Restore Desktop 1.0
Restore Desktop 1.0
Download: http://archive.info-mac.org/cfg/cmm/res ... top-10.hqx
Restore Desktop is MacOS Contextual Menu plug-in that saves and restores icons'
positions on the Mac Desktop. Restore Desktop restores icons' positions
automatically during display resolution changing. Restore Desktop also allows you
to restore saved icons' positions manually by control-click on the Mac Desktop.
System requirements:
PowerPC based MacOS computer
MacOS 8 or higher
ÇContextual Menu ExtensionÈ installed (part of Mac OS 8)
ÇSOMobjectsª for Mac OSÈ installed (part of Mac OS 8)
Shareware: Restore Desktop is distributed as a $10 shareware. This version is an
evaluation version. You can use it for 20 days. After that period it will present
you the registration dialog instead of restoring the iconsÕ positions. The entire
functionality will return after the registration. To unlock Restore Desktop, you
will have to register. Don't forget to write your e-mail address, so that you can
get the key to register.
