TypeSaver v1.0
TypeSaver v1.0
Download: http://archive.info-mac.org/cfg/type-saver-10.hqx
Announcing the release of the Mac only utility TypeSaver
File name......: TypeSaver
Date of release: 8/8/2000
Have you ever crashed after typing for an hour and forgot to save your
work? Well, I have! I was tired of losing my work and forgetting to
save periodically, so, I created TypeSaver. It's a very simple program.
Just drop TypeSaver into the Control Panels folder and restart. Now,
every key you press (you can define which keys to save or ignore) will be
saved to a file after a specified number of keystrokes (from 10 to 1000).
This is an excellent way to make sure you won't lose any typing because
of a crash or an easy way to keep track of what other people are doing on
your computer when you're not around! The folder that contains the
file(s) that the keystrokes are saved to can be hidden and this control
panel can be locked and password protected if you wish.
Another handy feature of TypeSaver is the ability to auto-save documents
in any application after a specified number of keystrokes or mouse clicks.
System Requirements.
Min. System..: 7 on up through OS9!
Min. Hardware: Mac SE or better (Works great on PowerMacs!)
Shareware....: $10
Author.......: John V. Holder
email address: [email protected]
Home Page....: http://www.northcoast.com/~jvholder
