Re: Mac Turbo Touch / Speed Key vs. Mice
Subject: Re: Mac Turbo Touch / Speed Key vs. Mice
Date: Fri, 7-Dec-84 10:57:05 EST
Article-I.D.: uw-beave.126
Posted: Fri Dec 7 10:57:05 1984
Date-Received: Sat, 8-Dec-84 06:19:50 EST
Lines: 84
From: decvax!decwrl!amdcad!fortune!rhino!redwood![email protected]
| However, it would be interesting if thru software smarts there were several
| levels of speed depending on precise intervals of rotation of the ball.
| The major complaint voiced was that it took too many rolls to move the cursor
| to the other end of the screen. (Note the Mac has an option in the control
| panel to skip every other pixel if the speed of the mouse goes above a
| certain limit.)
| It would be interesting to hear of anyone elses experiences.
| ... Dave Trissel
A couple of years ago at a COMDEX show, I had a long talk with a manufacturer
of (mostly military) trackballs about the great mouse-vs-trackball debate.
He agreed that uncompensated trackballs are certainly worse than mice for
office automation uses, BUT... that if you properly compensated in software
they were the same as (or maybe even a bit better than) mice.
The military had apparently funded some ergonomics studies (since they tend
to use trackballs in target locators in very rugged conditions) on various
flavors of mice, trackballs, joysticks, "torque"sticks (force-sensitive
joysticks that don't move). Particularly cute were some thumb-operated
torquesticks that fit on the end of a fighter plane's jotstick.
Anyway, the key seemed to be to design the entire system as a non-linear
control system, INCLUDING the human element, and massage the human input
with an appropriate inverse transform to linearize the portion of the system
from the human's intention to the cursor's position. One of the reasons an
uncompensated mouse is so easy to use is that our hand's kinesthetic reflexes
(internal feedback, both position and velocity) are already compensated
(by evolution and childhood training) to a position-linear target acquisition,
and the mouse just passes that along linearly to the application program,
which (usually) converts it linearly to screen position.
Likewise, trackballs are difficult because the fingers aren't "programmed"
to acquire large step changes in angular position (via a ball) quickly.
(Note that fine control of local position is as easy or easier on a trackball
as a mouse, but the trackball loses when trying to zip across the whole
page and land on a single pixel.) The various XXXsticks have similar ills.
However, if you analyze the eye/hand/cursor system using standard system
analysis tools employed in "servo" design (such as impulse response, large
signal step response, white noise response, dead-band and dither, etc.),
this guy claimed that you could "linearize" the system by putting an
equalization filter between the trackball output and the cursor screen
position (in software). The equalizer would model the inverse transform
of whatever the eye/hand/trackball response was, so that the net system
of eye/hand/trackball/equalizer was linear (or nearly so). (It's actually
a little more complicated than this, since the eye/hand system has non-linear
elements in it such as slew-rate-limiting, reaction time, and variable inertia.
Still, there are servo systems that manage to give smooth response with only
"bang/bang" output, and the human fine control is already pretty good, anyway.)
The claim was that with such proper compensation, ANY of the common input
devices (trackball, joystick, torquestick) could give target acquisition
speeds as good as a mouse to untrained or lightly trained users.
The idea of using the user's actual uncompensated response as a way to
design the compensation intrigues me. Has anyone else heard anything about
this? Does anyone know of a company that has TRIED using non-mice in office
applications with ergonomically designed compensation (other than simple
two-step scale changing as was mentioned above for the Mac)?
Such compensation could, I suspect, MARKEDLY improve even stupid cursor
keys found on most dumb terminals. I know that we made a stab in that
direction back at Fortune Systems, in that the auto-repeat on the keyboard
has two "gears", and shifts into "high" if you hold the key down long enough
(like some other terminals), but from personal experience using "vi" it
just isn't good enough. The irony is that it feels like it MIGHT be much
better, if the timing were more dynamic and took into account keystrokes
that followed one another, instead of just acting when you held a key down.
Suppose your editor actually timed the intervals between keystrokes of the
cursor keys and used some sort of CVSD algorithm to translate that into
cursor motion? Has anyone done THAT?
Rob Warnock
Systems Architecture Consultant
UUCP: {ihnp4,ucbvax!amd}!fortune!redwood!rpw3
DDD: (415)572-2607
Envoy: rob.warnock/kingfisher
USPS: 510 Trinidad Ln, Foster City, CA 94404
