PanALE-UniText v2.1
PanALE-UniText v2.1
Post by Info-Mac » January 1st, 1999, 11:00 am
Download: http://archive.info-mac.org/cfg/unitext-21.hqx
PanALE/UniText v2.1
Copyright ©1998, UniDoc System LLC
Welcome to PanALE/UniText 2.1 home page. PanALE is a Worldscript II
compatible system resource/fonts/extensions to enable Macintosh with
MacOS 7.5+ to
display/browse/read Chinese/Japanese/Korean in any application. UniText
2.0, a standalone styled text/HTML editor capable of editing Chinese,
Japanese and Korean, is
provided as the default editor of Pan-Asia Language Environment
(PanALE). It is an easy program which fills the gap between SimpleText
and a full featured word
processor. For Asian language user, it fills a void for a stand alone
styled text editor for double byte language with built-in fbit font and
input method support. As the CJK
inputting environment, PanALE/UniText is a shareWare ($20). If you like
the program, please support shareware concept by paying the registration
fee.
Key Benefits
Display Chinese, Japanese, Korean with any MacOS compatible
computer with system 7.1 or above in any applications.
Create, edit and print styled multilingual text in Chinese,
Japanese, Korean and any western languages.
Edit WYSWYG HTML with features tailored for GB/HZ Chinese and
Shift-JIS/EUC-J/JIS Japanese users.
Export any text file in image format using web savvy format
(JPEG/GIF/PICT).
Convert styled multilingual text in 2-byte languages to pdf
document by non-localized Adobe Acrobat for file exchange. Currently,
this only supports Elegance series
CJK truetype fonts and PanALE fbit fonts.
Convert language code set by importing and exporting text file to
be loaded to internet.
Set up an external Chinese, Korean, Japanese viewer and editor for
internet browser.
Quickly create, edit and print styled text documents of any size
(limited by RAM).
View and print TeachText or SimpleText read-only (ReadMe)
documents.
Embed picture, sound, QuickTime movie and QuickDraw 3D model in
your file for breath-taking presentation.
Drag and Drop any text, picture, sound, movie object around or to
other drag and drop compatible application.
Import/Export document from/to file format readable by other
applications.
Read document out aloud using Macintalk technology.
