Path: utzoo!utgpu!water!watnot!watmath!clyde!cbatt!ucbvax!SUMEX-AIM.STANFORD.EDU!INFO-MAC
Subject: INFO-MAC Digest V5 #78
Date: Tue, 14-Apr-87 00:07:00 EST
Article-I.D.: ucbvax.8704140535.AA29151
Posted: Tue Apr 14 00:07:00 1987
Date-Received: Wed, 15-Apr-87 04:36:22 EST
Sender: [email protected]
Reply-To: [email protected]
Distribution: world
Lines: 390
Approved: [email protected]
INFO-MAC Digest Tuesday, 14 Apr 1987 Volume 5 : Issue 78
Re: 128K Rom versions
switcher/word
Free-Text Database Programs
popup menus allow access to Mac menus (big screen users take note)
GAME-CROSSWORD.HQX
Homebrewed 2M upgrade of non-Apple 512K Macs
Shipping files
Programs for contouring data
Optical Mouse for the Mac ?
Re: information on 800k floppy drives wanted
Usenet Mac Digest V3 #29
Usenet Mac Digest V3 #30
Delphi Mac Digest V3 #21
Date: 13 Apr 87 13:19 PST
Subject: Re: 128K Rom versions
There are at least 2 different versions of the 128K ROM in the Mac+.
The only difference in the two that I am aware of involves the SCSI port.
The early version had a bug such that if the MAC were connected to a
SCSI drive which was not turned on, the Mac would not work at all.
This was corrected in a later ROM version so that the Mac+ would function
in this configuration. I believe that any Mac which was upgraded to the
128K rom should have the ROM without this SCSI bug. I don't know of any
program which allows you to upgrade to the latest version of the 128K ROM.
Bin #88 SLAC ARPANET address: [email protected]
415-854-3300 x2538
Date: Mon, 13 Apr 87 09:51:15 -0800
Subject: switcher/word
Ralph,
I saw your note about system bombs with word and it raised my
curiousity. I have been running Word 3.0 with Dollars and Sense under
Switcher for quite a while with no problem. I have run it with ram
cache on and off. I have run it with System/Finder 3.2/5.3 and 4.0/5.4.
Thus, I am curious as to the details of your problem. I should mention
I run on a MAC+ with Apple HD20.
Barry
Date: 13 Apr 87 09:43 EDT
Subject: Free-Text Database Programs
In a recent issue of Info-Mac, Mark Zimmerman described Tiny Browser, a
free-text database program he's worked up to the alpha-test phase. I'm
interested in this program -- but am also wondering what similar programs might
exist for other environments -- specifically, MS-DOS and the DEC-20 world
(Tenex/TOPS-20).
Any information would be greatly appreciated. If I get enough information back
I'll be glad to summarize for the net(s).
Date: 13 Apr 87 15:07 PST
Subject: popup menus allow access to Mac menus (big screen users take
Subject: note)
The enclosed DA allows you to access the menus available in any application
via popup menus. It is pretty slick and the only gripe I have so far is
that it is not an INIT but has to be selected every time you boot your system.
Here is the author's description from the help file which is part of the
packit file I'm posting.
"This desk accessory allows you to access the menubar from anywhere on
the screen. It will work with (probably) any menu in (probably) any
application. It is especially useful on large screens, where it will reduce
or eliminate the painful effects of mouse-wrist and mouse-elbow. It has
been successfully run on the Radius and Mac II (as well as the 512E and
Mac Plus, of course.)"
I'm only posting this and do not want to take credit for this incredibly
clever utility. The proper credit goes to the author Robert Stromberg
and this is shareware $10.
David Gelphman
archived as [SUMEX-AIM.Stanford.EDU]DA-POPUP-MENU.HQX
DoD
Date: Mon, 13 Apr 87 14:34 EDT
Subject: GAME-CROSSWORD.HQX
Date: 11-APR-1987 12:12 by BWD
CrossWord is a games for 1 to 4 players. Clues are given by the Mac and the
players is given a user determinded time length to enter his response. If the
response is correct, points are awarded depending on the difficulty of the word
/clue.
CrossWord puzzles can be created using any word processor and saving the
file as text only. Instructions as to the file format are included.
Another crossword puzzle game, WordPlay uses a different file structure for
their puzzles. A conversion program has been written to convert these
puzzles to CrossWord format. Instructions for converting files is included
in this file listing.
I have uploaded this file for my friend Randy Hunt, but would enjoy hearing
your comments. I will pass on any suggestions or other comments.
Brian
archived as
[SUMEX-AIM.Stanford.EDU]GAME-CROSSWORD-PART1.HQX
[SUMEX-AIM.Stanford.EDU]GAME-CROSSWORD-PART2.HQX
[SUMEX-AIM.Stanford.EDU]GAME-CROSSWORD-PART3.HQX
[SUMEX-AIM.Stanford.EDU]GAME-CROSSWORD-PART4.HQX
[SUMEX-AIM.Stanford.EDU]GAME-CROSSWORD-PART5.HQX
DoD
Date: Tue 7 Apr 87 11:00:06-PDT
Subject: Homebrewed 2M upgrade of non-Apple 512K Macs
For any of you seeking to upgrade your non-Apple (3rd-party upgraded) 512K
Macs to a Mac++ size of 2MB, the following note may be of interest. I recently
performed such an upgrade on my '512e' for just over $400 using a 1.5MB clip-on
memory board from Dove computer (via MacConnection), a 74F253 mux chip, 3 wires
connecting the motherboard to the Dove board, and some electronics know-how
coupled with a bit of research and a lot of patience. You'll still need the
first three parts to try this, but a lot less of the last three if things go
well.
The basic steps are these:
1. Pop the Mac case and remove the motherboard;
2. Desolder/remove the mux board at the set of 7 pads on the m.board;
3. Solder a 6" wire each to pads #2, 3 and 6 (mark the other ends);
4. Mount the Dove board on the m.board (proper alignment is essential);
5. Connect the other wire ends to the Dove board near the center '253
6. Re-assemble Mac and try it.
NOTE: if your 512K m.board memory chips are 200ns (i.e., not the faster
versions), you will also probably need to swap the center 74LS253 with a faster
74F253, as mentioned above. If you didn't do this, Mac may go ahead and boot,
but garbage will probably be left on the screen as the CPU and video accesses
overlap. Dove took the cheaper (like $1) route of using 'LS253 chips and then
disclaiming any compatibility with 200ns RAMs or 3rd-party upgrades. Not the
best approach, as far as we purist hardware engineering types are concerned.
But this does mean that YOU'RE ON YOUR OWN. If they won't honor my 90-day
warrantee because I put in a chip that should have been there in the first
place, I'm certainly not going to make any more of a guarantee than that to
you. However, if you take the standard precautions about working inside a box
with potentially high-voltage components and static-sensitive devices, this
upgrade should go almost like clockwork. It's definitely the cheapest
reasonable way to get 2MB into your box that Apple still doesn't recognize as a
512K Mac.
Carl Madson
[email protected]
(old: [email protected])
SRI International
Menlo Park, CA
415-859-2493
the complete instructions and comments are archived as
[SUMEX-AIM.Stanford.EDU]REPORT-HOMEBREWED-2M-UPGRADE.TXT
DoD
Date: Mon, 13 Apr 87 07:51 PDT
Subject: Shipping files
I'm trying to ship text-only files from my Mac to an IBM compatable.
While we seem to be able to connect okay, and type messages back and
forth, trying to ship&receive the file with XMODEM only generates errors
and sending&capturing stream seems to get hung on the first CR. I'm
using Versaterm Pro. Anyone know of any settings I should be fiddling
with, or have any other suggestions?
Thanks in advance.
Lisa
Date: Mon, 13 Apr 1987 16:03 PST
Subject: Programs for contouring data
Is anyone aware of any programs for the Mac that do contouring of data (such as
elevations, hydraulic heads, temperatures, etc)? I am looking for something
with the sophistication of those available for IBM PC's -- especially ones
that could contour data that were not collected on a rectangular grid. I
would think that with its high-res graphics contouring programs would be a
natural for the Mac, but I have not yet seen any.
If anyone has written such a program that they would be willing to share, I'd
be very grateful. I'd like to use it to contour the output from groundwater
models in a hydrogeology class I'm teaching.
Thanks in advance for any help,
Andre Lehre
Dept of Geology
Humboldt State University
Arcata, CA 95521
[email protected]
Date: Mon, 13 Apr 87 14:22:26 EDT
Subject: Optical Mouse for the Mac ?
My original Mac mouse has done a lot of good work but I
must say it is quite tired and used by now...
Does anyone have good or bad experiences with third party
mice, especially optical ones (I know only the A+ mouse,
which seems interesting) ?
Michel.
Date: Mon, 13 Apr 87 16:20:37 EST
Subject: Re: information on 800k floppy drives wanted
You should be aware that Photon 800 drives have had problems reported with not
working on ex-128K MacIntoshes. I found this out the hard way.
Mark
Date: Mon, 13 Apr 87 10:29 EDT
Subject: Usenet Mac Digest V3 #29
Usenet Mac Digest Saturday, April 11, 1987 Volume 3 : Issue 29
II in a Mac
Advise on Laserwriters?
System File Icons not showing
Re: Macintosh Smalltalk0.3 Keyboard Configuration
Fix to Microsoft Fortran SIZERESOURCE bug.
Mac II D/A resolution (2 messages)
Global blowing away Mac II?
Re: Servant. What happened to it?
Re: PRAM 4.0 has a bad BNDL
Re: Global blowing away Mac II?
MacScheme + Toolsmith
Hard Disk Backup blunder
ncr5380 information and help
Re: Advise on Laserwriters?
Re: Stock market simulations?
BREAK in Serial Driver
MacTerminal 2.0
MacDraw Plus
Megamax C compiler
Mac networks
3rd party upgrades
Appletalk to Ethernet
Studio Session on an SE
Re: LaserWriter type
Re: MPW C annoyances....
Warp 9 Internal hard drive users
Re: Mac II demonstration software
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-29.ARC
DoD
Date: Mon, 13 Apr 87 10:30 EDT
Subject: Usenet Mac Digest V3 #30
Usenet Mac Digest Saturday, April 11, 1987 Volume 3 : Issue 30
Playboy coming to a site near you?
Word 3.0: Styles
Connecting two MacPlusses to one SCSI drive!
Re: Warp 9
Writing Printer Drivers
MacFortran 2.2: Differences between "link" and "linker020"
Re: Mac Plus with 256K ROMs?
Re: Laserwriters and 68000 object code
Re: What happened to the 'universal window manager interface'?
Programming for High Baud Rates
Word 3.0 - Spell Checking
Re: Connecting two MacPlusses to one SCSI drive!
Re: new ROMs and 3rd party upgrades
9 Trk Mag Tape for MacII
DECnet & Macs
UPDATE: MAC SE Mouse Double-Clicking problem
Re: Programming for High Baud Rates (2 messages)
IMAGEWRITER PRINTER
Microsoft Word Made Easy, Second Edition
RSG3 Postscript blocks? (also patterns)
Re: Problems with System 4.0/Finder 5.4 and (Re: Msg 18622)
Re: Disk carrying cases
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-30.ARC
DoD
Date: Mon, 13 Apr 87 10:31 EDT
Subject: Delphi Mac Digest V3 #21
Delphi Mac Digest Monday, April 13, 1987 Volume 3 : Issue 21
switch box from Priority One
RE: Re: Mac II vs. IBM PS/2 (2 messages)
Drawpicture question (2 messages)
LightspeedC annoyance (6 messages)
RE: more new WORD BUGS! (wow!) (2 messages)
STRS Template (3 messages)
4th Dimension (1st report) (4 messages)
Spell Checker
re Installer for System 4.0
re Resedit & INITs
re MAC+/FAT MAC COMPATIBILITY QUESTION
re Some observations on WriteNow:
RE: FILE RECOVERY (2 messages)
Lotus gets theirs...
Isn't MPW great?
MPW printing bug
Bernouli Box (3 messages)
AppleShare
MAC II evangelists
Prodigy Prime
archived as [SUMEX-AIM.Stanford.EDU]DELPHIV3-21.ARC
DoD
