Yechi Startup 1.1
Yechi Startup 1.1
Download: http://archive.info-mac.org/cfg/yechi-startup-11.hqx
Yechi Startup 1.1
A great startup for all Macs, I repeat "Macs" and not those stink'en
IBM's.
If you like like this startup, then give me an e-mail at
If you want to actually use this startup you will need the following:
Mac OS 7.5 (or later) but not 8.0
ResEdit
Finder
Step 1: Open up the document called Yechi Startup 1.1. RSRC
Step 2: Click on the PICT resource
Step 3: Copy it!
Step 4: Open up a copy of System 7.5 Update
Step 5: Paste it!
Step 6: Click on yes when it asks you
Step 8: Swap your System 7.5 Updates and restart
Step 9: Hopefully you will see your cool Yechi Startup
Note: This is freeware, so if this startup in any way or form messes up
your computer don't put the blame on ME! It works fine on my PowerBook
Duo 2300c, Macintosh LC and Macintosh Performa 580CD, but I don't know
about any other machines.
Even if you hate this startup, then still send me an e-mail telling what
I should do in my next version.
I have a home page which you can cheak out my other freeware, the URL
is: http://www.geocities.com/EnchantedFores ... index.html.
If you want to put this software on a CD or somehting, you MUST notify
me before you do anything by e-mail.
In case you are wondering, I live in Melbourne and I am 12 years old. I
made this whole startup on just one day.
