TV Helper 1.0.1 & FM Strip GH 1.0
Download: http://archive.info-mac.org/cfg/tv-helper-fm-101-cs.hqx
Generally Helpful Software Presents:
TV Helper GH and FM Strip GH
Don't you wish the Apple FM/TV System was as convenient
to use as a real FM radio? FM Strip GH is a set of
Control Strip modules which attempts to achieve that
goal. Instead of launching and switching to a bulky
application everytime you want to change the station
or the sound level, just click on a button.
Requirements:
* TV Helper requires either the Apple TV/Video System or
the Apple FM/TV System.
* FM Strip GH requires the Apple FM/TV System.
* Control Strip or compatible software.
* Version 1.4 or above of the Video Startup (USA) software.
* System 7.5
Cost:
TV Helper GH is free.
FM Omni GH Demo is free.
FM Strip GH (FM Omni GH + TV Sound GH) is $10 USA.
Support:
New versions and betas are archived at:
Questions should be sent to:
