Trygve's CMM Plug-Ins 2.0.1
Download: http://archive.info-mac.org/cfg/cmm/try ... ns-201.hqx
These are plug-ins for the MacOS 8 Contextual Menu Manager (PowerPC
only). When you control-click on items in the Finder, a contextual menu
appears, and these plug-ins add new commands to the menu that operate on
the files and folders you clicked.
Version 2.0 simplified the menu organization and added new plug-ins.
Version 2.0.1 fixes a recoverable hang that would occur under certain
conditions.
Here are the plug-ins in this version:
- Convert Text - Converts the selected text files' line endings to Mac,
DOS, or Unix format.
- Cut / Copy / Paste File - Lets you treat files and folders as objects
that can be cut, copied, and pasted.
- Hide / Undo Hide / Show - Hides the selected files and folders. The
previous Hide can be undone. Also lets you show all hidden items in a
folder.
- Lift and Set File Info - Lets you set files' creators and/or types to
the those of other files.
- Lock / Unlock - Locks or unlocks the selected files. Depending on your
access privileges and particular file server capabilities, you can also
lock and unlock folders on a file server.
- Move / Copy / Alias - Lets you move or copy the selected files and
folders to the chosen destination folder or disk. Also lets you make an
alias of the selected items in the destination folder or disk.
- Open With - Lets you open the selected files with the chosen
application.
- Remove Custom Icon - Removes custom icons from the selected files and
folders.
- Set File Info - Sets the selected files' creator and/or type from a
list of choices that you configure by placing files and aliases in the
settings folders.
- Simple Strip HTML - Removes all HTML tags from the selected HTML text
files.
- Touch - Sets the selected files' and folders' modification date to
"now".
More information can be found in the readme file and at the website
listed below. Enjoy!
Trygve Isaacson
