Subject: Info-Mac Digest V7 #21
Date: 1 Feb 89 01:26:52 GMT
Sender: [email protected]
Reply-To: [email protected]
Lines: 394
Approved: [email protected]
Info-Mac Digest Tue, 31 Jan 89 Volume 7 : Issue 21
6.0.3 Change History (Official)
Adobe Fonts
Custom palette offscreen example
draft memos
Gatorbox
INIT 29 further information and corrections
Local Talk connections
Mac Irma
PD PSsend
Retry: Tecmar Drive Magic: Avoiding Reformatting
Please send articles and binaries to [email protected].
Send administrative mail to [email protected].
Date: 31 Jan 89 02:30:47 GMT
Subject: 6.0.3 Change History (Official)
The following is a copy of a document shipped to developers
describing the changes to System Software 6.0.3. You will notice
that only the System file, Responder, and AFE files are changed.
United States Macintosh System Software 6.0.3
Change History
Revision Dates: December 23, 1988
Copyright (c) Apple Computer, Inc. 1988. All rights reserved.
Introduction
This document summarizes the changes made to the United States
Macintosh System Software 6.0.2, since it's release in release in September,
1988.
The United States Macintosh System Software 6.0.3 release is primarily a
maintenance release and a bug fix for the Apple File Exchange. In addition it
provides a hook to support 32 Bit Color QuickDraw, and fixes problems in the
AppleTalk Manager and the Time Manager.
[Archived as /info-mac/tech/system-603-changes.txt; 9K]
Date: Tue, 31 Jan 89 14:58:41 EST
From: steinmetz!galactica![email protected] (Jeff A. Hallett)
Subject: Adobe Fonts
Here is a summary of the process as outlined in the document I made
reference to in my last posting. The full version can be obtained on the
CompuServe Adobe Forum under the title of INVFNT.TXT.
-------------------------------- 8
Subject: Custom palette offscreen example
Here's a six-file example from Apple of drawing a PICT into an offscreen pixmap
with a custom palette, and copying it to the screen, written in MacApp (#8
below). It's on AppleLink, in the directory Developer Services/Developer
Technical Support/Macintosh/Sample Code/SC.008.FracAppPalette.
Descriptions of the graphics programs:
This is a series of sample programs for those doing development
using Color QuickDraw. Since the whole color problem depends
upon the exact effect desired, there are a number of answers
to how to use colors, from the simple to the radically complex.
These programs try to cover the gamut, so you should use
which ever seems appropriate. In most cases, use the simplest
one that will give the desired results. The compatibility
rating is from 0..9 where low is better. The more known risks
there are the higher the rating.
The programs (in order of compatibility):
SillyBalls:
This is the simplest use of Color QuickDraw, and does
not use the Palette Manager. It draws randomly colored
balls in a color window. This is intended to give you
the absolute minimum required to get color on the screen.
Written in straight Pascal code.
Compatibility rating = 0, no known risks.
FracAppPalette:
This is a version of FracApp that uses only the Palette
Manager. It does not support color table animation
since that part of the Palette Manager is not sufficient.
The program demonstrates a full color palette that is
used to display the Mandelbrot set. It uses an offscreen
gDevice w/ Port to handle the data, using CopyBits to
draw to the window. The Palette is automatically
associated with each window. The PICT files are read
and written using the bottlenecks, to save on memory
useage.
Written in MacApp Object Pascal code.
TubeTest:
This is a small demo program that demonstrates using the
Palette Manager for color table animation. It uses a
color palette with animating entries, and draws using the
Palette Manager. There are two circles of animating colors
which gives a flowing tube effect. This is a valid case
for using the animating colors aspect of the Palette Manager,
since the image is being drawn directly.
FracApp:
This is the commercial quality version of FracApp. This
version supports color table animation, using an offscreen
gDevice w/ Port, and handles multiple documents. The
CopyBits updates to the screen are as fast as possible. The
program does not use the Palette Manager, except to
provide for the system palette, or color modes with less than
255 colors. For color table animation using an offscreen
gDevice w/ Port, it uses the Color Manager and handles the
colors itself. Strict compatibility was relaxed to allow for
a higher performance program. This is the most real of the
sample programs.
Compatibility rating = 2. (nothing will break, but it may not
always look correct.)
FracApp300:
This doesn't support colors, but demonstrates how to create and
use a 300 dpi bitmap w/ Port. The bitmap is printed at full
resolution on LaserWriters, and clipped on other printers (but
they still print). It demonstrates how to use a high resolution
image as a PICT file, and how to print them out.
Compatibility rating = 1. (The use of PrGeneral is slightly
out of the ordinary, although supported.)
[Archived as /info-mac/source/apple-color-examples.hqx; 78K]
Date: Tue, 31 Jan 89 21:43 GMT
Subject: draft memos
I would like to make a DRAFT mode for my memos that would clearly label them
as a draft. I once saw a tip (don't know where, don't know when) that would
write the word DRAFT in one inch high, 25% grey letters rotated 45 degrees
on each page of a Word document. As is recall it was only a few lines of raw
Postscript inserted in the Postscript style of Word at the top of the
document. Does anyone recall this procedure, or is wizard enough to just
create it out of hand?
The effect would be something like:
________
!... T !
!... F !
! A !
! R ...!
! D ...!
!_______!
Thanks for your help,
Mike Jones SPAN zodiac::jones
LASP, Campus box 392 INTERNET jones%[email protected]
University of Colorado BITNET jones@cololasp
Boulder CO 80309 phone (303)492-1295
Date: Tue, 31 Jan 89 10:03 CET
Subject: Gatorbox
Hi there|
We have an AppleTalk net with some Mac+s and a LaserWriterII. We also
have an Eathernet with some HP workstations (370 & 340). We should of
course like to be able to use the LaserWriter from the workstations
(including graphics). We would also like to use the disks of the
workstations as fileservers to the Macs.
Does any know if this is possible with Gatorbox or by some other means?
Anders Liljegren, Uppsala University
Date: Tue, 31 Jan 89 08:44:50 -0500
Subject: INIT 29 further information and corrections
There have been a few misconceptions floating around about INIT29 and
how it works. It is quite virulent, spreading at the drop of a hat,
and I don't want to minimize it; but there is a slight bit of
overstatement in what I have read and I want to try to correct it a bit.
1. If you have booted from a clean system (System file and INIT, cdev,
and RDEV type files are all clean), then you are running clean.
Nothing will happen if you put an infected disk in your drive, if you
look at an infected file with ResEdit or copy a file. The ONLY thing
which does damage while you are running clean is to run an infected
application. Doing so will infect your CURRENT System file. That's
all it will do (not that it isn't enough); you will still be running
clean afterward. Rebooting with an infected system file is necessary
before the serious damage starts.
2. Booting from an infected system disk (one or more of your System
file and the INIT, cdev, and RDEV type files IN YOUR SYSTEM FOLDER are
infected) will cause your system to run dirty, i.e. with OpenResFile
patched to infect anything it opens. Now you are in a state when
merely opening any file with a resource fork will infect it with
either an INIT 29 resource (if there is no CODE 0 resource) or with a
new CODE resource (if there is a CODE 0 resource). It is thus true
that merely inserting a floppy disk (under Finder, not necessarily in
applications, which might not cause the Desktop file to be opened) a
copy of INIT29 "infects" the Desktop file on that disk. And any
documents or other miscellaneous files which are opened for any reason
are likely to have an INIT29 written into them. However, the only
significant INIT29's are those written into the System file or into a
type INIT, cdev, or RDEV file in the system folder. In other files
the INIT29 resource is less like an infection than like a benign tumor
-- it takes up space, is neither useful nor harmful, and sometimes
gets in the way of something and causes it to break. [This doesn't
mean that some future virus couldn't activate it somehow.]
3. The only sure way to deal with INIT29 at this moment is to have a
completely clean system on a hardware LOCKED diskette, complete with a
detection tool like VirusDetective. All copies of INIT29 may be
safely removed. All infected applications should be deleted and
restored from locked master disks (you did keep those around, of
course, and locked
programs capable of properly removing the infection from an
application-like file (i.e. has a CODE 0 resource), including Virex;
but I guarantee you there will be one or more available before long.
/JBL
UUCP: {backbone}!bbn!levin POTS: (617) 873-3463
INTERNET: [email protected]
Date: Tue, 31 Jan 89 10:35 AST
Subject: Local Talk connections
Hello,
This is a question passed on to me about problems we've been
experiencing with our AppleTalk network. I really don't know anything
about Appletalk myself, but hopefully any answers will be appreciated
by this third party.
The question is simple : On a Local Talk (Apple Talk) network,
are there any restrictions on the number of notes on the net ? We
have 50 nodes on our net. The limit is supposed to be 32, but is
that number the number of ACTIVE nodes on the net or the number of
nodes hooked up to the net, period ?
Thanks in advance,
Kevin Cassidy
System Operator
Saint Mary's University
Date: Tue, 31 Jan 89 16:10:14 LCL
Subject: Mac Irma
Does anyone out there have any experiences/info on the performance of Mac Irma?
We are currently using Avatar boards with both Mac II's and SE's and are happy
with them, but are interested in examining other alternatives. Thank you for
any information.
Date: Mon, 30 Jan 89 23:52:39 BST
Subject: PD PSsend
Hello,
does anyone know where one can find a PD program that'll send a
postscript file to a laserwriter for printing. Something like PSsend
would seem to be appropriate; is there anything like it in the
INFO-MAC archives? Any info or PD or shareware programs would be
appreciated.
Paul
Paul Sutton |JANET: [email protected]
University Of Bradford |ARPA: pcs%[email protected]
|USENET: [email protected]
Date: Tue, 31-Jan-89 08:29:05 PST
Subject: Retry: Tecmar Drive Magic: Avoiding Reformatting
Whether this is a random occurrance or not, only the Hard Drive Gods
know, but, from time to time, my Tecmar MacDrive becomes confused and seems to
trash its master directory blocks. Usually this means reformatting the
drive. (thanks to religious backups I have not lost any thing, yet...)
Anyhow, last time this happened, the Tecmar Volume Manager software was
giving me it's usual helpful alert messages ("Can't reformat the drive!
Please Contact your Tecmar Dealer for Help (OK)" Ha!) when, in
frustration/desperation, I selected "Reset Print Spooler" from the Volume
Manager menu. Lo and behold, like Lazarus, my data was restored whole and
intact. (Guess the MDB wasn't trashed after all.)
The point is, Tecmar owners (anybody left??), you might try selecting
"reset Print Spooler" before reformatting your drives again next time. Since we
have been able to patch the Tecmar driver resources into all system versions
up from 1.something to 3.2, who knows what kind of magic stuff is coded into
the "Reset Print Spooler" feature...
-wiley
