problems with Forth vt52 emulator
Path: utzoo!watmath!clyde!cbosgd!cbdkc1!desoto!cord!hudson!bentley!hoxna!houxm!vax135!cornell!uw-beaver!info-mac
Subject: problems with Forth vt52 emulator
Date: Tue, 8-Jan-85 15:40:21 EST
Article-I.D.: uw-beave.356
Posted: Tue Jan 8 15:40:21 1985
Date-Received: Thu, 10-Jan-85 06:40:24 EST
Lines: 36
------- Forwarded Message
Return-Path:
Received: from SU-SIERRA.ARPA by safe with TCP; Sun, 6 Jan 85 21:22:57 pst
Date: Sun 6 Jan 85 21:22:27-PST
Subject: FORTH PROBLEMS
To: [email protected]
BILL
I HAVE DOWNLOADED AND TRANSLATED THE VT52ASSIST.4TH AND MENUS FILES.
HERE I HAVE COUPLE QUESTIONS WHICH YOU MAY KNOW THE ANSWER:
1. HOW TO AVOID THE "FREEZING MOUTH" PROBLEM AFTER USING SERIAL I/O?
I HAVE FOLLOWED THE SUGGESTIONS IN MAC4TH NEWS LETTER WHICH SAYS THAT
" ... ON LINE 4 OF SCREEN 16 IN THE SERIALINTERFACE CODE:
TOKEN.FOR SERIAL.IN 'CLOSE.ALL W!
THIS POLITELY CLOSES ALL THE FILES...."
WELL, I TRIED AND IT DID NOT WORK.
2. AFTER INCLUDING THE TERMINAL ASSIST BLOCKS, I DID GET MENUS ON THE SCREEN
ALONG WITH THE MACFORTH BLOCKS MENU BARS. BUT THE MACFORTH MENU BARS WILL
DISAPPEAR THE SAME TIME AS I UNMAKE THE SOME OF THE MENU BARS OPEN FROM
OPTIO MENU EARLIER. DO YOU SEE OR HEAR ANYONE ELSE REPORTED THE SAME PROBLEM
THANKS.
DAVID LIU
------- End of Forwarded Message
