INFO-MAC Digest V2 #42
Path: utzoo!watmath!clyde!cbosgd!ihnp4!houxm!vax135!cornell!uw-beaver!info-mac
Subject: INFO-MAC Digest V2 #42
Date: Sun, 5-May-85 22:04:51 EDT
Article-I.D.: uw-beave.1134
Posted: Sun May 5 22:04:51 1985
Date-Received: Tue, 7-May-85 22:18:25 EDT
Lines: 381
INFO-MAC Digest Monday, 6 May 1985 Volume 2 : Issue 42
list of info-applebus coordinators
Re: Printing Mac Postscript File?? (LaserPrep)
MacDraw 1.7 and Imagewriter
Improvements to UCSD Pascal....
more on Mac upgrades
2MB Mac upgrade
Inside Mac not $4.00
1 Megabyte Macs and Beyond ?
Has anybody used "Neon" ?
Date: Sun 5 May 85 00:51:45-EDT
Subject: list of info-applebus coordinators
Here is a summary of redistribution list coordinators for
info-applebus. These are the people to contact if you are at one of
the sites mentioned and you'd like to receive info-applebus.
Redistribtion List Coordinator address Area info-applebus-bbn@bbn
tappan@bbng bbn info-applebus%ucbcory@ucb-vax jsc%ucbcory@ucb-vax
Berkeley appletalk@ucla-cs request@ucla-cs ucla [email protected]
hokey%plus5.uucp@seismo ? munnari!applebus@seismo munnari!kre@seismo
Australia info-applebus-incoming@harvard sob%talcott@harvard harvard,
gcc info-applebus@utah-20 oper.crum@utah-20 Univ. of Utah
info-applebus-scrc@scrc-stony-brook hornig@scrc-stony-brook Symbolics
info-applebus%[email protected] dsc%daemon@tektronix Tektronix
ucl-info-mac@ucl-cs hugh%hcig.nott%ucl-cs United Kingdom
info-mac@mitre cperry@mitre Mitre Corp. info-applebus@cmu-cc-te
ec0n@cmu-cc-te Carnegie-Mellon info-applebus@tartan wohl@tartan Tartan
Labs info-applebus@cit-20 mikes@cit-20 Caltech
incoming-info-applebus@columbia chris@columbia Columbia Univ.
[email protected] [email protected] Univ. of Penn.
[email protected] [email protected] West Germany info-applebus@drea-xx
[email protected] Canada post-info-applebus@washington
macnair@washington U of Washintgon bboard.info-applebus@dec-marlboro
Deufel@dec-marlboro DEC [email protected] km%emory.csnet Emory
Univ. info-applebus@wsmr jmitchen@wsmr07 White Sands
info-applebus@s1-c vdb@s1-c Lawrence Livermore Lab
local-info-applebus@usc-ecl schwartzkopf@usc-eclb Univ. So. Cal.
[email protected] [email protected] Toronto nyu-info-applebus@nyt
russell@nyu-cmcl2 New York Univ.
Here are some other people at sites which don't currently have
distribution lists. If you are at one of the sites listed below,
please contact the appropriate person to have a local distribution
list created for. Thank you.
macintosh@nwc-143b, farber@udel-ee, rej@cornell, pugh%e@lll-mfe,
cmsmaint%[email protected], cperry@mitre, cralle@lll-crg,
[email protected], swg.lpress@usc-isib, [email protected],
[email protected], [email protected], [email protected],
fae.wu@ames-vmsb, billn@sri-unix, mcgrew@ru-blue
Date: 5 May 1985 1411-PDT (Sunday)
Subject: Re: Printing Mac Postscript File?? (LaserPrep)
There are two different ways that a Mac application program can talk
to the LaserWriter. The obvious way is for it to generate PostScript
directly; those files do not normally require a header. If an
application program does not do anything special, it outputs to the
LaserWriter by generating a file that has the syntax of PostScript but
the semantics of Apple QuickDraw. In other words, it is a PostScript
file that consists of a series of calls on user-defined operators, and
each of those operators corresponds to some QuickDraw function. While
this scheme can work with no cooperation on the part of the
application, it does not produce the most satisfactory results because
the semantics of QuickDraw are reasonably device-dependent, and the
computation that the LaserWriter needs to perform to emulate them at a
pixel resolution that is not an integer multiple of the screen
resolution can be substantial.
There is a header file (that gets downloaded into the LaserWriter as
part of its initialization sequence) that defines all of the operators
that are needed for QuickDraw emulation. It is not
application-dependent, and it is site-dependent only in that it
contains the server loop exit password for the LaserWriter, so if you
have changed the password on your LaserWriter from the default
password of 0000000, you will have to edit the header file to reflect
that new password (the server loop password is the first 7 characters
of the file).
It would be a fairly simple matter to modify that header file so that
it could be used as a genuine prefix to each file that is printed,
rather than being downloaded into the printer outside of the server
loop (where it will stay until the printer is rebooted).
I am enquiring as to whether or not the contents of this header file
are proprietary to either Apple or Adobe. I can't imagine that they
are proprietary, but I want to check anyhow. If the file is not
proprietary I will happily send a copy of it out to the net (it is 40K
characters, of which 19K are the actual definitions and the rest are
comments and documentation that should be stripped from it before you
actually use it.)
Brian Reid decwrl!glacier!reid
Stanford [email protected]
Date: Sat, 4 May 85 19:10:53 EDT
Subject: MacDraw 1.7 and Imagewriter
Warning (or is this a bug report?):
Don't remove the Imagewriter printer driver from your MacDraw (version
1.7) disk. If you do, if will NOT able to 'start MacDraw cold' to
create a new document i.e. if you double click MacDraw you get a
window you can not edit in. The window is all gray and none of the
tools work. Removing the Imagewriter software does NOT seem to effect
editing OLD MacDraw documents.
joel
Date: 3 May 1985 18:11:29-EDT
Subject: Improvements to UCSD Pascal....
> From: [email protected] (Werner Uhrig) > From: [email protected]
(Joel West) > > "SofTech upgrades p-System software: > Performance
speed on Apple II computers increased" > San Diego Tribune, April 22
financial pages > > ...[the p-System software]got a reputation from
program developers > as > being particularly slow in execution,
especially on the Apple, > which, > some said, "ran slow as molasses."
[Goodwin] agrees: "We lost > contact > with the customer and input of
what they wanted in a product." > But that's all changing, he said:
"We're speeding up > performance > on the Apple II family by a
magnitude of 20 to 30 times." > > - ----------------personal
comment-------------------- > > ... the UCSD Pascal for the Mac
("MacAdvantage") benchmarked in my > test between 30-100 as slow as a
compiled C. This suggests that the > new UCSD Pascal would be not a
p-system at all, but a fully compiled > language. > --
After reading the above, I called Softech to check it out. Having
used Apple Pascal on the IIe for about a year now, I was pretty
excited at the capabilities described in this article.
The performance increase described in the article comes through the
use of a native code generator (NCG). For those not familiar with the
p-system, an NCG is a program that takes the p-code produced by a
p-system compiler and translates in into native code for the processor
it is to run on. The translation is not complete; some portions of
p-code are left intact and still must be interpreted. However, the
increase in execution speed is still quite significant.
Alas, when I mentioned that I'd heard that an NCG (or some other
improvement) might soon be available for the Apple II family, the man
at Softech knew immediately what my source was. He said that the
reporter owned a IIe and got a little overzealous in his reporting.
The fact is that they currently have no plans for an improvement to
pascal for the Apple II family, though he said they WERE keeping an
ear open, and if demand was high enough, such a product MIGHT possibly
be released in the future.
However, NCGs are available (or soon will be) for several other
processors. It would be interesting to compare the performance of Mac
UCSD pascal using an NCG to Mac Object Pascal when both become
available. Also, does anyone perhaps have statistics on UCSD pascal
with an NCG on the IBM PC as compared to Turbo Pascal?
Regards,
--- Jeff Rogers
Date: Sat, 4 May 85 23:55:49 pdt
This shell script is useful for taking all or some
of the files in net.sources.mac and putting just the results
of xbin on all of them into one directory. Macsend (revised
version of 4/27 by Barry Eynon (barry!playfair@Score) can
then be used to download them all. I'm sure there is a more
efficient way to do the process than this, but it does work.
I would appreciate any improvements. With this shellscript
as a base one could set up a Red Ryder RSP to log on, down-
load everything, and log off pretty easily. Red Ryder 6.0
will hopefully have time batch files--even better! Well, I
hope this helps!
Chris Borton (sdcsvax!sdcc6!ix924)
[ Arpa net subscribers can find a copy of this stored in
UNIX-SRCS2XBIN.SHAR -jma ]
/bin/sh # Shellscript for xbin'ing groups of files to one directory
for macput. # Invokes /bin/sh upon entry. # # This shellscript will
ignore directories and files that are unreadable, # as well as any
files without the line "(This file must be converted...)" # #
Wildcards may be used. Thus, to xbin all files in the range 240 to
249 # use "macxbin 24*" # Upon termination of the operation, the
Macintosh bell will ring # two times. This is your clue to wake up
and see what is waiting. # This might be deleted if you plan to do
this in the background and # don't want to be bothered. # # Done on
May 5, 1985 by # Chris Borton (sdcsvax!sdcc6!ix924) # University of
California at San Diego. (Undergraduate CS) # mesg n for f in $* do
if [ -f $f ] && [ -r $f ]
then
fgrep "(This file must be converted" $f >
/tmp/BinHextest
if [ -s /tmp/BinHextest ]
then
rm /tmp/BinHextest
# Replace "/hp1h/ixmaster/ix924/hcx" with the full path to the
directory you # wish to put the files to download.
cp $f /hp1h/ixmaster/ix924/hcx
cd /hp1h/ixmaster/ix924/hcx
xbin $f
rm $f
# Replace "/usr/spool/news/net/sources/mac" with the path to your #
net.sources.mac if it is different.
cd /usr/spool/news/net/sources/mac
else
rm /tmp/BinHextest
fi
fi done echo -n " " echo "Downloads ready!" echo -n echo -n
mesg y
Date: Thu, 2 May 85 09:16:19 PDT
Subject: more on Mac upgrades
I posted a message here some weeks ago about Apple advising its
dealers *not* to perform the [hypothetical] 128K ROM upgrade on any
Mac that had been messed with by a third party. At that time, I had
heard this report from only one source (albeit a reliable one). Since
then (but before my message was posted here), I have received two or
three confirming reports from other (and distinct) channels. I would
advise great caution in pursuing 3rd party upgrades (including DIY)
until Apple is willing to confirm or deny the reports. I'd also
appreciate hearing directly from any of you who have any information
on this (I'll keep all names, etc., strictly confidential), and I'll
post a summary to the digest. Thanks.
..bruce..
Bruce Webster/BYTE
Magazine
bang!crash!bwebster@nosc
{ihnp4 | sdcsvax!bang}!crash!bwebster
Date: Thu, 2 May 85 09:23:21 PDT
Subject: 2MB Mac upgrade
Having warned you all about 3rd party upgrades, I thought I'd pass on
some information to you. I recently received a 3-page letter from
Duane Maxwell at Levco Industries about their Mac RAM expansion board.
To keep things brief, here's their price list and address:
"Bare" board (everything but the RAM) $499.95
1 megabyte upgrade kit 624.95
1.5 megabyte upgrade749.95
2 megabyte upgrade kit 874.95
Levco/dealer installation charge 100.00
2.0 megabytes installed: $974.95
Levco Enterprises
11568 Sorrento Valley Road, #14
San Diego, CA 92121
(619) 755-7827
A friend of mine (Will Thompkins) stopped by Levco and played with a
2MB Mac. He booted up the Assimilation RAMdisk software and created a
1.4MB RAM disk (which still left him a full 512K of work space). He
loaded it up with various applications and was quite excited about how
well every- thing worked.
Maxwell, in his letter, says that Levco plans to release a package
"that will allow the user to partition the memory in any way he or she
wants: into RAMDisks, cache buffers, and application heap space." He
goes on to point out the advantages of using a write-through cache
buffer for your disk drives instead of a RAMdisk, namely that nothing
is lost in case of a power glitch or system crash (at least, nothing
that wouldn't normally be lost).
The upgrade also includes a piezo fan, which (Maxwell claims) makes
the 2MB Mac run cooler than a regular 512K Mac. Levco is planning to
offer it as a separate product.
I thought those of you planning to do RAM expansion might want to
consider Levco's stuff. The usual disclaimers apply--I have no
interests, connections, or in any way will profit or benefit if you do
(or don't do) business with Levco.
..bruce..
Bruce Webster/BYTE Magazine
Date: Sun, 5 May 85 16:13:24 pdt
From: huxham%ucbcory@Berkeley (Frederick A. Huxham)
Subject: Inside Mac not $4.00
The reason some consortium schools think that they will be selling
I.M. for only $4.00 is due to a misprint in the latest price list from
Apple.
It listed the price as 5/$10.00 (or $2 each).
This is wrong.
At the computer store at U.C. Berkeley (I work there) you can buy them
for $15.00. I would imagine other Universities having similar prices.
Fred Huxham huxham@berkeley
Date: Wed, 1 May 85 13:00:28 EDT
Subject: 1 Megabyte Macs and Beyond ?
I have seen various discussions about rumors and plans for expanding
the Mac's memory capacity beyond 512K, which all seem to imply, when I
read them, that the extra memory is to be used for ram disk purposes,
not as extension of operational memory space.
Is there some characteristic of the way the Mac uses its address space
that precludes program and data structures to extend beyond 512K, say
because the video buffer's address, or some other io address space was
set up to be in this range? It would be unfortunate if the 68000
series machines and their potential address range were limited by this
kind of design constraint. If this is the case, does anyone know
whethe either the new ROM for the Mac or some later change will
correct it? Or can the Mac in fact take full advantage of additional
memory now?
Date: Fri, 3 May 85 17:05:56 pdt
From: ssc-vax![email protected] (Frederick Wamsley)
Subject: Has anybody used "Neon" ?
I just read a blurb from Kriyas Systems announcing a programming
environment for the Mac called Neon. Their literature describes it as
an extensible object-oriented language with full toolbox access.
Has anyone actually used it or seen it run? How fast is it? How
bug-free? How well documented?
I will post a summary if I find anything out. Please mail replies to
me directly.
Fred Wamsley UUCP:
{cornell,decvax,ihnp4,tektronix}!uw-beaver!ssc-vax!alcmist ARPA:
ssc-vax!alcmist@uw-beaver
