Info-Mac Digest V7 #87
Path: utzoo!attcan!uunet!husc6!bloom-beacon!tut.cis.ohio-state.edu!ucbvax!SUMEX-AIM.STANFORD.EDU!Info-Mac-Request
Subject: Info-Mac Digest V7 #87
Date: 13 May 89 00:12:53 GMT
Lines: 392
Info-Mac Digest Fri, 12 May 89 Volume 7 : Issue 87
6.0.3 again
[DCGQAL]GER.XSE0010!Windows 2.0
A Testing of HP Driver.
BinHex 5.0
Designer Draw
Excel-openable files (double-clicking)
Foghorn Leghorn sounds
Hard Drive Access
ImageWriter LQ
MacBinary and BinHex 5.0
Scanning, Character Recognition
Virtual Memory for the Mac (Pmmu and multifinder)
Date: Fri, 12 May 1989 15:32:20 CDT
Subject: 6.0.3 again
Ok, I know those of us without an SE/30 or a Mac II(c)x don't *need*
System 6.0.3, but is there any *harm* in using it? We the System Upgrade
program and I know some users are going to want to get 6.0.3 just
because it's new and and free (to them). I will probably be the person
administering the program. Should I discourage users who don't need
6.0.3 from using it? Thanks,
=--> CB Lih
Date: Thu, 11 May 89 12:20:36 PDT
Subject: [DCGQAL]GER.XSE0010!Windows 2.0
Windows 2.0
Copyright 1988,89 Joachim Lindenberg, Sommerstrasse 4,
7500 Karlsruhe 1, West Germany. All rights reserved.
Windows is an INIT/control panel extension that will add a windows menu
to the finder and other applications. You can configure the running
applications (and this is the big improvement in comparison to 1.x)
in the control panel.
(For the curious programmer: Windows does not know about Multifinder)
Windows is shareware. If you like and use it, send me $10.
International users: Send your check, turning it into cash
costs me $ 0.30.
Joachim Lindenberg
[Archived as /info-mac/cdev/windows-20.hqx; 27K]
Date: Fri, 12 May 89 16:19:50 EET
Subject: A Testing of HP Driver.
Hi Guys, here we have some GOOD news...
Frustrated to use only Apple's own low-quality
or high-priced printers? Why don't you switch to
HP DeskJet or LaserJet. Now this is possible for
all Mac users, because a FREE driver software seems
to work with the most applications of Mac.
Disadvantages?
-Terrible SLOW with the highest quality output mode
(300 dpi, 5-10 min/page) and
-not compatible with the applications written by
"weird programming methods". For this I can say
that I have been able to demonstrate problems
with Word (3.01, my favourite, sigh) text editor
and HyperCard (another sigh). The available document
lists a quite comprehensive list of other unworking
applications.
-Minor problems with the Finder when trying to tell
for application the using of LaserJet mode (eq you
have to check the corresponding box BEFORE
starting the application),
-possible bigger problems with MultiFinder (haven't
tried YET).
-Finally, I did NOT get it work with other speed
than at the 19200 baud via serial line between Mac
and LaserJet, although the driver program includes
selection button for 1200 and 9600 baud speeds. My
printer just returned magical error code 40.
Advantages?
+The price of HP DeskJet Professional is about 900
and the quality is said to be "uniformly excellent
and stood up against that of most laser printers".
My tests have been done by using HP's LaserJet.
+No problems when trying MacWrite, WriteNow, and a
couple of other programs. Again, the documentation
lists more tried applications.
+The C source code of program is available and it
could serve as a base when wanting to write your
own driver for different printer or improve this
one.
A conclusion: A high-quality output with ALL the graphics
you believe to need does not have to be expensive any more -
more work is needed to make it functioning under MultiFinder
and all Mac applications.
Still, folks: it works and that is great.
J.Santara
Computing Centre
Turku university
Finland
[This is the driver which I put in the archives recently. I believe it is
in the util directory. -Bill]
Date: Fri, 12 May 89 11:46 EST
Subject: BinHex 5.0
>Date: Thu, 11 May 89 17:12:48 PDT
>From: [email protected]
>Subject: MacBinary and BinHex 5.0
>I downloaded the program "MacBinary" thinking that it probably
>did the same thing as "BinHex 5.0" which has been around for
>years and still works just fine. After testing out both programs,
>I came to the conclusion that they do indeed do the same thing. I
>wonder why Greg Smith went to all the trouble of writing
>MacBinary when BinHex 5.0 was already available?
Is MacBinary Free? BinHex 5.0 is Shareware.
Tom Blake
Date: Fri, 12 May 89 12:51:14 PDT
Subject: Designer Draw
It turns out that the shareware version 1.0 of Designer Draw (April 1987)
works fine on a Mac Plus, SE, or SE/30, but will not work on any Mac II
series machine. I suspect the problem is related to the bigger screen.
We have tried it set at 1 bit video, but you still get the error message
"not enough memory to complete this operation" right after leaving the
title page. Turning the instruction cache off doesn't help, and we're not
running under MultiFinder. Could anyone suggest some possible fix, or is
there a newer shareware version of this program?
Date: Fri, 12 May 89 13:55:12 EDT
Subject: Excel-openable files (double-clicking)
Someone (I forgot who) wanted to know how to make the files
their program produces double-clickable (automatically opening
Excel).
The answer: when you write the file to disk, make sure the Creator
code is "XCEL". Since Excel reads the files already, I suspect the
type code (XLBN) is already correct.
No, I don't remember how to do this--I think there's a call called
SetFileInfo or somesuch. (I'm not a Mac programmer yet, for lack
of time.)
* Chris "Data" Davis ! BITNet: [email protected] ! NCC-1701D *
* Student Consultant ! InterNet: [email protected] ! ___ *
* Boston University ! [email protected] ! ---===========--- *
*---------------------+---------------------------------+ o \|/ o *
* DISCLAIMER: I said it and nobody else is responsible. ! `--' *
* "You all look like happy campers to me." -Dan Quayle ! *
Date: Thu, 11 May 89 14:18:57 EDT
Subject: Foghorn Leghorn sounds
The enclosed file contains several lines from Warner Bros cartoons featuring
Foghorn Leghorn. Enjoy. Unfortunately this will be the last series of
sounds I'll be able to post for a while since I'll be graduating from S.U
on May 14th.
Douglas J. Hill - [email protected]
RSDJH@SUVM [ BITNET ] or
User #1 at Europa BBS (315)-426-8092
[Archived as /info-mac/sound/foghorn-leghorn-various.hqx; 192K]
Date: Fri, 12 May 89 12:59:46 PDT
Subject: Hard Drive Access
Is there a freeware or shareware program around that will make a
hard drive unmountable if a person boots a machine with their own
floppy? If so, using that along with Lockout 2.0 would provide
pretty good security.
I know that you can use some device-dependent driver when setting
up some hard drives that will render the drive unmountable unless
you have that particular driver on the floppy boot disk, but I'd
rather have something that I can install after the fact.
Date: 12 May 89 15:32:18 GMT
Subject: ImageWriter LQ
Apparently, it was Apple's original intention to
replace only LQs with demonstrable problems.
However, they have been deluged with replacement
requests and apparently decided to replace all.
The result is an indefinite backup. Whereas I
was told originally that I'd have my replaced
LQ within a week, I've now been waiting for
six weeks with no end in sight. I talked to
Apple Customer Service yesterday, and they
make no prediction on how long it would take.
They advised me to get my LQ back and wait
until my dealer has the new one in hand. (I
would if I didn't do most of my work on a
laserprinter.)
My information comes from Apple or from what
Apple told my dealer (actually the university).
Steve Goldfield
Date: Fri, 12 May 89 10:57 EDT
[email protected] writes:
I haven't been able to get ahold of BinHex 5.0, yet, but I'll take your
word for it that BinHex also decodes MacBinary data files. The reason I
bothered to write MacBinary was that we only used BinHex 4.0 here when we
DID use BinHex. Usually, we just use StuffIt to unBinHex files, or mcvert
on our Unix box. The problem was that some of us used NCSA Telnet 2.1 to
download unBinHexed files, and that program didn't yet know how to handle
MacBinary format. I wrote MacBinary to address this need, not knowing about
BinHex 5.0's extra ability. I posted it because I had seen references from
other people with needs similar to mine. I thought that they might benefit
>From what I had done, rather than having to re-invent the same wheel that I
had re-invented. ;-) NCSA Telnet 2.2 has just come out and it understands
the MacBinary format, making MacBinary 1.0.1 even less necessary. That's
the nature of the Macintosh world, though. There is always something better
on the horizon, or already available.
| Greg Smith | BITNET: [email protected] |
| Systems Analyst | [email protected] |
| Bucknell Computer Services | Internet: [email protected] |
| Bucknell University | [email protected] |
| Lewisburg, PA 17837 | AT&Tnet: (717) 524-1801 |
Date: Wed, 10 May 89 05:40 EDT
Subject: Scanning, Character Recognition
Date: Sun, 7 May 89 16:36:27 -0400 (EDT)
I would like to transform a large amount of printed data into a text
file.
Does anyone have experience with scanners and character recognition
software ?
Any suggestions would be appreciated.
Thanks, Nikos
I've used a program called READ-IT
Vendor: (from the about box)
OLDUVAI Corporation
7520 Red Road Suite A
South Miami, Florida 33143
Tel: 305-665-4665
I've used it some, trying to understand when it might be useful. My
impression is that if you have a lot of text in one font (for instance a
book or at least many pages) then it might be useful, but only when
scanned at a reasonably high resolution. I've used it at 300 dpi from an
apple scanner, and found that after training it for a while, It started
to do ok, but not perfect. The reason that you want a reasonably large
text is simply that there is an overhead associated with training the
thing for your font, if it is not one of the ones supplied. I suspect
that no matter what you will still be left with some editing to fix it
up. You may want to give it a try. If you have further questions, you're
welcome to give me a call at 617-253-0608.
-alan
Date: Wed, 10 May 89 03:39 EDT
Subject: Virtual Memory for the Mac (Pmmu and multifinder)
Date: Mon, 8 May 89 23:53 EDT
One submitter asked about the use of the PMMU and virtual memory for the
Mac.
Connectix has written a virtual memory INIT which makes use of an installed
PMMU to give up to 8 megabytes of usable memory, irrespective of how much
RAM is physically present.
Apparently their product has problems with certain DMA devices or boards
which access RAM directly- this access does not go through Memory
Manager trap routines and thus cannot be handled by system software.
John Jamison [email protected]
- I have no affiliation with Connectix, etc.
If you order this product, then I suggest you first request, if
possible, an evaluation copy, if you are depending on you favourite
program running correctly. A while ago I tried this with Allegro Common
lisp and found that it did not work. As I soon after upgraded with real
memory, I abandoned the project.
I did use it with multifinder and a number of other mac applications, so
I don't mean to imply that it is likely that your application won't
work. Also, I have heard good things about Connectix support, and
responsiveness in fixing bugs and imcompatibilities. The intention of
this message is just to warn you it is possible that the connectix
product doesn't work with all software
-alan
