NewCM 1.2.2
NewCM 1.2.2
Download: http://archive.info-mac.org/cfg/cmm/new-cm.hqx
NewCM is a contextual menu plugin which makes it easy to quickly create
files in open Finder windows. After configuring NewCM with a set of
template files, control-click in a window and the contextual menu will have
a submenu listing your templates. Select one, name it, and the file is
created and opened.
- Any file type can be used
- Files can optionally not be opened
- The menu can be reordered and given dividers
- Version 1.2.2 no longer depends on Mac OS Easy Open being present
Requires a PowerPC computer running Mac OS 8.
David Catmull
[email protected] ICQ: 16731215
http://come.to/dathorc/
Sent with Cyberdog: Because it's not over until we say it's over...
