INFO-MAC Digest V5 #85
Path: utzoo!mnetor!seismo!lll-lcc!styx!ames!ucbcad!ucbvax!SUMEX-AIM.STANFORD.EDU!INFO-MAC
Subject: INFO-MAC Digest V5 #85
Date: Wed, 6-May-87 00:16:00 EDT
Article-I.D.: ucbvax.8705060442.AA14190
Posted: Wed May 6 00:16:00 1987
Date-Received: Thu, 7-May-87 06:44:18 EDT
Distribution: world
Lines: 685
INFO-MAC Digest Wednesday, 6 May 1987 Volume 5 : Issue 85
scripting on the Macintosh
Reconstructing Desktop WITH info?
Shutdown/head parking
Scrap Saver INIT
CatMaker
Appletalk, Bussedout, Mazewars no work?
STARTUP SOUNDS
Mac II Video choices?
Re: Mac II is shipping! -- NEC MultiSync and Mac II
Alt Keyboards for 512E?
TOPS on a Mac XL?
Utilization of Bernoulli Box
Laser Disk Labels
accounting programs
Plotters
Seeking TDBMS
AppleTalk RS232
Usenet Mac Digest V3 #33
Usenet Mac Digest V3 #34
Usenet Mac Digest V3 #35
Usenet Mac Digest V3 #36
Usenet Mac Digest V3 #37
Delphi Mac Digest V3 #24
Delphi Mac Digest V3 #25
Date: 4 May 1987, 10:23:57 PST
From: David M. Gelphman 415-854-3300 x2538 DAVEG at
Subject: scripting on the Macintosh
I haven't seen this topic discussed much on info-mac and I sure would
like to hear other's opinions. It seems to me that the Mac user interface
in its current implementation is seriously lacking the capability to
script 'batch' processes, pipe output to different tasks, and create and edit
POWERFUL Macros (Tempo is not powerful or ROBUST enough). It is unfortunate
that these tools (especially Macros) are not part of the system software.
It seems to me that with the introduction of the Mac II, Apple is going
after a market rich in 'power users', and these users will demand more of
the user interface in this regard. Comments?
Bin #88 SLAC ARPANET address: [email protected]
415-854-3300 x2538
usual disclaimer #432 applies: my employer apologizes for the fact
Date: 1 May 1987 11:24-EDT
Subject: Reconstructing Desktop WITH info?
Does anyone know of a program which can recreate a desktop without loosing the
text in the GetInfo box? It seems like it should be easy to get that
information from the old desktop, or at least try.
Rick
Rick Lerner
Computer Science Dept.
Carnegie Mellon Univ.
Pittsburgh, PA 15213
(412) 268-3828
Date: Thu, 30 Apr 87 21:49:19 edt
Subject: Shutdown/head parking
In info-mac 5.83, an anonymous correspondent offers to send
Kamerman Labs actual money for a decent shutdown utility.
There's no need. The following should fill the bill, and comes
complete with source code.
The following BinHex 4.0 / Packit II file contains source code
and executable for SCSI Stop, a shutdown utility. This should
answer the questions about shutdown which were raised in info-mac
volume 5, #57.
This package is in the public domain.
Ephraim Vishniac
decvax!wanginst!wang!ephraim
archived as [SUMEX-AIM.Stanford.EDU]UTILITY-SCSI-STOP.HQX
DoD
Date: Mon, 4 May 87 10:51 EDT
Subject: Scrap Saver INIT
Date: 1-MAY-1987 20:07 by LOGICHACK
[ Updated to version 1.1 1-MAY-1987 20:07 by LOGICHACK. This latest version
(1.1) of 4/29/87 has better error checking for empty Clipboard files and has a
file creator type of 'MACS' so it shows up in System 4.1 and up as a little
Macintosh icon. ]
ScrapSaver is a small utility to read in the clipboard at boot time. This
means your clipboard contents will always be around, even if you reboot or
turn your computer off. This is most useful with System 4.0 and higher
since it writes the scrap file on _ShutDown. To use ScrapSaver, simply
drag it into your System Folder.
Have fun.
Bug reports and comments are should be directed to one of the addresses below.
Paul Mercer
Delphi: LOGICHACK
AppleLink: D0131
MCI: SOL
681 E. Seneca Tpk., #A4
Syracuse, NY 13205
Phone: (315) 492-3348
archived as [SUMEX-AIM.Stanford.EDU]INIT-SCRAPSAVER-11.HQX
DoD
Date: Tue, 5 May 87 09:17 EDT
Subject: CatMaker
Date: 3-MAY-1987 18:37 by WNOLAN
Hard disk cataloging program, source code available (Lightspeed C).
archived as [SUMEX-AIM.Stanford.EDU]UTILITY-CATMAKER.HQX
DoD
Date: Sun 3 May 87 22:26:57-EDT
Subject: Appletalk, Bussedout, Mazewars no work?
I am experimenting with Appletalk trying to get Bussedout or Mazewars
running.
Equipment: 2 Mac Pluses, system software just before SE release
I have tried to get these programs to work and neither does. Using th
debugger, I found that Bussedout passes (get this!) an even pointer when
it should pass an odd one! This was after I had to OpenMPP by debugger
(It apparently did not do that right either). Mazewars has similiar problems.
I have tried several versions of the ATP and MPP drivers (both in the
system and program files).
What I am doing wrong?
Also, what's the story on file server packages for AT. I am looking for
something that doesn't reqqXe a dedicated Mac. Did I hear something
called TOPS or MACSERVE?
Thanxs
5-May-87 16:04:01-PDT,1334;000000000001
Date: Tue, 5 May 87 16:03 PDT
Subject: STARTUP SOUNDS
Hello,
According to the folks who brought us StartUpSounds
(the MacNifty people), a startup sound can only be played
correctly when (1) you have the proper sound INIT installed
in your system, and (2) if the sound file was sampled at
a rate of 22,000 samples per second. Sampling at this rate
will occupy an awful lot of disk space (22K per second I think?),
but I understand that this rate is necessary to insure a high
sound "quality" during playback. I was wondering if anyone knew
if it was possible to patch the INIT resource needed to play the
startup sound so that it would also playback sound files sampled
at a slower rate than 22,000. The MacNifty manual lists 4 different
sampling speeds which it is capable of digitizing sounds (22,000 ,
11,500 , 7,500, and 5,000 samples per second). I would like to be
able to use sounds digitized at 11,500 samples per second as startup
sounds. Has anyone else tried to do this successfully?
Bob Ruderman
Bob Ruderman
Department of Geography
University of Washington
Seattle, Washington 98195
Bitnet: [email protected]
Arpanet: C9017%[email protected]
Usenet: C9017%[email protected]
Date: Tue, 5 May 87 05:54 CDT
Subject: Mac II Video choices?
If the Mac II is indeed shipping, it's about time to get the
scoop on video options. Apple and Supermac both have fine
color systems, but they're a bit pricey, even at developer
rates. Anybody got any info on other vendors? Send to me
if you can and I'll summarize.
scott t. boyd
the machax(tm) group
Date: 5 May 87 11:37:05 PDT (Tuesday)
Subject: Re: Mac II is shipping! -- NEC MultiSync and Mac II
Now that Mac II is shipping, does anyone know if the NEC MultiSync
monitor can be used on the Mac II?
Leonard Li.
Xerox
Date: Sun, 3 May 87 16:18:02 GMT+0100
Subject: Alt Keyboards for 512E?
A while back (several months ago) I saw posting(s) in reference to alternate
keyboards for the Mac512/512E/+. Are these still avaialable? Do they operate
well? Anybody doing conversions to allow SE/II keyboards to be hooked up to
the other Macs? Any info appreciated.
Jay Rolls
BBN Communications
Stuttgart, West Germany
[[email protected]]
Date: Tue, 5 May 87 01:38:41 PDT
Subject: TOPS on a Mac XL?
On the back (or maybe it's the side) of the box of the TOPS product
by Centram Systems, it says that TOPS runs on a Mac XL. I've yet
to figure out how, and I've been trying for weeks. A few details on the
hardware: a Mac XL with 1 Meg Ram, and 10 Megabyte external Profile.
Yes, 10 Megs. Apple replaced the 5 Meg drive with a 10 Meg one last time it
was in for service. We're running without the screen modification.
We WERE running System 3.2, Finder 5.3 on the Mac XL, but ever since the
trouble started, we've had to revert to finder 4.1 system who knows what.
Symptoms: Boot, get Welcome to Mac Message, TOPS installed, InterBase
installed, and then El Bombo with system ID = 10. So I trash TOPS,
install system 3.2, Finder 5.3, and lo and behold, same thing. Then we
go back to the MFS system and finder, and all is jolly. Strange, eh?
More TOPS strangeness: QDial 1.6 and Talking Moose blow up almost
instantaneous while running under TOPS.
So, is anyone out there running TOPS on a Mac XL? Care to share the
secrets? I'm beginning to suspect that TOPS, or the SYSTEM is incredibly
sensitive to what desk accessories, INIT resources, etc. are installed.
Have noticed, for example, that a Mac XL will not boot off a system from
a DataFrame 20 XP drive, while of course a Mac + will do just fine.
By the way, all the systems referred to previously (which bomb on an XL)
run just fine on the Mac. We're running MacWorks 3.0, installed on the
Profile.
Date: Fri, 1 May 87 7:46:38 MDT
Subject: Utilization of Bernoulli Box
I'd appreciate any comments from people who have had experience with Bernoulli
Boxes, or comments in general with respect to what I have detailed below.
1. Equipment - Original 128K machine that has been upgraded with new ROM,
800K drive, and has MacMemory 2 Meg of RAM. No SCSI port added.
2. Situation -
a. I'd like a hard drive, but what I really want is a drive with tape
backup also. However, I don't want to invest that kind of money at this time
as I just might go for a totally new machine in several years.
b. I could buy a Jasmine 20 for approx. $590, but I'm skeptical of some of
these new firms and like to stick with a name brand that I can get serviced
easily, and a firm that will be in business at some point in the future.
c. I'm not what you'd call a power user, and I'm not one of those who has
hundreds of diskettes (maybe a hundred) full of software. My needs are text
editing, data base work, some paint, and remote access to a multiuser micro
system. My young daughter is learning and will probably be a heavy user some
day.
d. Icon Review has been selling the older (serial port) 5 Meg
Bernoulli Boxes for $499, and a pack of three 5 Meg cartridges for $99. I
realize their are limitations with this equipment: you can't boot from it;
it's a bit noisy; it's slower than a SCSI. Their are advantages also with the
method of operation that make then less susceptible to a crash, and the ease of
data security. The thought is to just considered it a 5 Meg floppy and boot
with my RAM disk as I currently do. I could store my applications on the
cartridge and my data on 3.5"disks, and the Ram disk could contain all the
goodies for the desk top. My backup could also consist of a cartridge(s).
3. Questions -
a. Is this a reasonable idea for a modest investment, and an interim
solution? Would it work?
b. Does anybody have any experience with this equipment, good or bad?
4. Please respond directly to me, and if anyone is interested in the results
I'll certainly let you know.
H.C. McCaffrey
White Sands Missile Range, NM
Date: 2 May 1987 23:57-EST
Subject: Laser Disk Labels
Can someone tell me where to get a copy of the MacDraw disk label
described on page 154 of the May issue of MacUser? The article
says the file is available on CompuServe and GEnie, but it doesn't
give the precise locations.
Date: Sat, 02 May 87 18:39:59 EST
Subject: accounting programs
Hi, I don't belong to this list, but I'm wondering if any of you can
help me. For a friend, I'm looking into accounting and/or job cost
analysis programs for the MAC. Any leads into either freeware,
shareware, or any other kind of program and/or publisher would be
greatly appreciated. Preferable programs are those that would allow
keeping ledgers and so on.
Thank you for your help! (Please reply directly to me. If anyone
requests it, I will summarize responses for the list)
Bernardo Ferdman
(State University of New York at Albany, tel (518) 442-5136)
Date: Fri, 1 May 87 09:16:04 pdt
Subject: Plotters
A user here is lookming for drivers to run a Tektronix 4662 single pen
plotter and/or a 4692 multi-pen plotter. Any ideas?
Please reply direct - If we get any useful info I'll summarize for the net.
bill
Date: Tue, 5 May 87 18:36:09 PDT
Subject: Seeking TDBMS
I apologize if this subject has been covered already, but I haven't
been able to locate an answer so far. I am trying to locate a text
data base management system (TDBMS) for the mac that would be
similar to Instant Recall or AskSam on the ibm. If anyone know of
such a program, I would be grateful if they would let me know
(off-net preferably). Thanks in advance.
Walter Henry
xb.k98@stanford
Date: Thu, 30 Apr 1987 07:33 PDT
Subject: AppleTalk RS232
Infosphere (in Portland OR, (503) 226-3620) has a new product called
'ComServe' which claims to make an RS232 channel available to all
Macs on an AppleTalk. Specifically (from their brochure):
Shares an outbound serial communications channel
Supports data rates of 300 to 9600 baud
Supports the leading telecom applications, transparently
Allows servers to be selected by name, using Chooser
Operates in the background of a Macintosh, requiring no dedicated HW
Runs optionally with AppleShare and MacServe as co-resident services
Works on Mac 512, Mac +, and Mac XL
I haven't tried it (heck, I haven't even SEEN it) but it sounds good.
(standard disclaimer - I have nothing whatsoever to do with Infosphere)
Mark McNair ([email protected] University of Washington, Seattle)
Date: Tue, 28 Apr 87 16:17 EDT
Subject: Usenet Mac Digest V3 #33
Usenet Mac Digest Friday, April 24, 1987 Volume 3 : Issue 33
Re: Mac II D/A resolution
Cancelling prints
Re: UNIX and Mac applications on the Mac II
Will Lubrication Stop Annoying 400K Drive Noises?
Lightspeed Pascal Problem...
Old English font
Dove memory upgrades
Fixing Sad Macs (stuck switches)
Switcher 5.1 "scratchpad application"?
Re: HELP!! Interchanging Spreadsheet Files ie DIF SYLK or WKS??
Upgrade your Mac 512 now! (2 messages)
New Release of FzzPlot
Most appropriate sound editor?
How to launch an application
Re: Programming for High Baud Rates
Megamax C, uw and Newer system files
MacFortran 'include' sensitive to trailing blanks...
remapping keyboard ?
MacDraw, MacWrite --> PostScript? -- Request
Using UnpackBits to decode MacPaint files
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-33.ARC
DoD
Subject: Usenet Mac Digest V3 #34
Usenet Mac Digest Friday, April 24, 1987 Volume 3 : Issue 34
Writing for MacUser (warning)
Re: Graphing Programs
Speedy floating point options (2 messages)
Re: DMCS
MS Word 3.0 upgrade.
Reverting With the Resource Manager
BeepInit bug!
Re: How to launch an application
How to Change MS WORD 3.0 Menu Names?
Mac Touch Screens?
THE DEBUGGER (& macnosy)
MacinTalk on an SE ( Was: Own an SE? Can you do me a favor?)
800K Drive/128K ROM
PC/Mac Tape Backup
Re: DMCS
2400 Baud Modems
Subscribing to MacUser (warning)
Bernoulli Box & Apple HD 20 SC
chinese wordprocessor
Connecting Mac+ to Olympia Typewriter
More MS Word bugs
Why does AppleShare require a MacPlus?
Re: Modem cables
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-34.ARC
DoD
Date: Mon, 4 May 87 10:48 EDT
Subject: Usenet Mac Digest V3 #35
Usenet Mac Digest Saturday, May 2, 1987 Volume 3 : Issue 35
Re: Subscribing to MacUser (warning)
Re: Dove memory upgrades
Re: BeepInit bug!
Re: THE DEBUGGER (& macnosy)
Re: How to Change MS WORD 3.0 Menu Names?
Pascal Scientific Libraries
Wanted: digitized pictures of famous paintings
Read/Write discs in another format
"system" call
WANTED screenplay Word Processor
Re: "system" call
Re: Smalltalk80 for Mac from Xerox?
Re: Wanted: digitized pictures of famous paintings
MacUser Subscriptions
Re: MacPaint to PC-Paint
Classic Mac operation with programming for SE or Mac ][?
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-35.ARC
DoD
Date: Mon, 4 May 87 10:49 EDT
Subject: Usenet Mac Digest V3 #36
Usenet Mac Digest Saturday, May 2, 1987 Volume 3 : Issue 36
AppleTalk through Broadband?
Re: "system" call (2 messages)
Re: Classic Mac operation with programming for SE or Mac ][?
MacFortran: Bug or Feature?
Replacing Appletalk driver with RS-232 driver
EDT
Calling "LAUNCH" from Pascal
Re: anomoly in LightspeedC include file? (maybe)
Does Versaterm do custom keymaps?
Re: Replacing Appletalk driver with RS-232 driver
RamStart 1.3 bug on SE
text-to-MS Word
CD-ROMs in Apple's Future
Re: RamStart 1.3 bug on SE
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-36.ARC
DoD
Subject: Usenet Mac Digest V3 #37
Usenet Mac Digest Saturday, May 2, 1987 Volume 3 : Issue 37
MacTerminal patch for new keyboard
Re: Program compatability between Mac ][ and Classic Mac...
Re: Calling "LAUNCH" from Pascal
AppleTalk on broadband
WriteResource Bug Patch
curved arrows
Mazewars plus and Appletalk
Slide Production Systems....
Re: Patch for Font/DA Mover wanted
Re: MacSnap Memory Addition (?)
Re: TextEdit sub/superscripting
Re: curved arrows
Cheap scsi drives: survey results (longish)
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-37.ARC
DoD
Date: Tue, 28 Apr 87 16:18 EDT
Subject: Delphi Mac Digest V3 #24
Delphi Mac Digest Monday, April 27, 1987 Volume 3 : Issue 24
re: HD Backup directories
re Icons in menus
Dvorak Keyboard Layout
Any engineers out there? (2 messages)
re: SuperPaint, Aldus Prep, spelling che
RE: MacFair II and the Macintosh II (4 messages)
RE: sound problem
ResEdit is not your friend (3 messages)
Prototyper maker Addr wanted
Response to DiskTime II Review
Re: Reverting With the Resource Manager
Switcher programming
re: Writing for MacUser (warning)
re: How to Change MS WORD 3.0 Menu Names
MacFaire Rotterdam Part1 (3 messages)
MPW C code resources
word centering
archived as [SUMEX-AIM.Stanford.EDU]DELPHIV3-24.ARC
DoD
Date: Mon, 4 May 87 10:50 EDT
Subject: Delphi Mac Digest V3 #25
Delphi Mac Digest Monday, May 4, 1987 Volume 3 : Issue 25
Help (3 messages)
DiskTimer II, MacBottom 40
Word 3.0
re: ScrapSaver INIT
re: Emacs and Scribe for Mac
ADB Optical Mice
watch cursor (3 messages)
MacMemory Upgrades
Scan 300 (2 messages)
Overvue 2.1 bug
MacApp license for free programs
system heap (3 messages)
Word 3 and Switcher
The Low down on LoDown?
TMON & System 4.1
SCSI sensing (3 messages)
Font Scaling
RSG 3.0 vs. Laserprep 3.3
Re: AutoBlack and SE
Re: Help! Mangled Hard Disk
Here are the headlines
MacWorld Rotterdam Rest
Words to program by
Keyboard differences
archived as [SUMEX-AIM.Stanford.EDU]DELPHIV3-25.ARC
DoD
