Re: BITNET mail follows
Path: utzoo!watmath!clyde!burl!ulysses!cbosgd!ihnp4!houxm!vax135!cornell!uw-beaver!info-mac
Subject: Re: BITNET mail follows
Date: Wed, 5-Dec-84 03:42:36 EST
Article-I.D.: uw-beave.2445
Posted: Wed Dec 5 03:42:36 1984
Date-Received: Thu, 6-Dec-84 03:55:09 EST
Lines: 20
It isn't MacTerminal which sets the creator to CCOM, it is macput,
although that can be changed with on of macput's command line
switches.
A binhex.hex file will have the correct creator, one of the advantages
of that transfer method.
The only way I know to find out the actual creator is with Fedit.
Page through the file in ASCII looking for APPL, the creator should
show as four upper case letters within a few bytes after that (if
there is one. A second pair of four letter names may follow, but
these are for any created files. The bundle bit must be set if there
are any of the later three names.
Jim Budler
Advanced Micro Devices, Inc.
(408) 982-6547
UUCPnet: {ucbvax,decwrl,ihnp4,allegra,intelca}!amd!jimb
Compuserve: 72415,1200
The Source: STW265
