RE: mice and keyboards
Path: utzoo!watmath!clyde!burl!ulysses!mhuxr!mhuxn!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: RE: mice and keyboards
Date: Fri, 21-Dec-84 14:37:09 EST
Article-I.D.: uw-beave.274
Posted: Fri Dec 21 14:37:09 1984
Date-Received: Sat, 22-Dec-84 03:21:15 EST
Lines: 42
I'd like to make a few new points about mice and keyboards.
First, I like the Mac mouse. It works quite well on a laminated desktop
(if cleaned monthly). Though it's not as nice as a Xerox Dandelion
Optical mouse, it has a smoother feel than the Dandelion's ball-bearing
mouse. And I like the fact that it has only one button. With two
buttons, programs attach meanings to the buttons that are arbitrary and
therefore difficult to remember. It's just as easy to hit one button as
it is the other; why should one button be reserved for the more important
or more destructive commands? With a 1-button mouse, double-clicking is
available for actions with large consequences; the user clearly sees that
to do more, he or she must keep clicking.
To illustrate the confusion encountered with 2-button mice, look at the
Mac's command and option keys. It's tough at first remembering whether
control sequences use the command or option key. You must learn the
key meanings---by using key caps, drawing the link between command and
control keys, or by the meaning of the word "command." If it takes you
three weeks to draw the association, you spend needless time uncomfortable
with part of the machine.
Criticism of the mouse has failed to mention the mouse's size. An optical
mouse is better for signing your name because it is smaller, not just
because it has low friction. A great product for the mac would be a
"Minnie Mouse"---a 1/2" x 1 1/2" x 1" mouse that would be used by the
fingertips for precise painting.
As for the placement of the "control" key on the mac, I don't think it
should be moved to caps-lock; it just should be moved over a bit. Where
where it is now, it feels like I'm hitting the space bar. It's even
sculptured like the space bar, as if I'm supposed to hit it with my thumb.
To compare, look at how far a space bar extends on a VT100. It goes all
the way to the middle of the 'Z'. On a mac, it only goes to the middle of
the 'X'. Move the command and option keys over 3/4", and you have, in my
opinion, an ideal placement. Very similar to the location of "Control"
and "Meta" on a Symbolics Lisp machine.
Rich
(Temporarily at GE, Schenectady)
