INFO-MAC Digest V5 #127
Post by Info-Mac » October 30th, 1987, 1:12 am
Path: utzoo!mnetor!uunet!husc6!cmcl2!beta!hc!ames!ucbcad!ucbvax!Moderators.David.Gelphman
From: [email protected], [email protected], [email protected]
Subject: INFO-MAC Digest V5 #127
Date: Thu, 15-Oct-87 20:58:00 EDT
Article-I.D.: ucbvax.8710160158.AA28599
Posted: Thu Oct 15 20:58:00 1987
Date-Received: Sat, 17-Oct-87 11:26:37 EDT
Lines: 674
INFO-MAC Digest Thursday, 15 Oct 1987 Volume 5 : Issue 127
LASERWRITER FONT SCALING PROBLEM
Scrolling Bitmaps
source code examples wanted!
Routine to copy resources
Hypercard script for importing , usenet, delphi, etc.
Word 3.01 Bi-Directional Printing
DiskTimer II Claims
Last word on 80386(PS-2/80) vs. 68020 (Mac II)
Appletalk on Ethernet
MacDraw file format
Extending HyperCard Help stacks
hypercard mailing list?
Question: does Mac MS-Word like plain ASCII files?
Screensavers for Mac II
memory upgrades
ada for the macintosh
Control Panel mod
DISK TESTER
SDLC for the Mac
SCREENS HURT EYES (Mac SE, Plus)
Looking for math and physic programs.
HiTop Full page monitor
FullWrite delay
Turbo Pascal Upgrade 1.0 to 1.0E
What is hypercard?
Apple Consortium
Date: Mon, 12 Oct 87 15:07:23 SET
Subject: LASERWRITER FONT SCALING PROBLEM
I URGENTLY NEED HELP ON A LASERPRINTING PROBLEM.
I PRINT QUICKDRAW PICTURES FROM MY APPLICATION WHICH CONTAIN DRAWPICTURE AND
DRAWSTRING COMMANDS AMONG OTHERS. I ALSO USE THE SETLINEWIDTH PICCOMMENT.
I KNOW ABOUT TECH NOTE NO. 35 AND HAVE REMOVED ALL TXRATIO OPCODES.
THE FIRST PAGE I PRINT IS PERFECTLY OK. HOWEVER ALL FOLLOWING PAGES
CONTAIN HUGE (I.E. 48 TO 96 POINT CHARACTERS INSTEAD OF SMALLER SIZES).
I'M USING THE GENEVA FONT WITH FONT SUBSTITUTION SELECTED IN PAGE SETUP,
SYSTEM 4.1, LASERWRITER 4.0. I'VE TRIED TO RESET TEXTSIZE(0) AFTER EACH
PROPENPAGE, IN VAIN. THE PICTS PRINT OK ON THE IMAGEWRITER...
THERE MUST BE A WORKAROUND, AS OTHER APPLICATIONS CAN PRINT MULTIPAGE
MIXED TEXT AND GRAPHICS.
AS MY APPLICATION HAS TO BE FINISHED NEXT MONTH, I REALLY NEED ADVICE
URGENTLY.
THANKS VERY MUCH
NORBERT
Date: Tue 13 Oct 87 06:50:02-PDT
Subject: Scrolling Bitmaps
Does anyone have suggestions or example code to illustrate scrolling
bitmaps? I have done scrolling text and 'PICT's (w/o bitmaps, of course),
but I am not as sure how to proceed to code scrolling bitmaps.
Thanks in Advance....
Timothy Burcham
b.burch@lear
BITNET: MA.TSB@STANFORD
MCI: TBURCHAM
Date: Wed, 14 Oct 87 15:02:14 EDT
Subject: source code examples wanted!
I am a newcomer to Mac programming. So far, I have found Transkel.c (by
Paul Dubois) extremely useful. Is there any skeleton program around for
desk accessories?
Also, I would be quite interested in source code examples, preferably in
LightspeedC, of:
DAs which use windows
Modeless dialogs which use useritems (i'm mostly interested in the
procedure to draw the useritems)
CDEFS of any sort
Thanks in advance for any and all help.
-Jeremy Bornstein
Date: Thu, 15 Oct 87 16:03:51 EDT
Subject: Routine to copy resources
Does anyone know of any simple method to copy resources from one file to
another? I am writing a program where a user may edit a new file. The program
stores the current contents of the file in a temporary file on the disk. Then,
when the user selects File/Save, the program should copy the resources from the
temporary file into the other.
Atul Butte
Brown University
Date: 12 Oct 87 20:27 EDT
Subject: Hypercard script for importing , usenet, delphi,
Subject: etc.
Here's a tiny, trivial script to take in a text file such as a usenet
digest, split it into cards at any line containing "---", and load it
into a stack. It's interesting to use to experiment around with large
stacks. I've found that, published claims to the contrary, the actual
searching speed for arbitrary text is 10-50 seconds/Megabyte on a Mac Plus
(and the rate of importing text into a stack is several hours/Megabyte).
on mouseUp
ask "Import from what file?"
if it is empty then exit mouseUp
put it into fileName
open file fileName
repeat
doMenu "New Card"
put empty into tempStor -- initialize accumulator
repeat for 100 times -- max of 100 lines/card
read from file fileName until return -- grab one line
if it is empty then -- end of file
close file fileName
exit mouseUp
end if
put it after tempStor
if offset ("---", it) > 0 then exit repeat -- found end of item
end repeat
put tempStor into field "Article" -- display item
end repeat
end mouseUp
Please send me improvements on the above first, crude effort! It seems
much faster to put the imported text into a container rather than directly
into the field (perhaps because it doesn't have to do TECalText every line?).
Fields musn't have >30,000 characters in them, hence the 100 line limit
above on lines/card. 15-Oct-87 13:03:58-PDT,765;000000000001
Date: Thu, 15 Oct 87 15:56:01 EDT
Subject: Word 3.01 Bi-Directional Printing
[email protected] asked how to get bi-directional printing with Word 3.01. The
answer is the following.
1. Hold down Option and Command, THEN select the File/Print menu.
2. Press down Caps Lock, then press OK.
3. Nothing will print, so select File/Print again, without holding down
any keys.
4. Press OK without any keys.
Word should then be set for bi-directional printing. I found this tidbit of
information in the October MacUser (in the TipSheet section).
Atul Butte
Brown University
Date: Mon, 12 Oct 87 22:25:36 edt
Subject: DiskTimer II Claims
In a recent info-mac, Norm Fong of FWB gave DiskTimer II figures for
FWB's "Hammer" drives without adequately pointing out why the figures
are grossly misleading. DiskTimer II figures are based on repetitive
operations involving a single area of a disk (or two small, separate
areas in the case of the seek test). FWB's disk drivers have a
sizeable private cache. So, when DiskTimer II gives a time for
"100 24K reads" on an FWB drive, it's actually the time for one
24K read and 99 retrievals from local cache. Same story, essentially,
for writes and seeks. Since an actual user's cache hit rate is
usually somewhat less than 99%, your actual performance will be
enormously worse than these figures suggest.
Ephraim Vishniac
masscomp!wang7!ephraim
Date: 13 Oct 87 22:36:00 EST
Subject: Last word on 80386(PS-2/80) vs. 68020 (Mac II)
Reply-to:
MAC II vs. PS-2/80, The last word (I hope)
Here are results for the now-infamous Byte benchmarks comparing the 80386,
as embodied in the PS-2, with the 68020, as incarnated in the Mac II. First
two columns in the table are due to David Betz from Byte/BIX, 3rd column is
my numbers for a Mac II-equivalent upgrade in a Mac+. I did floating point
tests in Fortran, since LSC doesn't yet have 68881 hardware floating point
support. The results show plainly that the 68020 is across the board a little
faster than the 386, and MUCH faster on floating point stuff.
Mac II PS-2/80 Novy Board in Mac+
MPW C Metaware C
Dhrystone: 2857 3626 3728 (LSC)
Fibonacci: 52.37 57.26 42.58(LSC)
Float: 0.65 1.62 0.96 (Absoft Fortran)
Savage: 3.40 9.49 3.30 (" " )
Sieve: 4.82 6.45 4.78 (LSC)
Sort: 7.53 7.74 14.53(LSC)
In my opinion, if Byte does not prominently publish a retraction of their
earlier results, then they are obviously trying to deliberately mislead their
readers.
Date: Fri, 9 Oct 87 06:53:21 edt
Subject: Appletalk on Ethernet
We have a number of Mac users that would like to be networked. We have a
broadband coaxial cable running through out our site. What I am looking for
is a "Appletalk on Broadband" product. It would be the Apple equivilant to
the various "Ethernet on Broadband" products. What we DON'T want to do is
set up seperate "networks" and then bridge (read piece) them together. Use of
the phone lines is also not a solution, we don't own the wires. I'm not on the
list for distribution, so please respond to me directly, even by phone.
Thanks in advance,
Thomas K. Hinders
Network: [email protected]
or
Naval Surface Warfare Center
Silver Spring MD
(301) 394 4225 or 1802
Autovon 290 4225
Date: Mon, 12 Oct 87 12:21:56 EDT
Reply-to: [email protected]
Subject: MacDraw file format
I recently purchased a Mac and have been very happy with LightSpeed
'C' porting a large package of DOS/unix DNA and Protein sequence analysis
programs. Some of these programs generate graphical output, which I have
also done successfully, but I would like to provide versions of those programs
which write a MacDraw format file, so that figures drawn by my programs can
be more easily manipulated later.
Where can I get the format for MacDraw files?
Bill Pearson
...!uunet!virginia!wrp
[ note from moderator: the MacDraw file format is not available from Apple
but the PICT format is described in Technote #27. The Technotes are in
the archives here at Info-Mac and for those who can't FTP from the
archives they are available from APDA. DAVEG ]
Date: Mon, 12 Oct 87 21:54 EDT
Subject: Extending HyperCard Help stacks
HyperCard is indeed a superb product and the rapid proliferation
of Stacks and Hypertalk discussion attests to its timeliness.
I've been very impressed by the online HELP stack provided with
HyperCard, and have used it at the template for a new stack.
Our goal is to place a Mac near the entrance to our public Mac room on campus.
The new Help Stack will then help novices get started with the Mac. It
will include, for example,
info on the hardware and software available in the room
rules for using the room
basic introductory info about each major software product
(e.g. FullPaint, Word, MacDraw, Excel, ...)
With a little ingenuity, I think it could prove very versatile for helping
novices learn about the computer and how to access the software. Unlike
commercial tutorials, HyperCard lets me personalize the contents to
our specific situation.
I'd like to share information and stacks with fellow travelers. Considering
the popularity of the Mac in higher-education, I suspect that there are
several others out there with a similar need and interest.
Leo D. Geoffrion BITNET: [email protected]
Associate Director for NYNEX: (518) 584-5000 Ext. 2628
Academic Computing
Skidmore College
Saratoga Springs, NY 12866
Date: Sun, 11 Oct 87 23:42:32 PDT
Subject: hypercard mailing list?
Is there interest out there for a separate hypercard programmer mailing list?
I have a feeling that HC stuff will start overwhelming both comp.sys.mac and
info-mac if we don't plan fof it now.
chuq
Date: Tue, 13 Oct 87 17:22 N
Subject: Question: does Mac MS-Word like plain ASCII files?
We are desperately in need of a conversion program that converts
(or at least tries to) convert regular ASCII files to a format that
Mac MS-Word 3.01 likes better. The carriage return is interpreted as
an end-of-paragraph separator which is not what one wants to, most of
the time. As soon as our secretaries get plain text files, they have to
struggle through the file, removing the spurious paragraph separators.
I cannot believe we are the only ones having this problem.
The conversion program could e.g. accumulate //,
or -bounded records until (a) one empty line, or (b) a line that
starts with a or is encountered, and send out the
accumulated record, terminating with a single or , whatever.
Does such a program exist? Please answer to me directly since I am not
a subscriber of INFO-MAC.
KKKKKUUUUNNNNN
KKK UUUU NNNN Lambert Schomaker
K UUUU NNN [email protected]
KKK UUUU NN Nijmegen, The Netherlands.
KKKKK UU N
Date: Wed, 14 Oct 87 10:09:21 EDT
Subject: Screensavers for Mac II
Are there any screensavers which run on the Mac II (Apple monitor)
and which can activate themselves after a certain amount of idle time,
a la Autoblack?
[ note from moderator: PYRO! from Software Supply does the job rather
nicely (although not as nicely as AutoBlack). It comes as a freebee with
PowerStation or Suitcase, both of which are excellent products. DAVEG ]
Date: Thu, 15 Oct 87 09:59:10 PDT
Subject: memory upgrades
now that simm chips are becoming readily available, the memory upgrade
story is different than before. it seems that all non-simm upgrades
have gone up in price (which is too bad for some who want an
inexpensive upgrade with no thoughts for future further expansion),
while simm upgrades have gone down. but which ones are good? which
are well supported? which ram disk/cache programs are good? if you
send your experiences with upgrades, both simm and non-simm, to me i
will summarize and post. or, post replys directly.
joseph rockmore
advanced decision systems
mountain view, california
Date: Thu, 15 Oct 87 09:53:27 PDT
Subject: ada for the macintosh
does anyone know about what (if anything) is being done in the way of
ada for the macintosh? i don't expect a full implementation, nor a
validated compiler (i may be pleasantly surprised), but perhaps a
learning tool. any information would be appreciated. please reply to
one of these bboards, or directly to me. if there is enough
substantive information sent directly to me, i will summarize and
post. thanks in advance...
joseph rockmore
Date: Thu, 15 Oct 87 10:59:26 PDT
Subject: Control Panel mod
Here's an idea for the Control Panel, in the hope that someone with power will
listen...
I am getting all too many items in my Control Panel (ten at current count) and
on my Mac ][ I can scroll right past the one I want before I can blink. What
is needed is the SFGetFile filter wherein you can type the first few letters
or so of a cdev name and bring it up. That would be very helpful.
I realize there are problems should a cdev have an edit field, but none of the
cdevs present currently support such a thing and I seem to recall reading
that it was difficult, if not impossible, to do, so there shouldn't be any
conflict.
If anyone at Apple reads this, could you please mention it to Steve, Scott,
Kristee, and/or Amy?
Jon
N L [email protected]
E L PO Box 5509 L-561
C Livermore, California 94550
C (415) 423-4239
Date: Thu, 15 Oct 1987 11:26 PDT
Subject: DISK TESTER
I'm looking for a disk drive tester for Macintosh 400K and 800K drives.
In particular, the tester should provide information on the drives centering,
read/write functions, radial alignment, azimuth alignment, hysteresis, and
spindle speed.
We currently use a disk tester provided by Apple that is a go[Do/no go type
tester. If there is a problem the tester simply indicates the drive is
bad. It would be nice to know why the drive is bad; and in the case of
intermittent drive problems, it would be nice to know the tolerance factor
of the drive.
Any information would be greatly appreciated. Thanks in advance for your
time and efforts.
Dan Calderwood
Academic Computing
Humboldt State University
BITNET: GDCWOOD@CALSTATE
Date: Thu 15 Oct 1987 14:37 CDT
Subject: SDLC for the Mac
Does anyone out there know of an SDLC board for the Mac SE/ ][ or anyway
to hook a mac into an IBM mainframe using the SDLC protocol? A friend of
mine here at school asked me to look into it. If anyone has any information
whatsoever, please forward it to me directly. If I get sufficient response,
I'll summarize to the list...
Thanx in advance...
Bye for now but not for long
Greeny
Bitnet: Miss026@ecncdc
Internet: miss026%[email protected]
Disclaimer: What? Who? me? Nope...not me...you *MUST* have the wrong guy!!!
Subject: SCREENS HURT EYES (Mac SE, Plus)
Date: 10 Oct 87 04:00:00 GMT
My eyes have been hurt by some recent Macintosh screens (SE, Plus).
Symptoms include sensitivity to light, dryness, grittiness under
the eyelids, soreness. A brief exposure produced only soreness.
Another screen was mildly irritating; I had to use it with the
intensity turned down low.
These screens feel harsh to my eyes; they also "feel" brighter than they look.
I am an experienced Mac user; older Mac screens have never hurt my eyes.
Has anyone encountered problems like this? (PLEASE BE ALERT TO PEOPLE YOU
KNOW OR MIGHT HEAR ABOUT.) If so, please reply to me directly.
You can also post on the comp.sys.mac bulletin board.
Howard L. Dyckman, Dept. of Electrical Engineering, Phillips Hall,
Cornell University, Ithaca, NY 14853.
Here's more info:
The screens which bothered me had purple tint or blue with slight purple
tint. I have inspected some of them; mfr is Clinton Taiwan Corp.
Eyes hurt much worse than what ophthalmologist describes here:
In article [email protected] (David Robins) writes:
>As an ophthalmologist, I have seen many computer-related eye problems.
>All of them have turned out to be *NOT* due to the computer equipment
>itself, except when an out-of-focus or flickering system causes eyestrain.
>... Staring at anything, but particularly a terminal, reduces the blink
>rate. Tear evaporation takes place, and air "burns" the conjunctiva
>and cornea. This leads to dryness, grittyness, foreign body
>sensation, burning, and sometimes photophobia (light sensitivity). It
>can feel just like UV keratitis (corneal burn). ...
>Treatment is the same, but UV burn takes 1-2 days to heal, whereas dry
>eye heals overnight. One uses artificial tears, an over-the-counter
>preparation, every 1-2 hours, ointment at bedtime optional.
My eyes have been sore, dry, and sensitive for months, not 1-2 days.
They are recovering slowly. At one time, my eyes were so dry that mild
breezes bothered them, making it very uncomfortable to take a walk
outdoors. These and other symptoms were caused by some recent Macintosh
computer screens (SE, Plus). Prior to this experience, other
exposures produced symptoms which lasted for days.
I am an experienced Mac user; older Mac screens (as well as other
computer screens) have never hurt my eyes.
Ophthalmologist's reply above is well meant but is not the explanation for
my symptoms.
If you know of anyone who has had similar problems (perhaps
milder or shorter lasting) please contact me directly.
Date: Wed, 14 Oct 87 11:28 N
Subject: Looking for math and physic programs.
Last week I received information about MacMath. It looks very nice, but
unfortunately I could not find a program for the periodic problem
X''(x) + aX(x) = 0 .
Can somebody tel me his experience with MacMath ? Is it a course or a useful
program I can use with studying, can it handle any function ? The program
ANALYZER can find the derivative (symbolically) of a function; but how
complicated can a function be ? What are the restrictions ?
I'm also looking for other mathematic and physic programs. For example on
the Atari and Cyber there is a program called SCHOONSCHIP. Does somebody know
if that program is available for the Macintosh?
I am VERY VERY interested in programs that can fit data points in many ways,
especially if it is possible the user can define the kind of function.
I'm very thankful if you can send me any information to :
**** [email protected] ****
Thanks for reading,
Geert-Jan van Soest
Galgewater 38
2311 VZ Leiden
the Netherlands
Date: Wed, 14 Oct 87 8:16:54 MST
Subject: HiTop Full page monitor
Has anyone had any experience with the HiTop full page monitor that has been
recently advertised in MacWeek and MacUser. It is marketed by Network
Specialities INC. It is selling for 995 and seems to be a good buy. Exept
I have not heard of it before and am a little leary of spending that kind
of money and not know what I am getting.
Thanks
John Buono
Date: Wed, 14 Oct 87 16:07:21 PDT
Subject: FullWrite delay
I hate to admit that I've been eagerly waiting for vaporware, but
FullWrite sure sounds good in the ads. It looks like I'll have to
wait a while longer -- ComputerWare just told me that they don't
expect to see it for another month (and they didn't seem too confident
about that.) I'm glad I didn't take advantage of Ann Arbor's advance
purchase discount.
Can anybody confirm the rumor that some of the programmers have quit
because they lost their bonuses by missing the Oct. 1 shipping date?
Is Ann Arbor still looking for a merger? If they're looking to sell
out, maybe FullWrite is worth more to them as vaporware.
-- Steve
Date: Thu, 15 Oct 87 16:01:58 EDT
Subject: Turbo Pascal Upgrade 1.0 to 1.0E
Does anyone know whether Borland is offering any upgrade policy from Turbo
Pascal 1.0 to 1.0E? What are the differences between the two versions? Does
1.0E allow programming on the Mac II?
Atul Butte
Brown University
Date: Mon, 12 Oct 87 18:14:43 -0400 (EDT)
Subject: What is hypercard?
Can someone give a short synopsys (sp?) of HyperCard - ie what is it etc
also, what is the status of the MultiFinder?
confused and questioning
[ note from moderator: while I will not give a synopsis of Hypercard, I
believe that MultiFinder 1.0 is either being duplicated for distribution
or is nearly complete. It should be appearing in dealers very soon. DAVEG]
Date: Wed, 14 Oct 87 15:45:12 PDT
Subject: Apple Consortium
If there is someone out there who has a current list of the schools
in the Apple University Consortium, I'd appreciate it if they would
send it to me (not to INFO-MAC, please!) Thanks!
Steve Dennett
