Lisa
Lisa
Path: utzoo!watmath!clyde!cbosgd!ulysses!mhuxr!mhuxb!mhuxn!mhuxm!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: Lisa
Date: Wed, 6-Feb-85 05:15:51 EST
Article-I.D.: uw-beave.772
Posted: Wed Feb 6 05:15:51 1985
Date-Received: Thu, 7-Feb-85 03:54:34 EST
Lines: 47
Thanks for the comments, Thomas. Let me just clarify two things about what
I said. About the long time the Lisa takes to boot, you said:
With LisaBug installed, MacIntosh software boots (at least) as
fast on the Lisa as it does on the Mac. LisaBug also has the
advantage that it can trap illegal memory references, that it
has a built-in assembler, and that it uses a full screen for
the debugger display.
You seem to be talking about the time to launch a Mac application. I meant
the time to boot, to go from power off to doing something useful. That
is what you have to do when the still buggy program you're developing
crashes, isn't it? Or does LisaBug allow you to recover from some
crashes? Another thing is that the Lisa spends a long time checking
its hard disk when it boots. Your Lisa doesn't have a hard disk and
may come up much faster for that reason. Anyway, on a Lisa with a hard
disk I've seen that the time to go from power off to editing a program
is around 4 minutes.
You also said:
The MacIntosh XL upgrade does (will?) include a version of
MacWorks that can be put onto the 2/10 harddisk and that boots
from there.
So far, Apple has only gotten the number of floppies needed down to 1,
not 0. It used to be 2. You used to have to boot MacWorks and then
insert a Mac floppy with a system file and Finder to bring the system
up all the way. Now, all you need is a MacWorks floppy and after that
the Lisa will read in the system file and Finder from the hard disk.
Does anyone know if there's a way to stop the new MacWorks from reading
the system and Finder from the hard disk? I have the Manx shell on the
hard disk and set it to be the startup application. I also moved the
Finder to bin/Finder. Now when I try to boot MacWorks, it looks on the
hard disk and says "can't find finder." I don't know how to get it to
boot from a floppy so I can try to restore the hard disk for it. I'll have
to use an older version of MacWorks if the current one cannot be induced
to boot from a Mac floppy.
Since you can have a Lisa 2/10 and a 128K Mac for the price of a Hyperdrive,
you might be able to make a good development system if you only compile
things on the Lisa and run them on the Mac. That would prevent the Lisa
from crashing and avoid the very long boot time. You could also use a
few hundred K ramdisk on the Lisa to compensate for its slow hard disk. I'd
love to try this out, but problems like the one above keep on coming up.
