Behavior of InvalRect
Path: utzoo!watmath!clyde!cbosgd!ihnp4!houxm!vax135!cornell!uw-beaver!info-mac
Subject: Behavior of InvalRect
Date: Sat, 15-Dec-84 01:16:54 EST
Article-I.D.: uw-beave.222
Posted: Sat Dec 15 01:16:54 1984
Date-Received: Sun, 16-Dec-84 05:00:24 EST
Lines: 20
Kato.SV had some questions about InvalRect. Here's what Inside Mac tells us
about it:
InvalRect is a Window Manager procedure that marks a rectangular portion of
a window as requiring redrawing. A call to InvalRect has no immediate
effect on the screen--it simply precipitates a subsequent update event for
the window. In response to that update event, your code should redraw the
invalid portion of the window. (For simplicity, you might just redraw the
entire window; your QuickDraw calls will be clipped to the region you
previously marked as invalid by InvalRect and InvalRgn calls. Make sure
you use BeginUpdate and EndUpdate.)
The Window Manager has a hook--a global variable called paintWhite--that
controls whether or not it paints the invalid portion of the window white
just before generating the update event. In the normal case, this painting
is done.
...Art Pope, BBN Labs Inc.
