Atari Machine, 512K Finder Rewriting
Post by Info-Mac » February 6th, 1985, 2:02 am
Path: utzoo!watmath!clyde!burl!ulysses!mhuxr!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: Atari Machine, 512K Finder Rewriting
Date: Fri, 11-Jan-85 05:19:18 EST
Article-I.D.: uw-beave.392
Posted: Fri Jan 11 05:19:18 1985
Date-Received: Sat, 12-Jan-85 05:42:52 EST
Lines: 51
1. About Finder rewriting:
Although a true rewrite of the finder would be nice, it may be possible to
improve its performance on 512K macs by modifying memory management bits.
I tried an experiment today; I turned off, using Rmover, the "Purgable"
bits of the 4 "CODE" resources of the Finder. (Three of the four were
purgable, which means that can be swapped out by the
memory manager.) I booted the modified finder, ejected it, put in
two non-system disks, and tried some disk to disk file copies.
The results were encouraging; doing a small file copy using the standard
Finder required me two insertions of the system disk. Doing the copy
with the mutated finder required only 1 insert. Apparently, I was successful
in bringing the file copying routines into memory, but the mac still had
to modify the Desktop file on the system disk once it had completed the
copy.
Before I start playing around with other Finder and System resource bits, does
anyone know which resources it would be best to change, though I suspect that
Desktop management will always slow things down. Can much improvement
be gained, or will I run against the 46K limit of the 512K-mac system heap
size? (or of the desktop-updating algorithms that assume a small machine)
Can the size of the system heap be expanded by patching the piece
of the Finder code that sets it to 46K? And does the current finder notice
that my mac is "fat," or does it leave the system heap at the 16.5K size
of a small mac? (I am quite surprised that there is little performance
difference between the Finder on a 512K mac and a 128K mac, considering
the supposed 30K increase in system heap space.)
Thanks for your help.
2. About the "Jackintosh"
About the Atari Machine, there was also an article in the Wall St. Journal
Monday. Your prices are correct, except that the disk drive is an extra
$200, and a mouse is included. CNN's "Inside Business" showed pictures
from the conference at which it was unveiled; the machine WAS displayed, I
believe, but unfortunately the TV cameras didn't zoom in very close. They
also interviewed Jack Tramiel, who tentatively forecast April production.
The machine is not to be confused with Commodore's Amiga, which will
someday (maybe soon) be more powerful and more maclike.
Rich
P.S. I assume you all noticed a bug in the clock on January 1; my Mac
didn't advance the year to 1985. (Tell me if I'm wrong and your mac
worked.) Regarding the super bowl ad: maybe it should say "Macintosh,
why 1985 will still be 1984"
