Path: utzoo!watmath!clyde!burl!ulysses!mhuxr!mhuxt!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: Re: Apple on Arpanet?
Date: Thu, 13-Dec-84 06:14:26 EST
Article-I.D.: uw-beave.181
Posted: Thu Dec 13 06:14:26 1984
Date-Received: Fri, 14-Dec-84 06:16:49 EST
Lines: 30
Subject: Apple on Arpanet?
Date: 6 Dec 1984 1152-EST (Thursday)
I was surprised to see that, too -- but it seems to be an
artifact of a bad header munger somewhere. They're on CSNET, it
would seem; so [email protected] or
xxx%[email protected] is more appropriate.
chris
That was my fault, I'm afraid; I told the NIC to add APPLE.ARPA to the host
table prematurely. They are on the way to coming up on CSNET-PDN (CSNET's
IP network carried on the public data net). They contract with mt xinu for
kernel support and the delay is in making the arrangements for mt xinu to
add the (CSNET-supplied) X.25 software to the kernel.
The NIC has been instructed to remove them from the host table.
The same host that is currently on dial-up CSNET will be the host on
CSNET-PDN.
Mail sent to xxx%[email protected] will be correctly forwarded
both now and afterward; the posting from APPLE.ARPA does look like a
goof inspired by the NIC table entry.
Dennis Rockwell
CSNET Technical Staff
