INFO-MAC Digest V5 #110
Path: utzoo!mnetor!uunet!seismo!rutgers!ames!ucbcad!ucbvax!SUMEX-AIM.STANFORD.EDU!INFO-MAC
Subject: INFO-MAC Digest V5 #110
Date: Sat, 15-Aug-87 00:48:00 EDT
Article-I.D.: ucbvax.8708150528.AA21924
Posted: Sat Aug 15 00:48:00 1987
Date-Received: Sun, 16-Aug-87 07:42:39 EDT
Distribution: world
Lines: 828
INFO-MAC Digest Friday, 14 Aug 1987 Volume 5 : Issue 110
A note from the moderator
FTP access to SUMEX-AIM
Using MACSERVE at PUCC (BITNET)
Usenet Mac Digest V3 #48
Usenet Mac Digest V3 #49
Usenet Mac Digest V3 #50
Usenet Mac Digest V3 #51
Usenet Mac Digest V3 #52
Usenet Mac Digest V3 #53
Usenet Mac Digest V3 #54
Usenet Mac Digest V3 #55
Usenet Mac Digest V3 #56
Usenet Mac Digest V3 #57
Usenet Mac Digest V3 #58
Delphi Mac Digest V3 #33
Delphi Mac Digest V3 #34
Delphi Mac Digest V3 #35
Delphi Mac Digest V3 #36
Delphi Mac Digest V3 #37
Delphi Mac Digest V3 #38
Date: Fri, 14 Aug 87 21:33:36 PDT
Subject: A note from the moderator
Hi,
I'm trying to clear up some of the "archived as ..." messages in my files.
I know as I attempt to do this that I am going to get many requests from
people wanting to know how to obtain these files, so I am including this
note, plus the following help files.
**** please note ****
I cannot send archived files through the mail. If you are not on an
ARPAnet or BITNET host you will have to wait for these files to make
their way onto local bboards or into local user group collections.
The archives at SUMEX-AIM are for those people on the ARPAnet who have
FTP access. The server at PUCC is for those people on BITNET who can
send interactive messages. Right now those are the only two ways to
access the archives that I know about. If I learn of other ways I will
certainly make an announcement in a future digest.
Dwayne Virnau...
Moderator
ps, USENET and DELPHI digests are provided courtesy of Jeff Shulman, a
fact that is probably obvious from the messages themselves but I thought
I would mention it anyway. DoD
Date: Fri, 14 Aug 87 21:39:46 PDT
Subject: FTP access to SUMEX-AIM
Anonymous ftp is supported on SUMEX using the login name "anonymous" and the
password "guest"
Here are examples of ftp from both a dec-20 running TOPS-20 and a vax running
UNIX.
From the Dec-20
@ftp sumex
login anonymous
Password:
FTP>dir 00dir.names
PS:
00DIR.NAMES
FTP>get 00dir.names 00DIR.NAMES
PS:00DIR.NAMES.122 (to local file) 00DIR.NAMES
PS:00DIR.NAMES.122 => 00DIR.NAMES.1;P775202 !! [OK]
FTP>q
And from the Vax:
Navajoftp sumex-aim.arpa
Connected to sumex-aim.arpa.
220 SUMEX-AIM.ARPA FTP Server Process 5Z(40)-7 at Fri 23-May-86 09:48-PDT
Name (sumex-aim.arpa:berner): anonymous
Password (sumex-aim.arpa:anonymous):
331 ANONYMOUS user ok, send real ident as password.
230 User ANONYMOUS logged in at Fri 23-May-86 09:48-PDT, job 47.
ftp> ls 00dir.names
200 Port 4.5 at host 36.36.0.203 accepted.
150 List started.
00DIR.NAMES.122
226 Transfer completed.
24 bytes received in 0.08 seconds (0.29 Kbytes/s)
ftp> get 00dir.names
200 Port 4.7 at host 36.36.0.203 accepted.
150 ASCII retrieve of 00DIR.NAMES.122 started.
226 Transfer completed. 2259 (8) bytes transferred.
2259 bytes received in 0.06 seconds (37 Kbytes/s)
ftp> quit
221 QUIT command received. Goodbye.
Dwayne Virnau...
Moderator
Date: Fri, 14 Aug 87 21:42:50 PDT
Subject: Using MACSERVE at PUCC (BITNET)
I'm very excited to announce that the previously defunct MACSERVE at
BITNIC has been replaced by a new server for BITNET users. This server is
called MACSERVE at the node PUCC (Princeton University). The server
currently matches very closely the current info-mac archives. Bitnet users
who were frustrated to find that they did not have access to the info-mac
archives now have a means to access those files. Bitnet users will also be
glad to know that work is also going on elsewhere, so it is possible that
in the near future there will be another site which supplies this service
as well. Use it in the best of health and let's have 3 cheers for those who
brought it to us: the people at PUCC!
Macserve is pretty simple to use. Send an INTERACTIVE message over bitnet
which consists of either DIR or GET . From my system the usage
is as follows:
To have a directory of files sent to you:
TELL MACSERVE AT PUCC DIR
To fetch a given file such as the file ANIMATION-NOTES.TXT use
TELL MACSERVE AT PUCC GET ANIMATION-NOTES.TXT
Note that this works for a VM system and may be different for yours. In
any case the part of the commands above which are system dependant are
so that if your system requires something different in order to send
messages to a remote user then you should substitute the appropriate
stuff.
A file will be sent to you and it may have a name different than the
name you requested (such as 870312 0000001). Don't worry, this is the
file you requested.
I must mention that there are two caveats with regard to the
implementation of this server. First of all, since the server was
originally built for use within Princeton it sends its files in an IBM data
format called NETDATA. This format is easily readable by IBM machines
(using for example the RECEIVE command). Other systems may not easily be
able to convert this format back to standard TEXT file formats. Consult
your local experts to determine if this presents problems for you.
The second point is that you MUST send interactive messages to this
machine, mail will NOT cut the mustard. Please do not send messages to the
infomac moderator OR PUCC asking how to do this if you cannot send
interactive message to users on other BITNET nodes.
We expect that other servers which are being brought up will address
both of these shortcomings of the PUCC server. They should accept both
interactive and mail messages and should provide the files in a format
acceptable for the machine you are requesting from.
NOTE: PLEASE DO NOT DIRECT QUESTIONS ABOUT MACSERVE USAGE TO ME. I'M
ONLY RELAYING THIS INFORMATION TO THE INFO-MAC COMMUNITY AND AM IN NO WAY
RESPONSIBLE FOR THE MAINTAINENCE OF MACSERVE.
(this information is courtesy of David Gelphman, former info-mac moderator)
Dwayne Virnau...
Moderator
Date: Wed, 1 Jul 87 08:58 EDT
Subject: Usenet Mac Digest V3 #48
Usenet Mac Digest Tuesday, June 30, 1987 Volume 3 : Issue 48
Re: Question: Finder Windows & Mac II Screens
Re: Mac+ SIMMS in Mac II (be careful)
True Mac+ Compatibility in Upgraded Macs
Paragenesis Schematic Entry pkg on Mac II
MOVE command from finder
need serial driver help
SIMMS in Mac II
C++ on Mac -- any updates in status?
Mac SE Slow Upper Drive
Aztec C Problems
Printer drivers for daisy wheel printers...
Re: SIMMS in Mac II
Re: Mac SE Slow Upper Drive
Re: Where can I find info on Graf3D?
Whither IM ? and a call for feedback
Re: SE mouse problems
Help needed with text + Excel
Re: C++ on Mac -- any updates in status?
Re: Whither IM ? and a call for feedback
MPW 2.0 inquiry
Re: Mac ][ First Impressions...
Re: MPW 2.0 inquiry
uucp
MAC+ librarian for ESQ-1?
I need Window Help
Re: Help needed with text + Excel (w/ binhex'd example)
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-48.ARC
DoD
Date: Wed, 1 Jul 87 08:59 EDT
Subject: Usenet Mac Digest V3 #49
Usenet Mac Digest Tuesday, June 30, 1987 Volume 3 : Issue 49
ADB Keyboard Key Code Info Request
Question on Keycaps
Is switcher 5.1 right for an SE running system 4.1 & finder 5.5?
Folder Security
Re: ADB Keyboard Key Code Info Request
MacII plotting
Greek Accents
Re: Smalltalk on the SE
Alternate sounds on Mac Plus?
Bibliography software query
MacPlot
Looking for Information about Macintosh Databases
Mouse Unfreezing
Not all code segments accessible from Resedit (1.1d)
Re: AppleShare
Magic 30 HD vs System 4.1
Kudos to SuperMac on Enhance Upgrade
Simple digital input interface needed
When do 40SC extern. disks ship?
Re: Networking software
Re: Dear Apple: Finder feature wanted
Re: Not all code segments accessible from Resedit (1.1d)
MacBottom 20 and System 4.1
Dental Office Software needed!
SE fan (noise)
MacPlus keypad
Apple II emulators for the Mac
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-49.ARC
DoD
Date: Wed 8 Jul 87 09:02:35-GMT
Subject: Usenet Mac Digest V3 #50
Usenet Mac Digest Tuesday, July 7, 1987 Volume 3 : Issue 50
Re: Bibliography software query
ImageWriter-compatible printer
Re: Finder Feature
stdin in MPW Pascal
MaM Test (Memory test) on Mac II?
Re: 32-bit Mac II OS (was: SIMMS in Mac II)
DiskTimer II results on Mac II HD40
FWB's Hard Disk Partition
Help on SetIText
Re: FWB's Hard Disk Partition
Ada on Macs
PC compatibility questions [was Re: Mac SE running IBM]
Are there "SIMM-like" PC boards?
Hot Tip: Knob for LaserWriter
Re: better patch Rogue Clone
Custom Characters for LaserWriter
Does there exists old style mac keyboard -> ADB adapter?
Re: Turbo Pascal...
Re: Mac --> Ethernet --> VAX
Kinetics and tcp/ip
Bug in LaserWriter Driver/LaserPrep 4.0
PROLOG/M from Chalcedony Software
Question on HP ThinkJet with a Mac +
Guide question
Dove MacSnap 2 Megabyte+SCSI upgrade: comments from a hardware klutz
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-50.ARC
DoD
Date: Wed, 8 Jul 87 09:05 EDT
Subject: Usenet Mac Digest V3 #51
Usenet Mac Digest Tuesday, July 7, 1987 Volume 3 : Issue 51
Large Memory: How do you use it? (summary)
Drawing Lines in Dialogs
Terror Stalks the Soul of a New Machine
background printing question
Rogue Clone font
Sun monitor on Mac??
Re: Turbo Pascal...
report on the 'Software Entwickler Konferenz 1987' in Germany
Macs and PClones in the same office
Re: Software for Mac II
Re: Terror Stalks the Soul of a New Machine
Help with Vertical Retrace Queue
Hyperdrive V3R1 + Sys 4.1/Finder5.5 -- compatible?
Re: Imagewriter Alternatives
Bombs trying to low-level print via AppleTalk
vbl queue
Re: Taking a Mac to Europe
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-51.ARC
DoD
Date: Tue 14 Jul 87 08:57:46-GMT
Subject: Usenet Mac Digest V3 #52
Usenet Mac Digest Monday, July 13, 1987 Volume 3 : Issue 52
Control Panel vs. Chooser
female 8-pin mac connectors?
Levco-Expercommon Lisp incompatibility
Re: Borland's Turbo Pascal
Re: Control Panel vs. Chooser
Do US Imagewriters work in Europe and Japan?
low-price hard disk question
More on Dove MacSnap upgrade
Re: turning off the stack sniffer (long)
TextEdit problem (2 messages)
System 4.1/SCSI Bernoulli
Unidentified Bomb ID
HyperDrives and system 4.1
APDA and 800k floppies
Re: Drawing Lines in Dialogs
Changing heap size
Printing Question (background Idle procedures)
hard disk security
Re: Printing Question (background Idle procedures)
possibility of mac video board
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-52.ARC
DoD
Date: Tue 14 Jul 87 09:00:52-GMT
Subject: Usenet Mac Digest V3 #53
Usenet Mac Digest Monday, July 13, 1987 Volume 3 : Issue 53
Re: possibility of mac video board
Robot War on the Mac
Help with PostScript output on remote printer
Re: Do US Imagewriters work in Europe and Japan?
Floating figures in Word?
Re: Unidentified Bomb ID
Re: APDA and 800k floppies
EditText Item help
ROM Version & Machine Type
Re: More on Dove MacSnap upgrade
MAC II plotter drivers
Feedback on BB's wanted
How do I write a Guided Tour (2 messages)
Letter-quality printers
Debugging frozen mouse problem
Re: How do I write a Guided Tour
Re: ImageWriter-Compatible Printer
Coral Lisp???
Screen snapshot ROM bug not fixed
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-53.ARC
DoD
Date: Mon 27 Jul 87 10:41:24-EDT
Subject: Usenet Mac Digest V3 #54
Usenet Mac Digest Thursday, July 23, 1987 Volume 3 : Issue 54
VIA chip and msec timer
SE fan noise, a solution!!
Faraglace Story (long)
Mac II and SANE...
Statistics, Equations, Editors
Re: Window Manager problem (2 messages)
Re: Statistics, Equations, Editors
Mac II Horrors, Continued
Re: optimal paper for laserwriter?
"The Ancient Art of War" (A Question)
Programs That Bomb Under System 4.1
Why is A/UX disk I/O only 50KB/sec?
JClock INIT
Anchor points and Arrow keys
Programs for children with Down's Syndrome
Re: Mac II and SANE...
Re: Why is A/UX disk I/O only 50KB/sec?
Re: Sun monitor on Mac??
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-54.ARC
DoD
Date: Mon 27 Jul 87 10:53:49-EDT
Subject: Usenet Mac Digest V3 #55
Usenet Mac Digest Thursday, July 23, 1987 Volume 3 : Issue 55
Mac II Horrors are Over!!
Re: Anchor points and Arrow keys
Color Plotting?
Info+ INIT doesn't work under System 4.1
Arrow keys and collapsing selections
New MacDraw release
What ever happened to DBase Mac?
Touch Screen System for the Apple MacIntosh
SE display bug survey results (medium long)
Summary of Mac MIDI responses
mouse diode needed
3D Surface plots
Response to 'Bug in Hard Disk SC Drivers?'
Re: Window Manager problem (perhaps even a bug)
Re: Serial printer drivers
Hardware in a Jasmine 20?
MicroEMACS bulletin, Mac sources to be in 3.9
Re: HP Laser printer for the Mac II ?
Hard Disk Backup Software
Mac II NuBus Specifications
Apple 1200 modem problem
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-55.ARC
DoD
Date: Mon 3 Aug 87 10:02:55-EDT
Subject: Usenet Mac Digest V3 #56
Usenet Mac Digest Saturday, August 1, 1987 Volume 3 : Issue 56
Finder Feature (or bug)
Help!!!
PopUp menus
ImageWriter Compatable Printer
VBL tasks and LSC
Precision Timing on Macintosh?
"Ruggedized" Mac II?
Re: Home upgrade of Mac II video?
Re: PopUp menus
Hard Disk Servers and Minis
MacWorks version 3 and HFS
HFS Query
anyone got a Laotian font for Macintosh?
Bibliographic software query - summary of responses
Does anyone REALLY understand SCSI Booting?
Problem with Diskfit 1.1df
Re: Bibliographic software query - summary of responses
Re: HFS Query
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-56.ARC
DoD
Date: Mon 3 Aug 87 10:04:00-EDT
Subject: Usenet Mac Digest V3 #57
Usenet Mac Digest Saturday, August 1, 1987 Volume 3 : Issue 57
Re: Problem with Diskfit 1.1df
Re: HFS Query (Why PBHSetVol is Dangerous)
Re: Does anyone REALLY understand SCSI Booting?
Memory Usage on Mac+
Finder suggestion
Bug in Levco products
Re: A/UX filesystem performance
Maps on the Macintosh
Laserwriter naming funny business
CMS brand Quantum 80 Mbyte drive for MacII
List Manager in MacApp Dialog
Re: PopUp menus
macros and Microsft Word, *roff on Mac.
Function Keys on Apple Extended Keyboard
Placement of external drive
Re: Finder suggestion
Eject menu selection
Mac II Games
Summary of Making *OWN* SCSI Drive (Rather long)
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-57.ARC
DoD
Date: Sat 8 Aug 87 12:01:55-GMT
Subject: Usenet Mac Digest V3 #58
Usenet Mac Digest Saturday, August 8, 1987 Volume 3 : Issue 58
DiskExpress -- it's supported as ok...
Mac lab for High School environment??
Alternate font for RogueClone
Macsbugs->Shutdown Manager
Can the KX 1080 printer be used outside the US ?
How big should the system heap be?
Another Finder suggestion
Re: Making *own* SCSI Hard Drive
Re: Another Finder suggestion
Re: PopUp menus
cdev
Print quality (Delphi 3 #35)
1-meg SIMMs
TENew & StdTxMeas (2 messages)
Re: Drawing in Technical Environment
simple question
Re: Mac software under A/UX
Re: simple question
Inside TOP ? it
SFgetFile (or whatever) suggestion
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-58.ARC
DoD
Date: Thu, 2 Jul 87 10:17 EDT
Subject: Delphi Mac Digest V3 #33
Delphi Mac Digest Thursday, July 2, 1987 Volume 3 : Issue 33
CMS PRO-40-SE/i (6 messages)
TOPS Network ( Good or Bad News ? ) (2 messages)
Mac II Utilities
Mac II windows (2 messages)
CloseOrnHook (4 messages)
Dvorak & Sys 4.1/5.5
Ahh Color..
debugging as art (2 messages)
Mac II Err 28 (2 messages)
INITs (2 messages)
Mac II Serial Port (3 messages)
Software needs (2 messages)
SOFTSOFTWARE INQUIRY (2 messages)
Video on Mac II (3 messages)
Datadesk mac101
SE internal 20 address
quiet SCSI drives (2 messages)
Debugging in C
re: Spell checkers for Mac
Re: ChemDraw et al
Re: Sailing and Basic
Jump!Board020 (3 messages)
Excel Array/Macro Question
Formatting XL/HFS (2 messages)
Centering on Big Screens (2 messages)
ListMgr and Changing Fonts Question (2 messages)
archived as [SUMEX-AIM.Stanford.EDU]DELPHIV3-33.ARC
DoD
Date: Tue 14 Jul 87 08:52:27-GMT
Subject: Delphi Mac Digest V3 #34
Delphi Mac Digest Tuesday, July 14, 1987 Volume 3 : Issue 34
Appletalk Problem
RE: Aztec C Problems
Looking for A/B box
Habadex - Is it still out there anywhere
Color Monitor for Mac II
Switcher vs. System 4.1 (3 messages)
RE: Mac II Speed
Anyone with Reflex? (2 messages)
Microtek & Versiscan (3 messages)
mac II interlace video (4 messages)
DEC LA50 Driver
Compatibility problem LSP - MPW Pascal
SE keyaboard and boot problems
Re:Custom Characters for LaserWriter
A couple of Quickies... (2 messages)
CD ROM DRIVES (3 messages)
B&W Monitor (2 messages)
RE: ImageWriter-compatible printer
laser writer paper (2 messages)
re: Sun monitor on Mac??
PageMaker
4th Dimension (3 messages)
Quantum drives for Mac II
Do the PostScript strech... (3 messages)
SCSI Bernoulli boxes (2 messages)
Camera on the Macintosh II
Print Screens on Mac II (3 messages)
archived as [SUMEX-AIM.Stanford.EDU]DELPHIV3-34.ARC
DoD
Date: Mon 27 Jul 87 10:56:46-EDT
Subject: Delphi Mac Digest V3 #35
Delphi Mac Digest Friday, July 24, 1987 Volume 3 : Issue 35
Fortran 77 + 68881 for the Mac II (3 messages)
RE: Using assembly language with MicroSoft FORTRAN
RE: Do the PostScript strech... (3 messages)
re: Control Panel vs. Chooser
Selecting print quality (3 messages)
SE video problems
Re: Re: Control Panel vs. Chooser
Re: Debugging frozen mouse problem (2 messages)
Lisa (what's that?) hard disks
RE: Mac II Beep SND
RE: Region structure? (3 messages)
synching to vidoo blanking (2 messages)
Deactivating statictext (4 messages)
Looking for an FKEY...
Mac II w/multiple video cards
color picker (2 messages)
PageMaker 2.0 "features" (2 messages)
SoundWave
NEW Bernoulli drives
RE: equation composers
re: Arrow keys and collapsing selection
edititem disable (2 messages)
cdevs
archived as [SUMEX-AIM.Stanford.EDU]DELPHIV3-35.ARC
DoD
Date: Mon 3 Aug 87 10:05:57-EDT
Subject: Delphi Mac Digest V3 #36
Delphi Mac Digest Saturday, August 1, 1987 Volume 3 : Issue 36
changing pixel depth
RE: cdevs (3 messages)
drawpicture (4 messages)
MacBug 5.3 has new command?
OpenSocket (3 messages)
Raskin vs. Jobs
LaserWriter Plussing weirdness (2 messages)
Colorizing logos
RE: INFO-MAC Digest V5 #107
re: FullWrite Professional
re: slippery mouse? (desk pads / teflon
RE: Mac II horrors
re: Potential Bug??? [menus]
Re: Re: Suitcase and NFNT resources
Re: Bug?
TOPs and pcs and macs and vaxes and suns
RE: TOPs and pcs and macs and vaxes and (2 messages)
re: Site Licences etc. (2 messages)
graphicworks
RE: Anyone driving Compugraphics with Macs
laserjet to laserwriter upgrades
Printing information (4 messages)
Microsoft acquires Forethought
Medical applications of Macintoshes
RE: macexpo
SIGGraph report
archived as [SUMEX-AIM.Stanford.EDU]DELPHIV3-36.ARC
DoD
Date: Sun 9 Aug 87 08:39:02-GMT
Subject: Delphi Mac Digest V3 #37
Delphi Mac Digest Sunday, August 9, 1987 Volume 3 : Issue 37
Mac II monitors
RE: Mac II Color Monitors
It's Greek to me... (2 messages)
800K drive problems (4 messages)
Object-oriented C (3 messages)
Segment Loader problem (3 messages)
Mac II Color Monitors (2 messages)
HardDrive Woes and Wins.
RAM upgrades and accelerators
Word 3.01 bug
Used ImageWriters (2 messages)
User Group Connection party at Expo
1MB SIMMs
printer driver example
Netter's Dinner
archived as [SUMEX-AIM.Stanford.EDU]DELPHIV3-37.ARC
DoD
Date: Fri 14 Aug 87 19:07:52-GMT
Subject: Delphi Mac Digest V3 #38
Delphi Mac Digest Friday, August 14, 1987 Volume 3 : Issue 38
RE: 800K drive problems
RE: Usenet Mac Digest V3 #58
John Sculley Keynote Speech
Jean-Louis Gassee Keynote Speech
archived as [SUMEX-AIM.Stanford.EDU]DELPHIV3-38.ARC
DoD
