Re: Mackermit connect mode
Posting-Version: version B 2.10.2 9/18/84; site amd.UUCP
Path: utzoo!watmath!clyde!burl!ulysses!mhuxj!houxm!ihnp4!zehntel!dual!amd!jimb
Subject: Re: Mackermit connect mode
Date: Wed, 28-Nov-84 01:14:27 EST
Article-I.D.: amd.657
Posted: Wed Nov 28 01:14:27 1984
Date-Received: Thu, 29-Nov-84 04:12:52 EST
References:
Reply-To: [email protected] (Jim Budler)
Organization: AMD Applications, Santa Clara, CA
Lines: 24
In article info-mac@uw-beaver (info-mac) writes:
>From: Jyh-Jye Yeh
>The MacKermit I got from does not seem to be able to dial my Apple
>modem for some reason. I had it to work for the first time I got it and
>transfer a file to my Mac. But from the second time on, MacKermit does not
>send out any command to the modem although MacKermit seems to know that modem
>is there.
> Does anyone know how to do with this? (Or, I got a bad version of
>Mackermit)
>J. J. Yeh
>[email protected]
I had to set the DTR switch on my modem to ignore the DTR line as it
doesn't listen if this is not high. Then I went ahead and typed
ATDTphone-number. It worked. What terminal does it emulate? A vt52
like the IBM kermit?
Jim Budler
Advanced Micro Devices, Inc.
(408) 982-6547
UUCPnet: {ucbvax,decwrl,ihnp4,allegra,intelca}!amd!jimb
Compuserve: 72415,1200
The Source: STW265
