to
Andrew Trevorrow, it now exists and is called OzTeX.
OzTeX includes a previewer, a PostScript driver, the CMR fonts in the standard
sizes and font metrics for the LaserWriter builtin fonts. It also includes a
userguide (written in LaTeX) and the source code (in MODULA 2).
OzTeX was developed on a 1M Mac+ running the finder. But it runs happily on a
Mac II under multifinder, if you tell the multifinder to give it enough memory.
The preview display on a big screen is excellent and the fonts are well tuned
for printing on the LaserWriter. The userguide mentions transfering DVI files
>From other system, so you should be able to use OzTeX to preview DVI files
created on a different machine. Using OzTeX is straightforward if you know TeX
- the fun of using the Mac! I don't think our secretary wants to go back to
using the VAX
OzTeX doesn't have an integrated editor, so you have to use either a DA, like
the included \Sigma edit, or use your favourite editor/wordprocessor.
I don't know who does the re-distribution of OzTeX in the US or other areas.
For UK users, OzTeX is available from the ASTON TeX archive. Or send 10
unformatted disks and return postage to
Peter Abbott
Computing Service
Aston University
Aston Triangle
Birmingham B4 7ET
-- Lukas
Lukas Nellen @ eMail from the UK:
Department of Theoretical Physics @ NELLEN @ UK.AC.OX.PH.V1
1, Keble Road @ from the rest of the world:
Oxford OX1 3NP @ NELLEN @ V1.PH.OX.AC.UK
Date: Mon, 26 Jun 89 17:21 N
Subject: Rappaport plug
Hi Mac people,
In this list there was a note on the Rappaport plug which
enables your Mac read MS-DOS files just by attaching it into
the external drive port of the Macintosh.
I would like tohear of your experience on this product, can it
do the job properly? Any comments are appreciated, if there are
enough responses I will summarize to the list.
I think there was a mention of the converter for Mac to remove
the extra spaces from files transferred from VAX. Is it in Info-Mac
files? Again, replies are more than wellcome.
Mikko Lammi
Finland
Date: Mon, 26 Jun 89 09:50 GMT
Subject: Search for a decent lib program for Absoft Fortran 2.4
To all Absoft Fortran (version 2.4) users:
I am developing huge fortran programs for use in experimental
physics (data aquisition, analysis, fit, plot etc. programs).
These programs call a lot of subroutines for grafics, analysis
and I/O control which are common to all those programs.
I have around 200 of such common subroutines. The easiest way to
do development is to make a real library of those 200 subroutines
(like on the vax) and link them with the individual programs.
The problem I have is that the supplied lib program on the ABSOFT
distribution is awfull. One has to type every from the 200 names
and should nowere make an error or one has to start over again.
Moreover, I need to do the work twice since we use MacSE's and
MacII's, so a library with and one without floating point use.
The question: does somebody know if there exists a lib program
that either accepts commandfiles or wildcards and of course still
deliveres libraries usable with Absofts link program.
If so please notify me and if possible send me the program in
binhexed or stuffitted way or tell me where to buy it.
Thanks.
mail adress: [email protected]
C.T. de Laat
Fysisch Laboratorium
Rijks Universiteit Utrecht
princetonplein 5
Utrecht
Date: Mon, 26 Jun 89 08:18:03 EDT
Subject: Spell Checker for HC
This is kind of a cludge (sp?), but it works for me.
First, get all the fields into a file
on spellCheck
go to card 1
put "TheFields" into fName
open file fName
repeat with y = 1 to the number of cards
repeat with x = 1 to the number of bg fields
get bg field x
write it & return & "c'" & return to file fName -- C ced. or whatever
end repeat
go next card
end repeat
close file fName
end spellCheck
Now you spell check the document, and reverse the above script (I use the
fileName XCMD. Use your favorite in its place).
on endCheck
go card 1
put fileName("TEXT") into file fName -- Choose the file "TheFields"
open file fName
read from file fileName until "c'"
put empty into the last char of it -- kill "c'"
put it into bg field x
read from file fName until return -- kill extra return
end repeat
go next card
end repeat
close file fName
end endCheck
This is fast and effiecient, and works wonderfully under MF.
MikeA
