X3 for Mac OS X version 0.1.0
Download: http://archive.info-mac.org/cfg/x3-010.hqx
X3 for Mac OS X has landed
X3 is an application that visualizes the system performance in the form of
a realtime rotating 3D-object in the Dock. It is designed to use very
little memory and processor cycles so you can keep it running all the
time.
page:
http://www.10k.org/jake/soft/soft.html
2001-11-17 0.1.0 * complete rewrite in Objective-C
* optimized 3D pipeline
* transparent background
* customizable color and CPU usage
* dynamic object selection
* vectorized data layout
enjoy
Jake
