MacWrite to Script/Troff translator: info
Subject: MacWrite to Script/Troff translator: info
Date: Thu, 31-Jan-85 14:39:13 EST
Article-I.D.: uw-beave.680
Posted: Thu Jan 31 14:39:13 1985
Date-Received: Sat, 2-Feb-85 09:06:46 EST
Lines: 192
[ This can also be found in writetotroff.dco -jma ]
MACWRITE TO SCRIPT/TROFF TRANSLATOR
As promised earlier, here is a source distribution of the MacWrite to Script
and MacWrite to Troff translator written at Brown. This has been fairly-well
tested at Brown, and has proven to be crash-free over the last few months.
It runs with Version 2.2 MacWrite documents only right now, and will be
updated for the new version when a stable one arrives.
The SCRIPT version runs with University of Waterloo SCRIPT, and
is customized for a Xerox 9700 laser printer with a file
called "mwprof script". This will be included in the distribution as well.
The TROFF version is customized for an TROFF output device, but will work with
NROFF as well. Users of the MacWrite to Troff translator are encouraged to
look at the already archived translator done by Mike Caplinger at Rice
University to determine if this software is more appropriate for their use.
USE
The translator accepts the data fork of a MacWrite file as standard input and
generates a translated file as standard output. For example:
mwscript bazinga.script
mwtroff bazinga.me
translates the MacWrite file bazinga.data to the script file bazinga.script,
and
the MacWrite file bazinga.data to the troff/me file bazinga.me.
Once a translated the Script file is processed normally on the VM side (running
it through the appropriate Xerox 9700/SCRIPT execs if available at your site)
with the CPI=32 option.
The translated troff file is simply run through troff with the -me package.
The translator was written not to generate SCRIPT/TROFF files that an end
user would want to edit, but to generate files that would be processed and
sent directly to a laser printer. Thus, some of the SCRIPT/TROFF codings are
concerned with getting accurate output, not providing an elegantly readable
SCRIPT/TROFF file.
KNOWN BUGS/FEATURES
The software has several known bugs/features not implemented:
- Headers and footers are not implemented. Given the shortcomings of
SCRIPT and TROFF in processing these and MacWrite in storing valuable
semantic information about page numbers and the like, this was left
out in the hopes that the newer versions of MacWrite might correct
some of this.
- Tabs are not guaranteed to work after the first line of the paragraph
(TROFF only). Troff does character placement following tabs based
upon where the tab falls on the INPUT line, not on the OUTPUT line
that is being built up. Thus, it is extremely difficult to get tabs
correct for any but the first line, since the translator wraps lines
when it needs to.
- Tabs are not guaranteed to work on lines with font changes (TROFF only).
Again, because Troff determines tabs based upon the INPUT line, and
because changing leading in TROFF cannot be done inline, one runs into
the above problem.
- Decimal tabs are treated as right-aligned tabs in TROFF. (TROFF does
not implement decimal tabs.)
- Only plain, bold, and italic are implemented in TROFF.
- Only plain, bold, italic, and bold-italic are implemented in SCRIPT.
- Point size changes are not implemented in SCRIPT.
- Pictures are treated as a page advance at all times.
CAVEATS
Because this is not a WYSIWYG (what you see is what you get) system, the
formatting (line breaks and page breaks) will not be exactly as seen on
the screen, though attempts are made to use character fonts that most closely
match the size of those in use on the Macintosh. Be warned that because of
fluctuations in character sizes, tabs with very close tolerances may not work
properly, as the characters in a previous tab field might spill over into the
next tab field. When working with tabbed columns, leave a little extra room for
safety.
As well, SCRIPT and TROFF commands do not pass through the translator as
commands -- they are treated as if they are normal text. This allows one to
have lines that begin with periods, for example:
...and seven years ago
without causing the SCRIPT or TROFF processors to interpret and as a command
and subsequently choke.
INSTALLATION
Script
Currently the SCRIPT version runs on VAXes and SUNs running 4.2 UNIX; it
has not been ported to the Waterloo C Compiler for VM, but it should port
with little effort. To compile the script version for UNIX, simply do
cc -o mwscript mwxlate.c -DWSCRIPT
As well, on the VM system where it will be appropriately accessible,
install the file "mwprof script" so that it can be imbedded properly
in each individual's script document (this file contains the appropriate
input translations to get special characters).
Troff
The TROFF version runs on VAXes and SUNs running 4.2 UNIX and has produced
output for 240, 300, and 480 dot/inch Imagens and a 240 dot/inch Varian
plotter. To compile the troff version for UNIX, simply do
cc -o mwtroff mwxlate.c -DTROFF
This is all that should be needed for this version.
SUPPORT
We expect to be keeping this version up-to-date with any bug fixes that
may be reported, or an additions that people may desire to make. You are
encouraged to mail any additions or problems to
nkm%brown@csnet-relay (CSNET) or
nkm@browncs (BITNET)
so that we may include them in subsequent releases. If you do find bugs,
that you believe are worthy of reporting, please send a written description of
the problem, a machine down-loadable version of the original MacWrite document,
and the translated version to the above address. Because of limited manpower,
we won't be able to provide telephone consulting for individual problems,
but will try to answer electronic mail that comes our way.
DISTRIBUTION FORMAT
Mailed to net.sources and archived on info-mac will be two files:
mwxlate.c -- the source code for both the troff and script translators
mwprof.script -- the script include file for the script translated
documents.
COPYRIGHT
The translator is (c) 1984 Brown University. It is distributed at no cost,
with no warantees expressed or implied, and may used and modified, but not
sold without permission.
FINAL THOUGHTS
Good luck. We know that this is but a first crack at the problem, but hope
it will be of some use to those of you out there, and encourage additions,
criticisms, complaints, and anything else you might like to add. Bon Voyage!
Norman Meyrowitz
Institute for Research in Information and Scholarship (IRIS)
Brown University
Box 1946
Providence, RI 02912
Return-Path:
Received: from csnet-relay by SUMEX-AIM.ARPA with TCP; Wed 30 Jan 85 21:07:01-PST
Received: from brown by csnet-relay.csnet id bv04948; 30 Jan 85 21:21 EST
Received: from mailhost.IRIS.Brown.CSNet with SMTP via ethernet
by nancy.CS.Brown.CSNet; 30 Jan 85 (Wed) 18:59:33 EST
Message-Id:
Date: 30 Jan 85 (Wed) 18:59:58 EST
To: info-mac%[email protected]
Subject: MacWrite to Script character translation table: mwprof script
[ Find this file in mwprof.script -jma
Does that name make sense? ]
30-Jan-85 21:19:26-PST,95887;000000000001
Return-Path:
Received: from csnet-relay by SUMEX-AIM.ARPA with TCP; Wed 30 Jan 85 21:08:40-PST
Received: from brown by csnet-relay.csnet id bw04948; 30 Jan 85 21:24 EST
by nancy.CS.Brown.CSNet; 30 Jan 85 (Wed) 18:59:51 EST
Message-Id:
Date: 30 Jan 85 (Wed) 18:59:34 EST
Subject: MacWrite to Script/Troff translator: mwxlate.c (src code)
[ This file is archived in mwxlate.c -jma ]
