Path: utzoo!mnetor!seismo!rutgers!sri-spam!ames!ucbcad!ucbvax!RED.RUTGERS.EDU!SHULMAN
Newsgroups: mod.mac
Subject: Delphi Mac Digest V2 #60
Date: Thu, 20-Nov-86 14:35:54 EST
Article-I.D.: RED.12256494642.38.SHULMAN
Posted: Thu Nov 20 14:35:54 1986
Date-Received: Thu, 20-Nov-86 23:39:23 EST
Sender: [email protected]
Lines: 745
Approved: [email protected]
Delphi Mac Digest Thursday, 20 November 1986 Volume 2 : Issue 60
RE: Hard disk drives (Re: Msg 14839) (4 messages)
Hyper Drawers warning
RE: Booting SCSI & HD20 Hard disk
RE: human touch "One Touch" board (alter (Re: Msg 14845) (2 messages)
RE: Apple fellows & "Application already open" message?
RE: Expanding your system heap (3 messages)
power supply parts
New Apple Sales Promotion? (3 messages)
Programmers at Work (2 messages)
DataFrame 40 XP is _Fast_
RE: Wanted: the MacBinary specification
RE: Computerworld Focus 11/12
RE: IBM-PC VAX MAC network?
RE: APL for the Mac (2 messages)
RE: ZoomWindows...Help Wanted
RE: Mac fan comparison
Re: mac video - drawing into ScreenBits
PCPC's HFS Backup (3 messages)
RE: Font questions
RE: HD vs. Floppy: $/Kb (3 messages)
SCSI pinouts
HFS Blues Revisited
RE: mac video - drawing into ScreenBits fast?
Subject: RE: Hard disk drives (Re: Msg 14839)
Date: 15-NOV 01:17 Hardware & Peripherals
Levco make an internal 20mb drive called the Overdrive-20, and it
couples with the 2Mx board, and the Prodigy 4 (I have both). They are
also releasing a 40mb Overdrive early in December (based on the CP340
I think). I personally like the Overdrive (even if it is not the
speediest, at the moment) because of the way it mounts internally, and
the reasonably quiet, but very efficient fan (no more heat problems).
On the Prodigy at least, the Overdrive's power supply runs the Disk and the
upgrade, so there is absolutely no extra load on the damned pple supply.
I have only had the Prodigy/Overdrive for 2 months, but (cross all appendages)
nothing has gone wrong, YET!
The Overdrive retails for about $1000, so it is not the cheapest.
Subject: RE: Hard disk drives (Re: Msg 14907)
Date: 17-NOV 02:22 Hardware & Peripherals
The allocation block size on HFS volumes is 0.5K for volumes up to
32MB in size, 1.0K for 32-64MB, 1.5K for 64-96MB, etc. The reason for
this is that a volume can have at most 65,535 allocation blocks.
Subject: RE: Hard disk drives (Re: Msg 14920)
Date: 18-NOV 04:32 Hardware & Peripherals
Shouldn't that be the "minimum allocation block size is" I believe
that you can change that on a per volume basis by twiddleing a number
in the volume header block or whatever it's called. Another reason
for having larger allocation block sizes is to reduce the amount of
fragmentation a disk undergoes. You ideallly want to tailor the size
of the allocation block to the average and mean sizes of the files on
the volumes. That tailoring process ain't easy though. An ideal
number for most users should actually be about 2k though...
David
Subject: RE: Hard disk drives (Re: Msg 14958)
Date: 18-NOV 10:24 Hardware & Peripherals
Yes, I was referring to the minimum and default allocation block size.
It can be changed prior to initializing the disk as described in the
Disk Initialization Package chapter in IM vIV. Any change after
initialization would have to be done before any files (even Desktop)
were created, and would require changing several fields in the master
directory block and the copy of the virgin MDB at the end of the
volume.
Subject: Hyper Drawers warning
Date: 15-NOV 12:28 Hardware & Peripherals
Be aware that the stupid GCC Drawers accessory fails to UnLock itself when it
quits -- thus leaving a large LOCKED, unrelocatable block in your application
heap.
If anyone has a REAL line of communication to GCC, maybe YOU can get thru to
them.
This causes real PAIN when using Lightspeed Pascal.
Subject: RE: Booting SCSI & HD20 Hard disk
Date: 16-NOV 03:17 Network Digests
> From:
> Subject: Booting SCSI & HD20 Hard disk
One way (not super elegant) way to make a SCSI drive boot before the HD-20 is
to kill the boot block signature off of the HD-20 with Fedit. Just change Larry
Kenyan's initials in the first to bytes of a volume to anything else and you
got.
Paul
Subject: RE: human touch "One Touch" board (alter (Re: Msg 14845)
Date: 16-NOV 03:41 Hardware & Peripherals
Doug:
I have a Human Touch 3 to 1 Touchboard and have been using it since July. I'm
extremely pleased with its performance and compatibility. It has, in my
experience, been compatible with all software that also works on other 2MB
upgrades. The only exception to that I have found is Pheonix 3D. I might note
that the 321 board speeds up everything on the Mac to 12.5mhz including the
Apple ROMs. I don't think the HyperDrive 2000 (a similar product) does that.
Note that I'm not completely unbiased since I wrote most of the ROM
code for the 321 board. The bad news is that Human Touch has
apparently disappeared for the time being. Their phone number 'has
been temporarily disconnected due to the customer's request' according
to a phone company recording.
One major complaint of the upgrade was its ugly external power supply. My
solution was to mount the power supply internally. Not too tough to do, even
for a hardware klutz like me. I'm not sure if you should by one (if you can
even find one) due to the unknow status of the company. One last thing, I'm
using a SuperMac DataPort to hook up a DataFrame to it. Sucker works great.
Welcome to ICONtact.
Paul
Date: 16-NOV 03:54 Hardware & Peripherals
A friend of mine bought a One Touch board, but there were some
problems with it, so he had to send it back for a new one
(regretfully, since he loved the speed). And then Human Touch went
chapter 11. I don't know what his dealer was able to do.
Subject: RE: Apple fellows & "Application already open" message?
Date: 16-NOV 03:54 Network Digests
> From: [email protected] (Takao Shimono - the TongKing boy)
> I know Dr. Alan Kay is one of three Apple Fellows.
Bill Atkinson is another.
> From: [email protected] (Michael C. Berch)
> Subject: "Application already open" message?
I think I've seen that happen when I've moved an application from one folder to
another. Apparently Finder doesn't update its APPL resource (in which it keeps
track of what applications are where). One way around this was to open the
folder containing the application.
David Dunham "If voting could change the system, it would be illegal. If
Maitreya Design not voting could change the system, it would be be illegal."
Subject: RE: Expanding your system heap
Date: 16-NOV 17:19 Network Digests
>From: [email protected] (Howard C. Simonson)
>Subject: Expanding your system heap
>Date: 11 Nov 86 22:53:17 GMT
>Organization: Amdahl Corp, UTS Products Group
>Thought I'd make a quick request to the net about the proper way to go
>about expanding the system heap.
In addition to fooling with the field in Boot Blocks containing the size of
the System Heap, make sure you also increment the Boot Blocks version number.
The 128K ROMs look at the version number first before deciding whether to
use the settings in the Boot Blocks or whether to default to settings from
the ROM.
Last I heard, it was not advisable to set the size of the System Heap larger
than 64K. Among other things, system patches have in the past been referred
to the base of the System Heap using a 16-bit offset, and if this is still
true, it might cause problems.
peter
Date: 18-NOV 04:12 Network Digests
While testing some prerelease software that gave misleading error messages, I
cranked my system heap up to 100K with no apparent ill effects. I do have a
Mac+; I think the 64K limit is much more of a problem with 64K ROMs.
Date: 18-NOV 13:28 Network Digests
Could be ... there was something to do with the coding of the trap
vector during initialization, which was compressed in the 64K ROMs but
not in the 128K ROMs. (Now where is my master concordance of Inside
Mac where I can look this up???)
peter
Subject: power supply parts
Date: 16-NOV 21:57 Hardware & Peripherals
Does anyone know where I can obtain parts for the power supply mines
almost shot
Subject: New Apple Sales Promotion?
Date: 17-NOV 20:16 SIG Business
Does anyone know why Apple has been sending out large empty envelope? After
reading someone else's report, I recevied one today.
Subject: RE: New Apple Sales Promotion? (Re: Msg 14929)
Date: 17-NOV 20:38 SIG Business
That's the new press kit for the new *** due out next January.
The way I look at it, if they got the postage right, it's a plus (in several
terms of the word).
Then again, maybe it's a sneaky way of bringing up the topic of one slot.
(stop me! stop me!)
Alf
Date: 17-NOV 21:15 SIG Business
They hope you will put some money in them and return them...
For what it's worth, I got an envelope (nonempty) with a mailing pushing APDA
today. They paid 56 cents postage for it. That might be what you aren't
getting.
Lofty
Subject: Programmers at Work
Date: 18-NOV 01:57 Programming
While killing some time in a Computerland recently, I spotted a title
"Programmers at Work" on the bookshelf. The title was enough for a
mental yuk, but since the car was not going to be ready for an hour, I
ended up thumbing through it. Turned out to be one of the most
delightful books I have ever read.
It's a series of interviews of the well known programmers of our day
(Gates, Kildall, Hertzfeld and 16 others). They express feelings,
philosophies on a variety of subjects, programming techniques, where
computers are going, the effect of age on programmi ng skills (scary,
I'm 46), how they got started, etc.
The techniques and hints are useful, but the book is so much more than that. I
identified with many of the feelings, dreams, frustrations, and triumphs
expressed. It gave me a better appreciation of what it is to be a programmer.
I can now put into word s why I enjoy it so much. It gives the profession some
dignity. Next time I fill out a form with a box marked 'occupation' I will say
'programmer' without the mental prefix 'just a'.
It's published by Microsoft Press ($14.95). The editor is Susan Lammers. I
have also seen it in Crown Books. The other big chains should be carrying it
also.
Steve Seidensticker, Author of PROLOG/m
P.S. I have no connection with Microsoft or anyone mentioned. This
is strictly an unsolicited testimonial.
Subject: RE: Programmers at Work (Re: Msg 14947)
Date: 18-NOV 13:19 Programming
I'll second the testimonial. It's a great book and I stretched it out over a
week or two instead of gulping it down at one sitting.
peter
Subject: DataFrame 40 XP is _Fast_
Date: 18-NOV 14:24 Hardware & Peripherals
I've just completed benchmarks on the DataFrame 40 XP, and I've been using it
for real work. It's very fast. Our benchmarks show about a 20% increase over
the run-of-the-mill, and the speed increase is quite noticable in use.
Ric
Subject: RE: Wanted: the MacBinary specification
Date: 18-NOV 17:57 Network Digests
To:
Subject: Wanted: the MacBinary specification
The MacBinary specification should be available on CompuServe. It's Dennis
Brothers' baby, and he's a Sysop there.
Ric Ford
Subject: RE: Computerworld Focus 11/12
Date: 18-NOV 20:30 Network Digests
To: [email protected] (Steven R. Jacobs)
Subject: Re: Computerworld Focus 11/12
I've made something of a specialty of editors on computers from IBM MVS
systems to VAX/VMS, VAX/Unix, IBM/PC and Mac systems, and I find mouse-based
editing far more efficient for me than any command-driven editors I've seen.
There are functions missing from Mac editors, but they aren't the fault
of the mouse.
I agree that it is nice to have a keyboard option for mouse commands -- the
Standard File dialogs are a good example (on the Mac Plus), but take a look
at the standardization of Command keys (there isn't any) versus the
standardization of mouse-based functions (menus, double-clicking). I thank
Apple daily for forcing some standards on the application developers, and
find it amazing and wonderful that the real non-standard, non-Macish
applications have almost entirely gone "down the tube."
Ric Ford
Subject: RE: IBM-PC VAX MAC network?
Date: 18-NOV 20:32 Network Digests
Subject: Re: IBM-PC VAX MAC network?
Bill Joy of Sun recently spoke in Boston and said that U Michigan is porting
NFS to the Mac...
Ric Ford
Subject: RE: APL for the Mac
Date: 18-NOV 20:41 Network Digests
To: [email protected] (Dave Munroe)
Subject: APL for the Mac
Although I'm not an APL hacker, Portable Software's APL for the Mac seemed
to me to be well done. They are at 60 Aberdeen Ave., Cambridge, MA 02138;
617-547-2918 (as of May 1986).
Ric Ford
"MacInTouch" newsletter
Date: 19-NOV 03:49 Network Digests
> From: [email protected] (Dave Munroe)
Quote Quad is the newsletter of the APL SIG of the ACM.
David Dunham "A mind is like a parachute. It only functions when open."
Maitreya Design
Subject: RE: ZoomWindows...Help Wanted
Date: 19-NOV 03:50 Network Digests
> From: [email protected] (Jim Meiss)
> Subject: ZoomWindows...Help Wanted
> Is it possible to set the size that the window zooms to?
Yes. I recommend setting it to the smaller of the paper size or the screen.
This way if you have a FPD or Megascreen or E-machine, you won't get obscenely
large windows.
if (((WindowPeek)window)->dataHandle != NIL) {
pr = &(**(WStateData **)((WindowPeek)window)->dataHandle).stdState;
pr->right = pr->left + WIDTH;
b = pr->top + HEIGHT;
if (b bottom) pr->bottom = b;
BTW, both your ZoomWindow calls use inZoomOut...
Maitreya Design
Subject: RE: Mac fan comparison
Date: 19-NOV 13:49 Network Digests
to: [email protected] (phillip a todd)
Subject: Mac fan comparison
Thanks to the information you posted about Mac fans,
I bought a System Saver Mac from MacConnection (for $65).
I'm very pleased with it, finding it quiet and very
well designed. The extra outlets and switches are
useful (and gave me a spare Mac cord back).
Ric Ford
Subject: Re: mac video - drawing into ScreenBits
Date: 19-NOV 04:28 MUGS Online
To: [email protected] (Alen Shapiro)
Subject: mac video - drawing into ScreenBits fast?
> Is there a way to retarget the video display mechanism to read from
> other areas of memory [besides the alternate screen buffer]?
No.
> ... my own very fast 3 line 68000 code memory-to-memorymap copy function...
Have you tried unravelling the loop, i.e., generically speaking, replacing
Move #longs,Dn
@0 Move.L (An)+,(Ay)+
Dbra Dn,@0
with
Move #longs/x,Dn
@0 Move.L (An)+,(Ay)+ ;1
Move.L (An)+,(Ay)+ ;2
Move.L (An)+,(Ay)+ ;x
Dbra Dn,@0
Even with a fully unravelled loop -- which would take more than 40K of code --
you might not make 60 frames/sec. Move.L (An)+,(Ay)+ is 20 cycles nominal,
and the Mac's effective CPU rate is somewhere around 6MHz.
Subject: PCPC's HFS Backup
Date: 19-NOV 18:33 Hardware & Peripherals
Dave>
Is the updated version of HFS Backup available yet? I've got
Subject: Font questions
Yes, there is an FKEY like Other... that lets you temporarily use
fonts not installed in the system. FONTSIE 1.51 works with many (but
not all!) programs that have a "Font" menu, and with some ("sort of"
with Word 1.05, very well with Acta and miniWriter) that don't. A
beta-test version ("Special Fontsie"), somewhat less user-friendly,
works with more programs, including MacDraw and Write/Now, but you
have to make your additions before running the program. If Jeff wants
to upload them from Delphi, he's welcome to (i.e. he can for this
purpose break the restriction on further distribution of the beta-test
version of Special Fontsie).
Lofty
[ Fontsie is available in the INFO-MAC archives. At this time I do not think
it is appropriate to upload Special Fontsie. - Jeff ]
Subject: RE: HD vs. Floppy: $/Kb
Date: 19-NOV 21:55 Network Digests
To: harvard!ci-dandelion![email protected] (Carl A. Dunham)
Subject: HD vs. Floppy: $/Kb
It seems to me that this comparison would be a lot more valid if you
included the price of the floppy _drive_ in your equation. Alternatively,
you could compare the price of floppy disk media, per megabyte, with the
price of Bernoulli Box media, per megabyte.
Furthermore, there are 10MB Paradise drives selling for under $500, and
Bernoulli Box 5MB units are listed at $499 from Icon Review. These
approach the cost of an external floppy drive with a quantum improvement
in capacity and performance.
How about including in the equation the cost of the amount of RAM you're
using for your RAM disk, if it were bought as an upgrade?
Ric Ford
"MacInTouch"
Date: 20-NOV 03:38 Network Digests
> From: harvard!ci-dandelion![email protected] (Carl A. Dunham)
Yes, but cost/K of storage isn't the whole picture. How about multiplying
access time (from Steve Brecher's DiskTimer II) to get $seconds per K? Some us
may not be as patient as you are.
Date: 20-NOV 04:17 Network Digests
> Re: HD vs. Floppy: $/Kb
There are two advantages to a hard drive. The first is convenience - that is,
to both avoid the need to flip floppies and to keep the programs and maybe data
that is frequently used in an always accessable location. The second is speed,
which has some convenience value but really only has a true purpose in a
production/commercial situation.
Your point is very well taken. Hard disks are unsuitable as a repository of
static information (as anyone who has had one go South can verify) and anyone
who is buying a hard drive for that purpose is spending extra money for some-
thing he really doesn't want.
Laird
Subject: SCSI pinouts
Date: 19-NOV 22:58 Hardware & Peripherals
Does any good person out there KNOW where the SCSI terminator gets its 5V rail
from; I thought it was pin 26, but that just hangs my SCSI bus. Running without
an energised terminator seems to be causing a lot of flaky's. I am using a lash
up of drive + power supply + flat ribbon cables. Any help will be well
appreciated. Harry
Subject: HFS Blues Revisited
Date: 20-NOV 04:19 Bugs & Features
Just in case you though HFS funnies were confined to the Hard Disk 20 side of
things...
I noticed an 800K diskette all of a sudden grew to "779K used, 0K available" as
indicated in the Finder, so I copied it onto a fresh one - which showed up with
"778K used, 7K available". No crashes or intermediate giggles, but it was a
work disk.
Did you know that about a year ago, when a woman called WBCN with a
talking Mac, Karlos 4K asked her "what size are your floppies?" It
must have been one of those rare days when Josh was absent from the
keyboard...
Laird "A Waist is a terrible thing to mind"
Subject: RE: mac video - drawing into ScreenBits fast?
Date: 20-NOV 04:22 Network Digests
As usual, Steve BRECHER beat me to the punch, but I think I have a few comments
to supplement his:
I haven't tried drawing into the screen buffer (YVES has, for one..) but I can
offhand think of a shorter and probably faster blit. [so did Steve]
LoopLabel:
MOVE.L (A0)+,(A1)+
DBF D0,LoopLabel
The .L is there in the move to move four bytes per instruction; this should be
better than the MOVE.B that I often see in print, as the 68000 will not have to
fetch the instructions as often. You'll have to pre-calculate the counter DO
as one-fourth of the number of bytes to move, and fudge for the excess, perhaps
with
FinLabel:
CMPA.L A0,lastByte
BGT.S EndLabel
MOVE.B (A0)+,(A1)+
BRA.S FinLabel
EndLabel:
or something like that. Again, I haven't found the need to draw directly into
the screen, but I have to believe that it's not so hard. BlockMove() runs out
of ROM, which isn't interleaved with video memory, so you might trace through
and see what his code is like. Is AppleTalk or a hard drive on your Mac?
One more thing: check the hardware chapter of Inside Macintosh (Vol. 3, pp.
18-20). It describes the need to coordinate with the vertical blanking
interrupt to achieve smooth animation of images. You can't do it all during
vertical retrace, but you can apparently get enough of a head start to keep
ahead of the raster. Otherwise, you might _appear_ to be achieving 30 Hz.
Also, you might have to blit just changes to the screen.
I have heard that the author of Vanlandingham tried to blit the images and to
have digitized sound as well - but was unable to combine them. I wonder what
the Macintosh 128K would have included if the 68000 had just a little bit more
power; the hardware designers apparently squeezed it for just about all it was
worth.
Laird J. Heal (MACLAIRD)
End of Delphi Mac Digest
