finderview-cm-104-de.sit
Download: http://archive.info-mac.org/cfg/cmm/fin ... 104-de.hqx
FinderViewContextMenu 1.0.4 (german version),
contextual menu plugin for Mac OS 8.5
[filename: , suggested directory: ]
The FinderViewContextMenu makes using different Finder views a lot easier.
It allows you to save Finder view settings to a contextual menu entry. This
way you can easily collect your personal set of Finder views and reapply
them with a simple control-click.
The FinderViewContextMenu is US$ 9,- shareware. It works with all versions
of Mac OS 8, including the new Mac OS 8.5. It has been download.com's Most
Popular and received a four mice rating from Ziff-Davis' macdownload.com.
You can find more info about the FinderViewContextMenu at the website:
Minimal requirements:
- PowerPC processor
- Mac OS 8 (all versions, including 8.5)
